Is the electromagnetic 4-vector indeed a 4-vector?
33 replies · 4K views
mbond
About the electromagnetic 4-vector ##A^\mu=(\Phi/c,\mathbf{A})##. If it is indeed a four-vector, then its squared length ##A_\mu A^\mu=\Phi^2/c^2-\mathbf{A}^2## should be a Lorentz invariant. What is the physical significance of ##\Phi^2/c^2-\mathbf{A}^2##?
Thanks for any help.
It is a four-vector. The absolute value of a potential is generally not important. The gravitational potential, for example, can be set to zero at an arbitrary point. The electromagnetic potential can be varied by a suitable gauge transformation and still represent the same EM field. So, again, the magnitude of the potential is not physically significant.
More generally, the 4-potential is only physical up to a gauge transformation ##A_\mu \to A_\mu + \partial_\mu \phi##, where ##\phi## is an arbitrary scalar field.
As others mentioned, physical effects in the classical EM theory depend only on related gauge invariant quantities. In the quantum-mechanical Aharonov-Bohm effect, this is also valid for measurable quantities, like the phase difference between the wave functions of both coherent electron beams. But the phase of the wave function of a single beam itself, which is not measurable, depends in theories, that allow only local interactions, on the electric and magnetic potentials directly.
Source (see free PDF):
https://journals.aps.org/pr/abstract/10.1103/PhysRev.115.485
via:
https://en.wikipedia.org/wiki/Aharonov–Bohm_effect
additional source:
https://web.archive.org/web/2017092...ontent.cgi?article=1118&context=physicsfacpub
Also of potential interest is the Aharonov-Bohm effect, https://en.wikipedia.org/wiki/Aharonov–Bohm_effect.
wiki said:
The Aharonov–Bohm effect, sometimes called the Ehrenberg–Siday–Aharonov–Bohm effect, is a quantum-mechanical phenomenon in which an electrically charged particle is affected by an electromagnetic potential, despite being confined to a region in which both the magnetic field and electric field E are zero.
The potential [itex]A_{\mu}[/itex] is NOT a 4-vector. The fact that we can always choose [itex]A_{0}[/itex] to be zero in ALL Lorentz frame show that [itex]A_{\mu}[/itex] cannot be a 4-vector. Indeed, there exists no 4-vector representation [itex](1/2,1/2)[/itex] for massless particle of helicity [itex]\pm 1[/itex]. Under the action of the Lorentz group, the potential transforms according to [tex]A_{\mu}(x) \to \Lambda^{\nu}{}_{\mu}A_{\nu}(\Lambda x) + \partial_{\mu} f (x , \Lambda).[/tex] This is why some people say that [itex]A_{\mu}[/itex] is a 4-vector up to a [itex]U(1)[/itex] gauge transformation. The same situation occurs in general relativity where [itex]\Gamma^{\mu}_{\nu \rho}(x)[/itex] is not a tensor. Both [itex]A_{\mu}[/itex] and [itex]\Gamma^{\mu}_{\nu \rho}(x)[/itex] are CONNECTIONS in their respective group.
We cannot associate physical meaning to [itex]A_{\mu}A^{\mu}[/itex] simply because it is NOT Lorentz invariant.
For a particular fixed gauge it is Lorentz invariant (and here I am considering gauges that fix ##A_0=0## and similar to be different if fixing that in different frames). What it is not is gauge invariant.
Gauge invariance must hold in all Lorentz frames, otherwise no physical meaning can be associated to a given quantity.
Also, the gauge-invariant Maxwell equations are Lorentz covariant provided that the connection transforms as [tex]\bar{A}^{\mu}(\bar{x}) = \Lambda^{\mu}{}_{\nu}A^{\nu}(x) + \partial^{\mu}\lambda (x, \Lambda).[/tex] In the radiation gauge [itex]A^{0} = 0, \ \partial_{j}A^{j} = 0[/itex], you can show that the gauge function is given by [tex]\lambda (x , \omega) = - \omega^{0}{}_{j} \int d^{3}y \frac{1}{4 \pi |\vec{x} - \vec{y}|} \partial_{t}A^{j}(t , \vec{y}).[/tex]
I am confused here. Surely ##A^\mu## is a vector and ##A_\mu## is a one-form?
Irrelevant to the point. Given a gauge fixing ##A_\mu## are the components of a 4-vector. When you fix the gauge by letting ##A_0 =0##, this states that the zero component of ##A## is zero in a particular frame. This is obviously not the same gauge fixing condition as applying the same kind of condition in a different frame.
In relativity this distinction is many times glossed over as the metric provides a natural mapping between the two.
I am OK with that. My confusion comes from the statement that it is not a vector.
PeterDonis said:
I don't think the OP meant "is a 1-form" by "is not a vector".
I mean the statement in post #7. May be I misunderstood it, but it seemed to me to say that ##A## is not a vector.
That subthread is more complicated, but as far as I can tell, it also did not mean "is a 1-form" by "is not a vector".
"Vector" can be a general term meaning "is an element of a vector space", rather than the more specific "has one upper index". 1-forms are elements of vector spaces just as much as (upper index) vectors are. I think post #7 is using "vector" in that more general sense.
It is not about vectors vs 1-forms. In that post it says that it is not a tensor of any kind. Just like the Christoffel symbols ##\Gamma##. They are both conections.
As I understand the subthread in question, that's because @samalkhaiat is requiring that the vector space of which ##A_\mu## would have to be an element would have to be the same regardless of gauge--which condition cannot be satisfied for ##A_\mu## alone, you have to include the extra term ##\partial_\mu \lambda## that appears as soon as you change gauge.
Whereas @Orodruin is allowing the vector space of which ##A_\mu## is an element to change when you change gauges--so once you've picked a gauge, ##A_\mu## by itself, in that gauge, is a vector. But in a different gauge, the ##A_\mu## in that gauge would be an element of a different vector space; it's not "the same vector".
PeterDonis said:
Whereas @Orodruin is allowing the vector space of which Aμ is an element to change when you change gauges--so once you've picked a gauge, Aμ by itself, in that gauge, is a vector. But in a different gauge, the Aμ in that gauge would be an element of a different vector space; it's not "the same vector".
My point was that ##A^\mu A_\mu##, given that the gauge is fully fixed, is a Lorentz scalar and therefore Lorentz invariant contrary to the statement in #7 that it is not. The reason it cannot be assigned physical relevance is that it is not gauge invariant.
The potential with index up is not a contravariant Lorentz vector because it does not transform like [itex]A^{\mu} \to \Lambda^{\mu}{}_{\nu}A^{\nu}[/itex]. And the potential with index down (i.e., the components of the connection 1-form) is not a covariant Lorentz vector because it does not transform like [itex]A_{\mu} \to (\Lambda^{-1})^{\nu}{}_{\mu}A_{\nu}[/itex].
This is nonsense. Given a gauge fixing, it transforms exactly like that under Lorentz transformations.
These statements seem to contradict each other. Either one is wrong, or there is a missing piece somewhere. And the discussion of this in general is probably "A" level and hence is probably too much for an "I" level thread. Is there an "I" level resolution?
It is the point, [itex]A_{\mu}A^{\mu}[/itex] is not physically meaningful quantity because it is neither gauge nor Lorentz invariant.
I don’t know what you mean by those words. Can you translate your words to mathematical expressions so that I can understand them.
I suggest you read Weinberg QFT Vol 1 book. The second paragraph on page 251, he concludes: “The fact that [itex]a^{0}[/itex] vanishes in all Lorentz frames shows vividly that [itex]a^{\mu}[/itex] cannot be a four-vector. Instead, …… , so that under a general Lorentz transformation [tex]U(\Lambda)a_{\mu}(x)U^{-1}(\Lambda) = \Lambda^{\nu}{}_{\mu}a_{\nu}(\Lambda x) + \partial_{\mu}\Omega (x, \Lambda), \ \ \ \ \ (5.9.31)[/tex] ……” At the bottom of the same page he writes: “… [tex]f_{\mu\nu} = \partial_{\mu}a_{\nu} - \partial_{\nu}a_{\mu} . \ \ \ \ \ (5.9.34)[/tex]Note that this is a tensor even though [itex]a^{\mu}[/itex] is not a four-vector, because the extra term in Eq.(5.9.31) drops out in Eq.(5.9.34).”
You may also need to see the explanation in Bjorken and Drell, Vol 2, page 74 and problem 2 on page 81, which I posted the solution on these forums many years ago.
Look, the reason that QED is gauge and (formally) Lorentz invariant is down to the fact that we couple the potential [itex]A_{\mu}[/itex] to a conserved 4-vector current [itex]j^{\mu}[/itex].
In other words, if I fix the gauge in a particular frame by setting ##A_0 = 0## in that frame, and then I do a Lorentz transformation to a different frame (without changing gauge), I will not have ##A_0 = 0## in the new frame, correct? So "choosing a gauge", at least in this case, presupposes that I have also chosen a particular frame.
I say "at least in this case" because there is another choice of gauge, ##\partial_\mu A^\mu = 0##, which would appear to be preserved by a Lorentz transformation, so if I make that gauge choice I don't have to choose any particular frame.
But ##A^0## does not vanish in all frames if you have a fixed gauge condition. If you choose to also impose ##A'^0 = 0## as you make a Lorentz transformation, then you have done a Lorentz transformation and a gauge transformation. You are choosing to impose a gauge depending on your frame rather than imposing your gauge condition in a Lorentz invariant manner, i.e., ##U \cdot A = 0## with ##U## being ##(1,0,0,0)## in some given frame.
Perhaps it is an issue of what each of us consider the "Lorentz transformed" ##A##, which boils down to what gauge condition is applied. When you say ##A^0 = 0## I would primarily take that to refer to a single frame only. "The same" gauge in another frame would instead be ##U\cdot A = 0## with ##U## being the 4-velocity of the original frame. The alternative is imposing (somewhat artificially in my meaning) that ##A^0## in all frames. To me that is mixing the gauge and Lorentz transformations, but if that is what you want to do ...
Yes. You can, of course, make an additional gauge transformation such that ##A_0 = 0## in the new frame along with your Lorentz transformation if that is your wish, but to me that is artificially imposing a gauge condition that is explicitly Lorentz violating. Then we should not be surprised that the resulting ##A## does not transform as a 4-vector as the gauge condition itself is where the Lorentz violation appears.
Edit: The Lorentz transformed ##A_\mu## is, of course, also a valid 4-potential. It is just not in a gauge where ##A_0 = 0## in the new frame. It is in a gauge where ##U\cdot A = 0## (in all frames) with ##U## being the 4-velocity of the original frame.
On page 250 in the chapter "5.9 Massless Particle Fields", Weinberg called the ##a_\mu(x)## a "polarization vector":
Weinberg said:
Let's temporarily close our eyes to this difficulty, and go ahead anyway, using ... to define a polarization vector for arbitrary momentum, and take the field as ##a_\mu(x) = ## ...
On page 251, before the sentence you quoted, he wrote:
Weinberg said:
As we shall see in Chapter 9, these are conditions satisfied by the vacuum vector potential of electrodynamics in what is called Coulomb or radiation gauge.
At this stage in the text, he did not yet call ##a_\mu(x)## a vector potential. Then he solved the earlier mentioned difficulty by replacing the earlier used equation (5.9.6) by equation (5.9.30).
PeterDonis said:
Why not?
The mathematical details is given on the pages 248 and 249 of Weinberg text. The math is easy if you are familiar with the technics of “little group”. If you are not, then observe the following problem: Consider the propagator of the massive vector field representation [itex](1/2,1/2)[/itex] (which is a true Lorentz vector) [tex]\Delta_{\mu\nu}(x,y) \sim \int d^{4}x \ e^{ip(x - y)} \frac{\eta_{\mu\nu} + p_{\mu}p_{\nu}/m^{2}}{p^{2}+ m^{2} - i \epsilon} .[/tex] Since this propagator has singularities at [itex]m = 0[/itex], we cannot obtain the theory of massless field of helicity [itex]\pm 1[/itex] by simply taking the limit [itex]m \to 0[/itex] of the theory of massive vector field of spin 1. Therefore, the massless field of helicity [itex]\pm 1[/itex] cannot be described by a true Lorentz vector.
Weinberg constructs the field [itex]a_{\mu}(x)[/itex] from the polarization “vector” [itex]e_{\mu}(\vec{p}, \sigma)[/itex] and the annihilation and creation operators. Since the little group technics, he uses, is simpler to apply directly to the polarization vector, he derives the properties of the field [itex]a_{\mu}[/itex] from those of the polarization vector [itex]e_{\mu}(\vec{p}, \sigma)[/itex].
In section (5.9) of the book, Weinberg tries to answer the following equivalent questions: Can massless field of helicity [itex]\pm 1[/itex] be described by a true Lorentz vector? Does the field [itex]a_{\mu}(x)[/itex] transform like [itex]a^{\mu} \to \Lambda^{\mu}{}_{\nu}a^{\nu}[/itex]? Or, can the series of massless representations of the Lorentz group contain a true Lorentz vector? His answer was negative: “We have thus come to the conclusion that no four-vector field can be constructed from the annihilation and creation operators for a particle of mass zero and helicity [itex]\pm 1[/itex]” He then realized that the best one can do is to take the Lorentz transformation of polarization “vector” to be of the form [tex]e^{\mu}(\vec{p}_{\Lambda}, \pm 1 ) e^{\pm i \theta (\vec{p}, \Lambda)} = D^{\mu}{}_{\nu}(\Lambda) e^{\mu}(\vec{p}, \pm 1) + p^{\mu} \Omega_{\pm} (\vec{p}, \Lambda). \ \ (5.9.30)[/tex] When translated to the field [itex]a_{\mu}(x)[/itex], Eq(5.9.30) becomes [tex]U(\Lambda)a_{\mu}(x)U^{-1}(\Lambda) = \Lambda^{\nu}{}_{\mu}a_{\nu}(\Lambda x) + \partial_{\mu}\Omega (x, \Lambda). \ \ \ (5.9.31)[/tex] The presence of the second term makes the field [itex]a_{\mu}(x)[/itex] to be a gauge 4-potential instead of a true Lorentz 4-vector.
