- 6,735
- 2,437
I think we should leave the "side track" we got into with Naty1, it is clear from the other posts by the OP (Pythagorean) that he had something different in mind :-)
Now you're clearly talking about curves in spacetime (or space). As I explained before, curves in spacetime are not a part of a quantum mechanical description of motion. So your question can only be interpreted as a question about the smoothness of curves that represent motion in a classical theory. In classical theories, you can choose to let your curves be smooth or you can choose to e.g. let them consist of straight line segments (constant velocity on each segment). It doesn't really matter.Pythagorean said:Well, let's stick to the question of infinite energy being required then (as I've brought up twice). I think It might answer the question. I've been avoiding doing the math here, because I don't know how quantum and relativistic effects will play in, but let's do corrections for that later (where and if we can, I realize that qm mathematics won't play directly in, but I'm hoping any macroscopic consequences in reality can be considered.)
x (distance)
v = dx/dt (velocity)
a = dv/dt (acceleration)
j = da/dt (jerk)
to go from 0 to v velocity without a smooth acceleration, we would have to have infinite energy obviously, because it would mean that
a = dv/dt = inf (the slope would be vertical) and that would require infinite force:
F = ma = dp/dt = inf
so velocity must be differentiable.
now a change in acceleration:
j = da/dt = d^2v/dt^2 = inf
means a change in force:
dF/dt = m*da/dt = m*d^2p/dt^2 = inf
and at this point, my weak mathematical foundation fails me. How do I test the plausibility of an infinite change in Force?
There's more than enough knowledgeable people here already. How would a moderator resolve the disagreement? By repeating what's already been said? By locking the thread?Civilized said:In my opinion, we need to get some knowledgeable moderators into this dicussion so that we can resolve this disagreement for good.
Pythagorean said:How do I test the plausibility of an infinite change in Force?
(edit/foreshadowing: I have an epiphany and concede to one of your former points at the end of this post)Fredrik said:Now you're clearly talking about curves in spacetime (or space). As I explained before, curves in spacetime are not a part of a quantum mechanical description of motion. So your question can only be interpreted as a question about the smoothness of curves that represent motion in a classical theory.
Fredrik said:It's not a problem to have curves that fail to be smooth at a finite number of points. It would however be a problem to have a curve that isn't smooth anywhere, but there's no reason to consider such curves in classical mechanics.
fleem said:We've discovered various apparent rules of the universe, and one of those rules is that treating infinity like any other number is a no no, and we don't fully know how to treat it--maybe because there ain't no such animal in the first place.
That's kind of where I was going with this, I guess, yeah. Didn't really make the Zeno connection though.fleem said:Perhaps one of Zeno's paradoxes is more in line with what you are talking about? if so, I tend to agree that Zeno's paradoxes are more than just quaint stories. But I think the point of the other posters is that the current (classical) model ignores things like that, right or wrong. If its Zeno's paradoxes, or the indivisibility of QM intervals, then we can talk about that.
fleem said:No one has done that yet
Isnt the infinite energy of the vacuum a genuine infinity in nature ?Pythagorean said:I don't think we've found a genuine infinity in nature yet.
Nick666 said:Isnt the infinite energy of the vacuum a genuine infinity in nature ?
it is a mental (mathematical) construct but an essential one...
Naty1 said:jambaugh:
Be cautious! Such firm "beliefs" may blind you! : such "beliefs" have tripped up physicsts for all of history and prevented them from understanding new theories and experimental findings .
also recall that light was once viewed as traveling in ether, mass was "solid", space and time were "fixed and immutable", a proton is a fundamental particle, dark matter and dark energy are "impossible" (just mathematical constructs) etc,etc,etc.
Just keep an open mind. For example, if matter is both a particle and a wave,and equivalent to energy, why can't space and time be as well?? (after all, they all came from the same place: nowhere ("empty" space))... Nobody knows.
http://en.wikipedia.org/wiki/Vacuum_energyfleem said:This is new to me. Current theory is that the energy in the universe is finite.
Nick666 said:http://en.wikipedia.org/wiki/Vacuum_energy
It says here that the energy of the vacuum is infinite, but they renormalize it. Whatever that means.
As a non-scientist, you should stay quite calm when it comes to these points...
Naty1 said:valid point; And scientists, especially calm...
This caution runs both ways... but if you look at history the mistakes made in "too dogmatic beliefs" have been in reification of models and failure to pay attention to operational meaning. Einstein was able to revise his view of time and thence unify space-time by acknowledging that "time is what a clock indicates" and "distance is what a measuring rod measures". Hence the reality is in the dynamics of the clock and the measuring rod. His open-mindedness on this point allowed him to then generalize the previously fixed relationships between these. However the success of his theory led to the opposite position, with followers taking the geometric model as an ontological fact. This tends to be the nature of scientific progress.Naty1 said:jambaugh:
Again the aetheric interpretation of light was a mistake of reifying a model. It was in acknowledging that the reality of the aether was not necessary to describe the dynamics of light which led to relativity. Relativity doesn't assert the ether is real and doesn't assert the ether is unreal. It shows that the question is irrelevant because the physics is in the empirical observations of how light behaves.also recall that light was once viewed as traveling in ether, mass was "solid", space and time were "fixed and immutable", a proton is a fundamental particle, dark matter and dark energy are "impossible" (just mathematical constructs) etc,etc,etc.
My mind is quite open, but I am skeptical of many of the "kludges" (such as dark energy/matter and inflation) to get them to fit empirical data.Just keep an open mind. For example, if matter is both a particle and a wave,and equivalent to energy, why can't space and time be as well?? (after all, they all came from the same place: nowhere ("empty" space))... Nobody knows.
Astronomical observations have shown that the (energy) density of vacuum is rather small. It's certainly not infinite.Nick666 said:http://en.wikipedia.org/wiki/Vacuum_energy
Here Here!DrFaustus said:Pythagorean -> You keep asking questions about "Reality" (whatever that is) and are trying to come up with answers starting from physics. And this is the main problem you're having, that is not realizing that we can only infer properties about "Reality" by working out the consequences of the assumptions we make. [...] Bottom line, do not mistake a "model" for "Reality".
Yes. I agree that renormalization methods are valid and meaningful in the successful QFT of the standard model. Your point about the necessity of renormalization and how it relates to the canonical commutation relations is an important one. My past research has been in deformation expansion of the canonical commutation relations. The "necessity" of the canonical relations themselves stems from the very use of a field theory namely the fibration of space-time-gauge parameters into gauge fields over a space or space-time. The foundational assumption is that each point in space (or even each cell of space) has a physical quantum system associated with it. One is forced to count their ground contributions leading to the divergent vacuum energies. (One interesting result I've yet to publish is a relativity to the bosonic vacuum which I think could "hook" into GR.)jambaugh -> A quick remark on renormalization. It is true that in most of the books on QFT it does indeed appear as a "quick fix", but it not need be so. The mathematical reason for divergences to appear (at least some of them) is because a rigorous mathematical treatment of quantum fields requires quantum fields to be "operator valued distributions" and not operators. The reason is simply that you cannot satisfy the canonical commutation relations with operators and because if you consider the CCR at the same spacetime point, e.g. for the simple scalar field you have [tex][\varphi(t,\vec{x}), \partial_t \varphi(t,\vec{x})] = \delta(0)[/tex], which is infinite, or better, meaningless.
I agree (w.r.t. QFT) and of course the non-renormalizability of Grav in QFT suggests an alternative to QFT is necessary for the next theory. (Hence string-brane mathematics but as I said I see these as promulgating some of the same problems).Is renormalization gone? Not really. But it does not involve "subtractions of infinite quantities" as it usually does. Renormalization is now carried over as the "extension of products of distributions to points where such a product is ill defined". But this can be, and is done in a finite way. And also perturbation theory is based on causality so the formalism is perfectly well defined at all steps (this is the method of Epstein and Glaser). The reason why this is not thought is that it involves a lot of mathematical work and is generally not needed in current physical research. In any case, this really suggests that renormalization is in some sense an intrinsic feature of QFT.
Thanks for the references I'll compare them to my own library. However as I'm not looking to improve theory within QFT but rather to supplant it I'm not as concerned (yet) with improved expositions of renormalization or field theory. I may take a look at the Scharf book.(For the latter point, you can have a look at Bogoliubov's book "Introduction to the theory of quantized fields". As for renormalization being carried over in a mathematically rigorous way by handling products of distributions, have a look at "Finite QED" by Scharf.)
DrFaustus said:But questions like "Is spacetime a manifold?" are on the one hand not for physicists to answer (as you have noted it easy to cross the borderline with philosophy) and on the other completely irrelevant. As long as your assumptions allow you to describe and predict the result of experiments, that's all you need.
DrFaustus said:Bottom line, do not mistake a "model" for "Reality".
I am open minded but I don't buy every new speculation just because it generates juicy headlines in the popular media. (E.g. FTL tunnelling). Neither do I take orthodox views...
DrFaustus said:As for renormalization being carried over in a mathematically rigorous way by handling products of distributions, have a look at "Finite QED" by Scharf.)
malawi_glenn said:as far as we/I know, yes, it is smooth
Civilized said:Just wanting to add another witness to the fact that every mainstream book on quantum mechanics and quantum field theory treats space / spacetime as a smooth manifold.
Well said, all the currently established mainstream theories (the standard model) and the mainstream extensions to these (GUTs, string theory) always treat spacetime as a smooth manifold.
Naty1, Malawi and I have both gone through a mainstream graduate education in physics, and we are telling you that spacetime is smooth in the standard model and in string theory. You are disagreeing with us on the basis of vague statements in wikipedia and popularized books, when we each have shelves full of textbooks that leave no doubt that spacetime is smooth in all of our current physical theories. In my opinion, we need to get some knowledgeable moderators into this dicussion so that we can resolve this disagreement for good.
Pythagorean said:Is Spacetime Smooth?
Smooth: infinitely differentiable
ibcnunabit said:I don't think anyone really knows, at this point. It hasn't been proved either way, but we do know that if it's quantized it must be a pretty fine-grained quantization. Reiner Hedrich, for one, has written a number of papers on the idea of quantum spacetime.
If quantum mechanics is universally true, then it's quantized. If quantum gravity turns out true, then spacetime must be quantized, so gravitons would mean quantum spacetime. As would chronons, if you believe in quantum time, but that's pretty speculative at this point.
Right now most (non-QM) models start with an assumption of smoothness, but hey--a HD TV looks pretty smooth from a distance, but we all know there are pixels when you look closely enough. I'd like to see it proved one way or the other; I'm very curious to find out which way it comes out.
--Mike from Shreveport
john 8 said:There is no scientific reference or definition that states that space-time is a thing that exists as an entity. Please stop this science fiction fantasy. The field of science does not define space-time as a physical thing.
WaveJumper said:As far as physics and science are concerned, there is no such thing as physical matter or as you say "Physical thing"(the daily usage of the word "physical stuff"). There is only quantum fields that exchange force carrier bosons to create the illusion of solid physical stuff.
"Physical things" cannot be touched. You have never really touched anything at all, as the electrons in the outer shells repel the electrons of matter at 10^-8m.
Having said that, I think spacetime appears as much a thing as solid matter. And they are both relative to the frame of reference of the observer.
