Is the Limit as it Approaches 0 Always Infinity?
  • Level: Undergrad
  • Thread starter Thread starter Tekneek
    Limit
11 replies · 2K views · last reply
Tekneek
Why is the limit not just infinity?
Printed limit expression: lim as s approaches 0 of (1 - 1/s) / (1 + 10(2s+4)/(7s(s+5))) = -0.8750
wouldn't it be (1-infinity)/(1+infinity)?
Why should "-infinity/infinity" be infinity?
What is the limit of
$$\lim_{s \to 0} \frac{\frac{-1}{2}}{\frac{2}{s}}$$?
-s/4, if s =0 then
Would't the limit be zero?
Sorry typo, this is the formula I meant:
$$\lim_{s \to 0} \frac{\frac{-1}{s}}{\frac{2}{s}}$$
But the more important part was the first question.
For that formula it would be -1/2. I was thinking it would be infinity because you really can't put down a number with it unless maybe it is 1?
EDIT: Nvm go it. It ends up being -35/40. Thnx
That is not the point. It follows the "-infinity/infinity" type. It is easy to simplify it here to see the limit is not infinity, so your original idea cannot work - that was the purpose of the example.
I don't understand that question.
Okay.
Limit expression: lim s→0 of (1 - 1/s) / (1 + 10(2s+4)/(7s(s+5))) = -0.8750
Whenever you write "infinity", you should write "a large number".
In this form (1 - a large number)/(1 + another large number) could be any negative number. It could be large and negative or it could be small and negative.
A very important property of limits, not emphasized enough as I think it should be, is that "If f(x)= g(x) for all x except x= a, then [itex]\lim_{x\to a} f(x)= \lim_{x\to a} g(x)[/itex].
With this particular problem, we can, as long as n is not 0, multiply both numerator and denominator by n. That gives you [tex]\frac{s- 1}{s+ \frac{s+ 4}{7(s+ 5)}}[/tex]. Now, take s= 0.
The limit is of (s-1)/(s+(10*(2s+4)/7(s+5) that doing s=0 result in -7/15
No, check your algebra. The answer in post #1 (-7/8) is correct.
