Is Superdeterminism a Plausible Explanation for Quantum Mechanics?
87 replies · 13K views
In above superdeterministic model what would the expression be for all possible permutations : given 360 settings at A and B that are encoded in λ . Then that would be 3602 for detectors. Then how would encoded spins in λ at A and B be incorporated ?
It's not difficult to show that you can you can potentially "explain" any correlations by exploiting the superdeterminism loophole. For example, take ##\lambda## to be of the form ##\lambda = (r, s, \boldsymbol{a}, \boldsymbol{b})## with ##r, s \in \{-1, +1\}## and where ##\boldsymbol{a}##, ##\boldsymbol{b}## are unit vectors in ##\mathbb{R}^{3}##. Then set $$\begin{eqnarray}
\boldsymbol{o}_{\mathrm{A}}(t_{1}, \lambda) &=& r \cdot \boldsymbol{a} \,, \\
\boldsymbol{o}_{\mathrm{B}}(t_{1}, \lambda) &=& s \cdot \boldsymbol{b} \,, \\
\rho(\lambda) &=& p(r, s | \boldsymbol{a}, \boldsymbol{b}) q(\boldsymbol{a}, \boldsymbol{b}) \,.
\end{eqnarray}$$ Then you can make ##q(\boldsymbol{a}, \boldsymbol{b})## be whatever probability (or probability density) you want that measurements along the axes ##\boldsymbol{a}## and ##\boldsymbol{b}## will be chosen, and make ##p(r, s | \boldsymbol{a}, \boldsymbol{b})## whatever probability you want that the result of measuring along axes ##\boldsymbol{a}## and ##\boldsymbol{b}## will be ##(r, s) \in \{++, +-, -+, --\}##.
They don't have a model in any really useful sense though or discuss the magnitude of the task that would be. For example, suppose I planned to do a Bell experiment tomorrow in which two humans will (rapidly) choose the measurements to be done in the course of the experiment. In order for them to say in advance what their function ##\mathcal{F}(t_{1}, \lambda)## was they would need a physical theory that was comprehensive and detailed enough to predict not only what the spins are going to be but also human behaviour -- what measurements the humans are going to choose to do -- so that they can explain why they decide to do the right measurements at the right times for the experiment to show a Bell violation.
DrChinese said:
2. An examination at C is performed, yes. However, A and B have no common light cone (in the sense that their prepared state never existed in a common light cone).
I don't think this is correct since A and B must share a common past light cone. That is what locality meas and that is why they share the same value of lamda.
Other than the fact that all experimental setups on this planet could be considered to exist in a common light cone: No, you are incorrect.
My point exactly is that the cited experiment does not have the possibility that the measurement settings could be part of any local set of hidden variables. There was never any contact between Alice and Bob (A & B). And there was no common source for the entangled particles. The entanglement occurs afterward, at C. Not before - as in many Bell tests.
Now wle is saying that the OP paper exploits the superdeterminism loophole. I'm not entirely sure about that, but there is plenty of indicators that wle is correct. The problem is that a paper touting superdeterministic ideas should be so labeled in the abstract. That it would not be borders on intentional misdirection.
In fairness: I consider superdeterminism to up there with witchcraft and conspiracy theories when it comes to considering it as science. But that is stuff for a different thread. :smile:
Thar's right measurements are spacelike separated
This is not correct. You may want to check Bell's "The theory of local beables ". Here he explains the concept of local causality and draws a nice picture(fig.3) where the common causes responsable for the correlations are seen to lie in the overlap region of their past light cones. This is how the correlations are supposed to be locally explained by the hidden variables.
Now wle is saying that the OP paper exploits the superdeterminism loophole. I'm not entirely sure about that, but there is plenty of indicators that wle is . :smile:
Threre's no doubt @wle is correct. It is explicitly stated in the paper.
After this discussion here are two conclusions:
1. The paper is not very interesting because it relies on superdeterminism
2. The authors issue a wrong statement when saying that double slit experiments can be interpreted as an statistical effect.
Thank you guys!
Sorry, you are mistaken (excepting of course that all experiments on Earth can be said to exist in a common light cone.
The reason is that the experiment I cited is NOT causally constructed like most Bell tests. The cited experiment had never been performed while Bell was alive, not sure it had even been conceived at that time. There have now been many experiments in which entanglement occurs without any causal contact between the entangled particles. So it makes no sense to construct a paper around an explanation of entanglement that ignores experiments such as what I cited. They have basically ignored decades of experimental work.
Thank you guys!
1. Assuming everyone agrees the OP article is intended as a superdeterministic explanation of Bell, I would call such a paper a scientific sham. IMHO there's no science hiding there.
Well from this complete paper by the authors : https://arxiv.org/abs/1605.0849T3
They are intending a deterministic explanation for the correlations:" In our view non - local correlations emerge from a deterministic evolution of a shared hidden variable between two components of the ontological pair. And this also agrees with @A. Neumaier and his definition of Extended causality: *
"Joint properties of an extended object depend only on the union of the closed past light cones of their constituent parts and can influence only the union of the closed future cones of their constituent parts."
* Can this definition of Extended causality apply to space like separated experiments ?
Sorry but I'm suspicious about your assertion. I agree that the precicion to test Bell theorem has been increasing with time, however you are saying that the basic concept of entanglement that Einstein and Bell were talking about has become obsolete rendering Bell's proofs inaplicable.
Since I'm not an expert I can not tell but I would like hear some other opinion on this point.
Nothing about Bell's Theorem has changed or diminished in the slightest. If you think that's what I am saying, please reconsider. What you were quoting is something else written by Bell about a specific type of Bell test. Bell tests have advanced greatly since to eliminate even more "loopholes". Some of those loopholes are detection/fair sampling and locality, which are simultaneously eliminated in this test. Also, and relevant to the OP's claims:
"Our experiment already excludes all models that predict that the random inputs are determined a maximum of 690 ns before we record them..."
That is in addition to the fact that Alice and Bob are not in causal contact. So there are no shared local variables related to the particles being measured. And the measurement settings themselves are determined independently by Alice and Bob a very short time before their measurements, far too short to have been communicated from one to the other.
That's quite a lot of physics for even a superdeterministic hypothesis to overcome. :smile:
Here's a question for Dr. Chinese, who is more familiar with these tests of entanglement. The usual way that a Bells-Theorem-violating twin pair is produced is something like the figure below:
There is some kind of decay process that produces an entangled particle/antiparticle. (I drew it as a photon decaying into an electron/positron pair, which actually isn't possible, but maybe you could substitute a [itex]\pi_0[/itex] meson to make it plausible. How the particles are produced are not important for this discussion.)
Now, let's vary the experiment by producing 4 particles, as shown in this figure:
In this figure, we produce two sets of correlated pairs. The question then is: Is there something that can be done to the two particles in the box--some kind of measurement maybe--that forces the remaining two particles to be entangled? Maybe if you measure the total spin of the two particles in the box, and find them to have total spin zero, then that will force the other particles to be anti-correlated?
If an experiment like this were possible, then it would be a way to produce entangled particles that have no common past. That would seem to be an even simpler argument against local hidden variables than Bell's theorem--the correlations can't possibly be explained in terms of local hidden variables if they never met in the past to share that hidden variable.
Entangled quantum objects need not have a common past light cone, nor a common future light cone. This can be seen by the existence of entangled pairs where the sub-components have never co-existed at any point in time.
The point to recognize here is that the technology today has advanced so far that the old ways of looking at entangled pairs is outmoded. Formerly, entangled pairs arose from a common source. That provided us an easy to picture model of entanglement which is intuitive (to some degree). Everything apparently moves forward in time:
(Future)
Alice: V :Bob
(Past)
However, entangled pairs can be created from fully independent sources as well. I.e. 2 lasers in different spatiotemporal regions. Those objects are then entangled via entanglement swapping at a third spacetime point. This is done in such a way as the spacetime cones of the swapping components is also independent. In fact this can be done after the other particles no longer exist, just to drive the point home.
Now, if you choose to define the extended object as being the region defined by ALL of its components at all times they exist, then the definition above is fine. However, the resulting causal diagram has arrows in BOTH directions of time. It looks something like (Chris would be in the middle, not labeled below):
(Future)
Alice: W :Bob
(Past)
Having those arrows going both ways in time is a problem for most people. So define it as you see fit.
Ha, I just posted something like your diagram, except yours is much better...
And the answer is a big YES. :smile:
Inside the box, you perform what is referred to as a Bell State Measurement (BSM). Some of these project Alice and Bob into an entangled state. When that happens, Alice and Bob are perfectly correlated* AS IF they were the pair originally entangled. That is called entanglement swapping.
https://arxiv.org/abs/quant-ph/0201134
https://arxiv.org/abs/0809.3991
So this is what I have been referring to in some of my prior posts. Of course, "conspiracy" theories will evolve even under these scientific challenges. However, the resulting (super)deterministic quantum theories becomes (laughably :smile: ) untenable with these scenarios. If someone were to postulate a specific way they worked, it could easily be falsified.
*Or anti-correlated, depending on the result of the BSM. Note that the BSM results are themselves random.
https://arxiv.org/abs/0809.3991*Or anti-correlated, depending on the result of the BSM. Note that the BSM results are themselves random.
Good. Then as I said, in some sense, it seems that Bell's inequality is almost unnecessary to demonstrate the impossibility of a local hidden-variables theory that could explain the correlations, since is there is no way for the entangled particles to acquire a common hidden variable.
The Hilbert space of the full system is of the form ##\mathcal H = \mathcal H_1 \otimes \mathcal H_2 \otimes \mathcal H_3 \otimes \mathcal H_4##. It can be proven mathematically that if the observables of each particles commute in spacelike separated regions (which is true in the standard model), then the reduced density matrix on ##\mathcal H_1 \otimes \mathcal H_4## is completely independent of what you do to the particles in the box (##\mathcal H_2 \otimes \mathcal H_3##). It's an easy undergrad exercise. So no physical interaction in the box can physically entangle particle 1 &4. However, what you can do is produce entangled statistics by post-selecting events based on information that is obtained from particles 2 & 3. This is what's called entanglement swapping. It's not a physical process, but rather an operation that is applied to measurement data that has already been recorded after it has been recorded.
I would dispute such characterization. No one can be sure that the Bell State measurement of 2 & 3 does not cause a change to 1 & 4. The experiment must be viewed as a total context, and identifying the causal agents when there is quantum nonlocality is not really possible. This is same kind of issue as you have with a quantum eraser. Does the eraser cause a non-local change?
My point is not to start an argument about this, but to say that causality cannot be identified clearly unless you start with a specific interpretation. And we know where interpretations will take us... :smile:
DrChinese said:
I would absolutely dispute such characterization. No one can be sure that the Bell State measurement of 2 & 3 does not cause a change to 1 & 4.
But depending on the spacetime separation, the measurements of 2&4 can be spacelike separated from the subsequent measurements of 1&4. So I can't see how there could be a local hidden-variables explanation.
I'm only saying that the experiment seems incompatible with a local realistic explanation.
Oh, I agree completely. These experiments are even stronger arguments against local realistic explanations than the original Bell types.
And just to be clear: when I say the the Bell State Measurement of 2 & 3 projects 1 & 4 into an entangled state, I don't mean that it is doing so in local realistic terms. This is strictly a quantum nonlocal description. This is the usual description given by authors of these papers. Note: You could also say that the measurement of 1 & 4 casts 2 & 3 into a Bell State.
I am having trouble coming to the same conclusion, that the experiment you cited (https://arxiv.org/abs/1508.05949) invalidates any deterministic quantum theories. Do you also mean this to invalidate deterministic quantum theories that depend on FTL (spooky action at a distance)?
I agree completely.
But there will probably be someone who holds to the superdeterministic explanation: that everything that occurs on Earth is part of the same conspiracy that makes QM look correct.
I suppose I should make the mathematics a bit more clear:
The state of the system is ##\left|\psi\right> = (\left|\psi_1\right>\otimes \left|\psi_2\right> - \left|\psi_2\right> \otimes \left|\psi_1\right>) \otimes (\left|\psi_3\right>\otimes \left|\psi_4\right> - \left|\psi_4\right> \otimes \left|\psi_3\right>)##. You can now do two things:
1. Compute the reduced density matrix in ##\mathcal H_1 \otimes \mathcal H_4## and call it ##\rho_\text{no measurement}##.
2. Perform the Bell state measurement on particles 2 & 3. In that case, you get 4 orthogonal projectors ##P_1,\ldots P_4## and thus 4 states ##\left|\xi_i\right> = P_i \left|\psi\right>##. Now you can compute the density matrix ##\rho_\text{BSM} = \sum_i \left|\xi_i\right>\left<\xi_i\right|## and again compute the reduced density matrix in ##\mathcal H_1 \otimes \mathcal H_4## and call it ##\rho_\text{measurement}##.
Of course, you have to add all the normalization constants, which I omitted for brevity. You will find that mathematically ##\rho_\text{no measurement} = \rho_\text{measurement}##. This shows that the Bell state measurement on particles 2 & 3 can not influence the physical state of the composite 1 & 4 system. Of course, this does not prevent us from performing entanglement swapping on the recorded data.
I did view the experiment in the total context. The question is: Can the actions on particles 2 & 3 have a causal influence on the physical state of the 1 & 4 system? For this to be true, the state of the 1 & 4 system must change depending on what one does to the 2 & 3 system, but it doesn't. Yes, the situation is very analogous to the quantum eraser. It's also an effect of post-selection, which can be understood from standard quantum theory. The experiment says nothing about causality. It's just yet another indication that the predictions of quantum mechanics are correct.
rubi said:
...The question is: Can the actions on particles 2 & 3 have a causal influence on the physical state of the 1 & 4 system? For this to be true, the state of the 1 & 4 system must change depending on what one does to the 2 & 3 system, but it doesn't. ... The experiment says nothing about causality. It's just yet another indication that the predictions of quantum mechanics are correct.
I agree with virtually everything you are saying. The part I think is unjustified is in bold (I added that emphasis). No one can really say. This is quantum nonlocality. There is no well-defined causal direction that we know of.
Yet to imply that post-selection means that everything evolves forward in time is tantamount to making a back-handed local realistic argument. And that I dispute. As far as anyone knows: measuring 2 & 3 as being in a Bell State does in fact project 1 & 4 non-locally into a fully entangled state. Or in the words of the second of the 2 papers I cited:
"A successful entanglement swapping procedure will result in photons 1 and 4 being entangled, although they never interacted with each other. This is done by performing a Bell-state measurement on particles 2 and 3, i.e. by projecting them on one of the four Bell states. Consequently, photons 1 and 4 will be projected onto the Bell state corresponding to the BSM outcome."
The mathematical language is not in question here. Just the interpretation... and clearly what I am saying is the same as the authors of the paper. And yet there are other acceptable causal interpretations too. But a local realistic one is NOT one of those.
Of course, you have to add all the normalization constants, which I omitted for brevity. You will find that mathematically ##\rho_\text{no measurement} = \rho_\text{measurement}##. This shows that the Bell state measurement on particles 2 & 3 can not influence the physical state of the composite 1 & 4 system. Of course, this does not prevent us from performing entanglement swapping on the recorded data.I did view the experiment in the total context. The question is: Can the actions on particles 2 & 3 have a causal influence on the physical state of the 1 & 4 system? For this to be true, the state of the 1 & 4 system must change depending on what one does to the 2 & 3 system, but it doesn't. Yes, the situation is very analogous to the quantum eraser. It's also an effect of post-selection, which can be understood from standard quantum theory. The experiment says nothing about causality. It's just yet another indication that the predictions of quantum mechanics are correct.
What about phase changes ? They are ignored in your analysis. Can the BSM affect amplitudes so that no probabilities change but a correlation is changed.
DrChinese said:
I agree completely.
Sorry to be pedantic, but what do you mean by "I agree completely"? Are you saying that the experiment (https://arxiv.org/abs/1508.05949) invalidates deterministic quantum theories that depend on FTL (spooky action at a distance)?
Of course, I'm not disputing the fact that local realism is experimentally excluded. Maybe we just have a disagreement about definitions. The state of the composite system 1 & 4 is defined to be the density matrix that contains all information about the statistics of the composite system 1 & 4. And this density matrix is unaffected. However, the state of the composite 1 & 2 & 3 & 4 system is clearly affected by the measurement on particles 2 & 3. But in order to detect this change, one needs to perform measurements on the full system. Measurements on the 1 & 4 system can't detect a change of the global state. The state of the composite 1 & 4 system meets the mathematical criterion of an unentangled state, i.e. it is described by a separable density matrix, but the state of the composite 1 & 2 & 3 & 4 system becomes (even more) entangled through the BSM.
Phase changes are also included in the analysis. Everything is contained in the projectors ##P_1,\ldots,P_4##, whose form is restricted by the commutation relations in such a way that the density matrix of the composite 1 & 4 system is unaffected.
I'm not
As far as I know, the nonlocal rule of thumb (I consider it too imprecise to count as an "interpretation") that measurement collapses the wave function is consistent with every quantum experiment performed so far.
What do you mean by "correlation"? I thought correlation was defined in terms of probabilities. So if you don't change any probabilities, you don't change the correlation.
Do you mean changes of two-particle probabilities without changing single-particle probabilities?
No, just that local realistic ones are ruled out. At this point, it is "generally" agreed that nonlocal theories such as Bohmian Mechanics are viable.
