Is Super Commutativity Essential in Defining a Super Lie Module?
  • Context: High School
  • Thread starter Thread starter Korybut
    Definition module
4 replies · 2K views
Korybut
TL;DR
Is supercommutativity is necessary?
Hello!
I have some troubles with the definition of the so called super Lie module. In Alice Rogers' textbook "Supermanifolds theory and applications" definition goes as follows
Suppose that ##\mathbb{A}## is a super algebra and that #\mathfrak{u}# is a super Lie algebra which is also a super ##\mathbb{A}## module such that
## [AU_1,U_2]=A[U_1,U_2]##
for all ##A## in ##\mathbb{A}## and ##U_1,U_2## in ##\mathfrak{u}##. Then ##\mathfrak{u}## is said to be super Lie module over ##\mathbb{A}##.
According to this definition I assume that ##AU\in \mathfrak{u}## for ##A\in \mathbb{A}## and ##U\in \mathfrak{u}##. However if one considers chain of transformations
##[AU_1,BU_2]=A[U_1,BU_2]=-(-)^{|U_1|\, (|B|+|U_2|)}A[BU_2,U_1]=...##
##-(-)^{|U_1|\, (|B|+|U_2|)}AB[U_2,U_1]=(-)^{|B|\, |U_1|}AB[U_1,U_2]##
On the other hand one can do it differently
##[AU_1,BU_2]=-(-)^{|AU_1|\, |BU_2|}[BU_2,AU_1]=...=(-)^{|A| \, |B|} (-)^{|B|\, |U_1|}BA[U_1,U_2]##
If someone adds supercommutativity of the algebra #\mathbb{A}# in definition than everything is fine.
Book also provides an example
Suppose that ##\mathfrak{u}## is a super Lie algebra, and that ##\mathbb{A}## is a super algebra. Then ##\mathbb{A}\otimes \mathfrak{u}## is a super Lie module over ##\mathbb{A}##, with bracket defined by
##[AX,BY]=(-)^{|B|\, |X|} AB[X,Y].##
This example is not clear also due to same issue.
In definition of left(right) super #\mathbb{A}#-module algebra is supposed to be super sommutative (which may be relaxed I suppose). However this not required or written explicitly in definition or example of super Lie module.
I get the following equations
\begin{align}
[A.U_1,B.U_2]&=A.[U_1,B.U_2]\\&=(-1)^{|U_1||B.U_2|}A.[B.U_2,U_1]\\&=(-1)^{|U_1||B.U_2|}A.B.[U_2,U_1]\\&=(-1)^{|U_1||B.U_2|}(-1)^{|U_2||U_1|}A.B.[U_1,U_2]\\
&=(-1)^{|U_1||B|}A.B.[U_1,U_2]\\[6pt]
[A.U_1,B.U_2]&=(-1)^{|A.U_1||B.U_2|}[B.U_2,A.U_1]\\&=(-1)^{|A.U_1||B.U_2|}(-1)^{|U_2||A|}B.A.[U_2,U_1]\\
&=(-1)^{|A||B|+|U_1||B|}B.A.[U_1,U_2]\\&=(-1)^{|U_1||B|}A.B.[U_1,U_2]
\end{align}
but have difficulties checking yours. I used the first result from (24) to (25) and the fact that we are only allowed to pull out the "scalar" at the first position of the bracket.
Reply
\begin{align}
\end{align}
I do get the same results as you actually. But moving from line (8) to (9) you have used supercommutativity ##AB=(-1)^{|A|\, |B|}BA## but according to the textbook's definition algebra ##\mathbb{A}## is not necessarily super commutative it is just any super algebra. Perhaps author forgot to add this fact in the definition.
fresh_42 said:
I think super commutativity is inevitable for compatibility reasons. The calculation uses the Lie multiplication to switch the order between ##A.B.U## and ##B.A.U##. This has to be leveled.
One more time thanks for your help!
