Is Superdeterminism a Plausible Explanation for Quantum Mechanics?
87 replies · 14K views · last reply
rubi said:
Of course, I'm not disputing the fact that local realism is experimentally excluded. Maybe we just have a disagreement about definitions. The state of the composite system 1 & 4 is defined to be the density matrix that contains all information about the statistics of the composite system 1 & 4. And this density matrix is unaffected. However, the state of the composite 1 & 2 & 3 & 4 system is clearly affected by the measurement on particles 2 & 3. But in order to detect this change, one needs to perform measurements on the full system. Measurements on the 1 & 4 system can't detect a change of the global state. The state of the composite 1 & 4 system meets the mathematical criterion of an unentangled state, i.e. it is described by a separable density matrix, but the state of the composite 1 & 2 & 3 & 4 system becomes (even more) entangled through the BSM.
I don't disagree really with any of this, and I don't think you disagree with the following:
We do the BSM on 2 & 3 and see we have an entangled pair in 1 & 4. 1 & 4 have never interacted on any local realistic basic. They did not have a common origin either, and no local causal agent ever impacted the pair. Clearly, if one were trying to explain their entanglement using some desperate form of local realism: about the only thing left is to say that these entangled particles were created on the same planet and everything on the planet shares a common light cone. Of course, that explanation fails in one critical manner: why aren't any and all pairs of particles - anywhere on Earth regardless of origin - also entangled? Why just these few special ones that had the successful BSM? That is, if the "Earth as common light cone" idea is to be considered? (Obviously, that idea seems ridiculous to me. :smile: )
I am relating the above scenario to the OP article, which is constructing its premise on a flawed concept: that all entanglement arises from a common entanglement source. It doesn't, as the experiments I cited indicate.
stevendaryl said:
What do you mean by "correlation"? I thought correlation was defined in terms of probabilities. So if you don't change any probabilities, you don't change the correlation.
Do you mean changes of two-particle probabilities without changing single-particle probabilities?
I mean two particle correlations are not independent of phase. But I have to be satisfied with @rubi s answer. I'm struggling with the idea that the NV's can be entangled already before the interaction at C.
We need a clear definition of the terms here in order to agree or disagree. As I said, with the standard definition of the state of a (sub-)system that I have given (a state is defined to be a density matrix in the Hilbert space of the (sub-)system), the state of the 1 & 4 subsystem is separable (a quick calculation shows ##\rho^{1,4}_\text{measurement} = \rho^{1,4}_\text{no measurement} = \left|\psi_1\right>\left<\psi_1\right|\otimes\left|\psi_4\right>\left<\psi_4\right|##), rather than entangled, while the state of the 1 & 2 & 3 & 4 system is entangled, i.e. non-separable.
I agree with all of this.
DrChinese said:
No, just that local realistic ones are ruled out. At this point, it is "generally" agreed that nonlocal theories such as Bohmian Mechanics are viable.
Thanks for the clarification! I think I am on the same page now. :smile:
I agree and maybe it is just my misunderstanding of the term entanglement, but I don't like saying that NV's can be entangled before the interaction at C.
Look at the photon entanglement experiments and it is clear that photons 1 & 4 can be entangled either before or after the Bell State Measurement of 2 & 3. Ordering of the measurements is not significant to the results in any way. You can interpret that in several different ways.
I will interpret this by assuming that all the 'events' happen at the same time. As you say, ordering and precedence have no significance.
stevendaryl said:
If an experiment like this were possible, then it would be a way to produce entangled particles that have no common past. That would seem to be an even simpler argument against local hidden variables than Bell's theorem--the correlations can't possibly be explained in terms of local hidden variables if they never met in the past to share that hidden variable.
stevendaryl said:
Good. Then as I said, in some sense, it seems that Bell's inequality is almost unnecessary to demonstrate the impossibility of a local hidden-variables theory that could explain the correlations, since is there is no way for the entangled particles to acquire a common hidden variable.
Then I withdraw my previous suspicion about @DrChinese's assetions but I was right when I said that for these new tests hidden variables models are irrelevant rendering Bell's original arguments inaplicable
You are looking at things in reverse. Bell tests are tests of local realism (local hidden vaiables). The local realistic boundary is usually expressed as a Bell inequality. These tests have that attribute too. Certain elements are 100% identical.
However, some of these tests have been constructed specifically to address issues that some groups of "die-hard" local realists have expressed. Most of these issues are unreasonable (for reasons I won't get into here), but scientists have found ways to address them anyway and rule those issues out. That way they are not lingering in the background. The experiment of Hanson et al is indeed a Bell test, as are the entanglement swapping tests I cited. The original Bell test did indeed conceive of a single common source of entangled pairs. But that should not be seen as a restriction. There are literally hundreds (if not thousands) of Bell tests that have been performed to demonstrate limits on local realistic theories.
For some reason, you have it in your head that Bell has said something that this test invalidates or seems to contradict. That is far from the case. First, Bell said many things. That does not mean they all are to be taken as of equal weight. Second, Bell died before many key discoveries in this area were made. Bell would have loved these experiments. He would have loved GHZ and PBR, as well as the entanglement swapping I cite. All of these shed light on entanglement and the nature of reality. Which was the entire purpose of the Bell program in the first place. Consider that Bell's Theorem was not the only "no-go" theorem he came up with. He worked on others in the 60's too, they too are groundbreaking even though less well known. Such as BKS:
https://en.wikipedia.org/wiki/Kochen–Specker_theorem
https://arxiv.org/abs/quant-ph/9709047
I did not mean that. What I said is that the cases considered by Bell and EPR do not apply to these new cases of entanglement. This in no way means that this new cases invalidate what Bell and EPR have said.
I'm sick of seeing these permanent and stubborn attempts trying to recover the anthropocentric classical determinism and local realism.
It seems that most arguments pretending to recover realism and locality by refuting Bell's theorem fall mainly in two categories:
1_ Those which are simply wrong from a logical and interpretacional point of view
2_ Those resorting to very implausible arguments such as superdermism
But, even worse, know I realize that there are new experiments that were not anticipated by Bell and Einstein that seem to contradict even more strikingly the notions of reality and locality and that can not be treated with the method used by Bell in his 1964 theorem. Am I correct on this? or I misunderstood the meaning of this new experiments that seem to test entangled particles which do not share a common past causal origin which could presumably be represented by a common hidden variable λ.
Why do you think superdeterminism is implausible? It is quite easy to reject Bell's statistical independence assumption by looking at any classical field theory, like Maxwell's theory or GR or fluid mechanics. Some superdeterministic proposals may be stupid but this does not mean anything for the concept itself.
It is not that Superdeterminism is "impossible", it is just that, it is so "ad hoc" that it really explains NOTHING (and of course it predicts nothing in general, so, it is mostly useless).
And yes, I know t'Hooft is working on a Superdeterminism model of Physics, but still...
I think the correct word would be "irrelevant". "Whatever happens ... happens" is not a useful statement in science. It maybe a valid logical one, but one that everybody that wants to make science will ignore ... by design.
Actually, superdeterminism is not a theory, it's a feature of a theory. And as far as I know, there is no plausible theory that has that feature.
I agree, I feel it is similar to discussing God's existence in scientific terms
A minimalist version of superdeterminism only requires a denial of statistical independence assumption between detector settings and the spins of emitted particles. In order for this assumption to fail it is enough to show that some physical states of the detectors are incompatible with some physical states of the particle source. Take any mainstream field theory, like classical EM and write down the states. For this particular example the states will contain position and momenta of all charged particles inside the detectors and source (electrons and nuclei, or quarks if you like) as well as magnetic and electric field vectors. It is obvious that most states will not be compatible (like a net positive charge at detector A and a null electric field at the source) so the statistical independence assumption fails. Can you point out any ad-hoc assumption in the above argument?
Please see my above post. Pretty much all field theories have that feature ('t Hooft's CA interpretation is an example of a discrete field theory).
No, field theories do not have that feature. Field theories are deterministic, but not superdeterministic.
The distinction is illustrated by an EPR-type experiment. Consider the question of predicting, for an EPR-type experiment, what detector setting Alice is going to choose in the future. If Alice's choice is governed by deterministic physics, then it is predictable given her past lightcone. But I don't have access to her entire past lightcone.
Spacetime diagram of two overlapping past light cones: a large red cone labelled Alice's choice and a smaller yellow cone labelled My prediction, with a small orange overlap region at their shared base.
This is illustrated by the picture. The red region is Alice's past lightcone. The yellow region is my past lightcone. The orange region is our shared causal past. Alice's choice could depend on anything in the red region or orange region. But if I'm trying to predict Alice's choice, the only information I have is the orange region. So in general, I do not have enough information to predict Alice's choice.
So Alice's choices are not predictable by me, even if they are deterministic.
  • Spacetime diagram of two overlapping past light cones: a large red cone labelled Alice's choice and a smaller yellow cone labelled My prediction, with a small orange overlap region at their shared base.
The problem is about usefulness.
Could you (or anybody else) have predicted (based on a Superdeterminism model) the experimental results in Bell type tests (and infinitely many other possible different tests) if QM didn't exist (had we never discovered QM) ?
I have seen some papers trying to obtain KNOWN experimental results (that QM predicts correctly) based on Superdeterminism models, but every time it is "adapted" to the known result, it is never a prediction, not even a "natural" or "general" model, but it is totally conceived to just match that previous known result and nothing else.
stevendaryl said:
I'm not sure who you're talking to, but I disagree with both of these assertions. As I said, superdeterminism is a feature of a theory, it's not a theory. A superdeterministic theory might very well be testable and useful. But we don't currently have an example of one.
I actually don't think that t'Hooft's automata is a definitive example. He hasn't shown that such automata can plausibly reproduce EPR-type experiments.
I was responding to ueit, but now I am interested in your position.
Do you think we are ever going to find a Superdeterministic model that can actually predict, for example, our choices about instrumental settings?
It is not impossible in principle, but I highly doubt it.
Ummm, some messages have suddenly dissappeared, what happened?
One post was removed for a rules violation; and then the posts replying to it, including one of yours, were removed because they no longer had any context. You should have received an alert telling you this happened (if you didn't, it's because I accidentally didn't check the box to make that happen, and I apologize).
Ah, no problem, I was just curious. But...is it allowed here to talk about Superdeterminism anyway?
Yes. That's not a problem.
Is there any difference between this superdetermism and the phylosophical doctrine of fatalism or predeterminism? If not I find it hard to discuss these things in scientific terms at least for the moment. May in the future who knows. Not so long ego it was not possible to talk about the origin of the universe in scientific terms.
I highly doubt it, as well. But I don't completely dismiss the possibility. The reason I don't is because there is a sense in which superdeterminism is no weirder than the thermodynamic arrow of time. Maybe understanding the latter might change our view of what is plausible or implausible.
