physea
- 211
- 3
In a fluid there is gravity exerted so we know that the lower layers have higher pressure. Does that prove that Pascal's law is wrong?
The discussion revolves around the interpretation and validity of Pascal's Law in the context of fluid mechanics, particularly addressing whether the law holds true when considering the effects of gravity and hydrostatic pressure. Participants explore the implications of Pascal's principle and its consequences in various scenarios involving fluids in containers and hydraulic systems.
Participants express differing views on the interpretation of Pascal's Law and its implications in the presence of gravity. There is no consensus on whether the law is fundamentally flawed or if it is being misinterpreted in the context of hydrostatic pressure.
Participants highlight the importance of distinguishing between the equal transmission of pressure and the pressure variations due to hydrostatic effects. The discussion reveals a complexity in understanding how Pascal's Law applies under different conditions, particularly with respect to gravity.
No, it says that at each point pressure is the same in all directions.physea said:Pascal's principle says that an incompressible liquid in a container exerts the same pressure at all its points.
A.T. said:No, it says that at each point pressure is the same in all directions.
Not really. A better expression of Pascal's principle would be: Any externally applied pressure will be transmitted equally to all parts of the fluid.physea said:Pascal's principle says that an incompressible liquid in a container exerts the same pressure at all its points.
If you exert a pressure at the top of the tube, the pressure at the bottom of the tube will increase by the same amount. (This is in addition to the hydrostatic pressure that varies with height.)physea said:If I exert a pressure at the top of a tube, the pressure at the bottom of the tube will not be the same. It will be larger due to hydrostatic pressure (ie. the weight of the liquid itself)
Doc Al said:Not really. A better expression of Pascal's principle would be: Any externally applied pressure will be transmitted equally to all parts of the fluid.
No.physea said:I can accept this only in zero gravity. Isn't that correct?
So at any point in the liquid the pressure is the same in all directions. Emphasize "at any point". It does not say that the pressure is the same at all points in the liquid.A.T. said:No, it says that at each point pressure is the same in all directions.
