Is the integral of a non-negative function always positive?
  • Level: Undergrad
  • Thread starter Thread starter jenga42
    Inequality
6 replies · 4K views
jenga42
Hello,
I'm trying to figure out if this is true - any help would be greatly appreciated!
If a(x) < b(x) between the values x_i and x_f then is the following also true?...
int_{x_i}^{x_f} dx f(x) a(x) < int_{x_i}^{x_f} dx f(x) b(x)
where f(x)>0 for all x.
...I think it is true, but I'd like to be able to prove it!
Thanks,
Jenny
Your notation is a bit awkward. Are f(x)a(x) and f(x)b(x) the integrands?
If f is continuous (you will definitely need that, I think) and the interval is finite, then you could probably estimate it by its maximum and do a series of inequalities like
[tex]| \int_a^b f(x) p(x) dx | < | f(x) p(x) (b - a) | < \cdots[/tex]
Or you could try considering
[tex]\int_a^b f(x) (p(x) - q(x) )[/tex]
and showing that it is positive (for q(x) < p(x) everywhere).
You don't need continuity or anything of the sort -- the integral is monotone. That is, if h and k are integrable on [a,b], and h(x)<=k(x) for all x in [a,b], then
[tex]\int_a^b h(x) dx \leq \int_a^b k(x) dx.[/tex]
Edit: Oh. Maybe that's what you were saying here:
Hi,
Thanks for replying! I didn't know I could type the equations!
Just to clarify, I meant if a(x)<b(x), can I say
[tex]\int_{x_i}^{x_f} f(x) a(x) dx < \int_{x_i}^{x_f} f(x) b(x) dx[/tex]
where f(x)>0.
I'd like to know if there is a general theorem for this to be true? ...I think that (please correct me if I'm wrong!) I could only use
for a specific f(x).
What does "the integral is monotone" mean?
Thanks!
I've just had a thought, can I just say that as f(x)>0, then it cannot change the direction of the inequality, hence if a(x)<b(x) , then multiplying both sides by f(x), we find f(x)a(x)<f(x)b(x) and therefore
[tex]\int_{x_i}^{x_f} f(x)a(x) dx < \int_{x_i}^{x_f} f(x)b(x) dx[/tex]
This is assuming that if a(x)<b(x), then
[tex]\int_{x_i}^{x_f} a(x) dx < \int_{x_i}^{x_f} b(x) dx[/tex]
But I don't understand why this second equation is true - I've tried looking up monotone functions, but haven't found anything useful!
Thanks
That's perfect. (But you should be using [itex]\leq[/itex] instead of [itex]<[/itex].)
This should be straightforward to prove if you just use the definition of the integral. To make it even easier, you can prove the following:
If c(x) is integrable on [x_i, x_f] and if c(x)>=0 for all x in [x_i, x_f], then
[tex]\int_{x_i}^{x_f} c(x) \geq 0.[/tex]
[Once you do this, you can put c(x)=b(x)-a(x) to get the result you want.]
