Is My Solution Correct for Finding v0 Using Superposition Method?
4 replies · 4K views
noppawit
I'm solving by using superposition, I would like to ask that my solution is correct or not.
By the way, the question is "Find v0"
http://www.wisheyebio.com/uploads/Picture1.png
I don't know about superposition, but if you use KCL at the top node, you have three branches:
The left branch has the current source and two resistors.
The right branch has the voltage source and two resistors.
The middle branch has the remaining resistor.
KCL says that:
current going into node = current coming out of node
which, in this case means:
current in left branch + current in right branch = current in middle branch.
I called the current in the right branch i0, which makes v0 = i0R. I get a significantly different answer (-1.00 V), which I confirmed using a circuit-solving program.
[/URL]
You made two mistakes in the second equation. Since [tex]i_x[/tex] is entering the plus sign of the voltage source, it should enter the equation as +9V, instead of -9V.
Also, [tex]R + R + \frac{2}{3}R = \frac{8}{3}R[/tex], not [tex]\frac{32}{3}R[/tex]
IIRC, when treating the 9V source you would replace the current source with an open circuit, not a short. So the 2/3 R was incorrect to begin with.
You are right.
