Is the influence of dark matter symmetric?
The discussion centers on the symmetry of dark matter's influence within galaxies, particularly its gravitational effects. It is established that dark matter does not interact with normal matter except gravitationally, leading to a higher density in the dark matter halo compared to the galaxy's center. The asymmetry observed in galaxy shapes is attributed to their rotation rather than a property of dark matter itself. Therefore, the distribution of dark matter is influenced by its unique interaction characteristics, resulting in a non-uniform presence across different regions of a galaxy.
  • Understanding of gravitational interactions in astrophysics
  • Familiarity with the concept of dark matter and its properties
  • Knowledge of galaxy formation and structure
  • Basic principles of rotational dynamics in celestial bodies
  • Research the properties of dark matter and its gravitational effects
  • Study galaxy rotation and its impact on galaxy shape
  • Explore the differences between dark matter and normal matter interactions
  • Investigate the formation and characteristics of dark matter halos
Astronomers, astrophysicists, and students of cosmology interested in understanding the role of dark matter in galaxy formation and structure.
nortonian
I am more familiar with quantum physics than cosmology so it occurred to me that I hadn't heard anyone talk about the question of symmetry with respect to dark matter. If its influence is restricted to the disc of a galaxy, but it is particle-like in structure than symmetry is violated isn't it? In other words, it exhibits gravitational attraction but not radially like ordinary matter.
Space news on Phys.org
Its density is larger in the disc of a galaxy (at least, in some cases--in others I believe the dark matter "halo" around a galaxy is much more spherical than the galaxy itself is), but that doesn't make the gravity of any particular piece of dark matter asymmetrical, any more than the fact that the ordinary matter of a galaxy lies in a disc makes the gravity of ordinary matter asymmetrical.
So apparently the disc-like structure of a typical galaxy is not explained by a property of dark matter and there is no reason, theoretically speaking, for the predominant presence of dark matter in one particular area as opposed to another any more than there is for ordinary matter. If the asymmetry of the galaxy, when it is not spherically shaped that is, is due to something other than dark matter can it be explained by something else?
Yes, rotation. Galaxies that are flattened are flattened because they are rotating. There are also galaxies that are much more spherical, because they are not rotating, or are doing so very slowly, comparatively speaking.
nortonian said:
... there is no reason, theoretically speaking, for the predominant presence of dark matter in one particular area as opposed to another any more than there is for ordinary matter.
Not true at all. What you are missing is the ramifications of the fact that dark matter does not interact with anything except gravitationally. What this means is that a given particle of dark matter will travel from the halo in through the center of the galaxy, drawn there by gravity, but since it doesn't interact with anything, it just keeps going, slowing down slowly until it gets to the other side of the halo. Its speed is greatest at the center of the galaxy and lowest at the outer edges of the halo. That means that it spends far more time in the halo than in towards the center. Take it that all the particles do that and you have a distribution that has higher density in the halo than in the center.
Normal matter, of course, would not act that way because even with the vast distances between object involved, it is at least somewhat likely to smack into something during the trips back and forth so you would not get (and in fact do not get) a normal matter halo around galaxies in the same way that you do for dark matter.
  • Featured
  • · Replies 19 ·
  • · Replies 20 ·
