Is paramitric Equation Correct?
  • Thread starter Thread starter m_s_a
4 replies · 2K views
m_s_a
http://up5.m5zn.com/photos/00017/t4x1262r70cu.jpg[/URL]
http://up5.m5zn.com/photos/00017/rpbn4bsfcace.jpg[/URL]
C1:z(t)=t , 0<t<5
C1:z(t)=5+it , 0<t<5
C2:z(t)=1-t+5i , 0<t<5
C3:z(t)=5-t+5i , 0<t<5
C4:z(t)=i(1-t) , 0<t<5
1) Not really any difference as far as I know. They both indicate integral over the contour C. 2) The parametric form for the contour has several mistakes. Can you find one? I'll get you started. The contour has 4 segments, you've listed 5. Two of them labelled C1. What's up with that?
Dear
Dick
مرحبا
سعيد يرؤيتك
1)
I can not find an answer in books,In books sometimes use pattern,Sometimes using type IIusing
In your answer:
Do you clarify if possible
2)
C1:z(t)=t , 0=<t=<5
C2:z(t)=5-t+5i , 0=<t=<5
C3:z(t)=5-t+5i , 0=<t=<5
C4:z(t)=i(5-t) , 0=<t=<5
Sorry for error
I will try again.
Thanks
See you
For (1), IF "C" represents the same contour in both integrals, then, as Dick said, they are the same. However, I suspect that the question did not mean to imply that. If the two different "C"s may mean different contours, then the first form implies that C is a closed contour while the second does not.
For (2), now you've got C2 and C3 exactly the same! (Your second "C1" in your first answer should have been "C2".)
Hi king:smile:
O.K.
used (I) for Contour = sum of Curves , and Closed
and used (II) for any Curve
Q.2
Now
z1(t)=t , 0=<t=<5
z2(t)=5+it , 0=<t=<5
z3(t)= t+5i , 5=<t=<0
z4(t)=it , 5=<t=<0
