Is the Quantum/Classical Boundary the most important question in Physics?
135 replies · 14K views
DarMM said:
It's the proof given in Chapter 7 of Omnès's text as I mentioned before. Whereby the interference observables for a real device would require a second device with at least ##\mathcal{O}\left(10^{10^{18}}\right)## atoms. Thus such observables do not belong to the observable algebra due to both the actual limit of material in the universe and relativistic reasons, e.g. under General Relativity are so large as to collapse in on themselves and under Special Relativity are too large to operate on the time scales required.
Again Chapter 7 of Omnès's book or Chapter 4 of Streater's Lost Causes (only noticed there that he cites you in that book!)
Which part of Chapter 7? Does it require that one adopt the Consistent Histories interpretation?
atyy said:
As far as I can tell, that is the same as saying that every application of quantum mechanics has a classical-quantum cut. Frame selector = classical apparatus.
The thing is I'm not really sure what is "classical" about it. In an application of QM you need more information for a well posed statistical problem than in classical probability theory. However I'm not sure how this prevents anything from being described by QM.
That's what I don't understand, what prevents a quantum treatment. Give me a system to which QM cannot be applied.
All of Chapter 7 really. It also requires some lemmas and results from Chapter 6.
Omnès describes a form of Copenhagen in the book, but the argument doesn't require it.
The term "classical" is just traditional language (Landau & Lifshitz). If you don't like it, you can call it the observer or the measurement apparatus. Whatever it is, the Born rule applies when there is a measurement, but QM itself does not say when a measurement occurs. This is just the traditional measurement problem. The topic of this thread really only makes sense as asking "Is there a measurement problem?"
So my take is that both of these mean the same thing:
Q: Is there a measurement problem. A: Yes
Q: Is there a classical-quantum cut. A: Yes
Well, the quantum treatment itself must leave the observer out. So QM cannot apply to the observer. For example, can you apply QM to yourself (your whole self)?
This is of little weight in the present context since limitations of the existing universe affect just one particular state, whereas a superselection rule is a property of states in general.
Quantum Alchemy said:
Is there any more important question in Physics than this one? [Quantum/Classical Boundary]
Very easy. The most important question in physics is why we don't have hoverboards yet. I'm tired of carrying supplies from stores to my home, and a hoverboard would make my life so much easier. :smile:
Seriously, though...
phinds said:
Personally, I think the most important question is why QM and GR don't play well together. Clearly one or the other or both need modification and so far no one has been able to do it.
I also think that is one of the most important questions. And thus, how QM works in (or together with) a dynamic GR spacetime. And then also what the implications of this are for the interior of black holes.
I would like to mention another problem which I personally find deeply interesting, and that is the cosmological constant problem (see e.g. http://aapt.scitation.org/doi/10.1119/1.17850).
And connected to this is also the question of dark energy and the accelerated expansion of the Universe.
Edit: I'd also like to add that I personally understand the cosmological constant problem only on a basic level; I don't have deep enough knowledge about QFT and GR. But I still find it absolutely fascinating.
What do you mean?
Superselection rules are properties of the observable algebra not states. In fact isn't that the point, that there is more to the physics than just the looking at the states alone can tell you due to restrictions on the observable algebra. If you see Streater's book he calls this a superselection rule.
I also don't understand what you mean by "limitations...affecting one particular state".
I said this back in my original post where I said QM tells us neither which event occurs nor the set from it is drawn and that in an experiment we select the Boolean frame with that choice lying outside the theory.
That's why I'm confused, what's the point you're disagreeing with.
In one application the system that constitutes the selection of the Boolean frame is not given a quantum states. It is mathematically represented by a selection of a Boolean subalgebra, not a statistical operator/density matrix.
However in another application it can be given a quantum state. Thus there is nothing which cannot be treated by QM.
None that I'm aware of. I thought this was clarified many posts back. Basically, there is no disagreement, but for the purposes of this thread it is important that while in one sense, perhaps everything is quantum, in another sense, not everything is quantum. So just trying to use language that is clear.
And can you describe yourself with quantum mechanics?
From my perspective using Landau and Lifshitz style language is more unclear, even though it has historical precedent. People will take the "cut" to represent some division in systems to which QM applies and it's hard to point to aspects of the formalism itself that represent this "cut".
Where as quantum probability lacking a selection mechanism for both the event and the sample space from which it is drawn is directly related to the formalism and reflects Kochen-Specker contextuality and doesn't leave the idea that (the macro dofs of) a stone is outside quantum theory.
As a matter of practice no, just like any complex macroscopic system such as our devices.
However there is nothing in the formalism forbidding describing me in principal.
Unless this is some kind of question about consciousness.
Do you believe that there is a measurement problem in quantum mechanics?
People mean many things by that phrase, some split it into two or three separate problems that they then call "small" or "big" and sometimes different groups can mean the same thing but one group views it as a problem and the other views it simply as the way things are, i.e. a property of the theory.
So it depends on what you mean.
DarMM said:
What do you mean?
Statements about ''the actual limit of material in the universe'' are properties of the state, not the observable algebra. The empty universe and our universe are different states with vastly different amount of material.
On the level of the observable algebra, superselection rules are related to the center of the algebra, and the center does not seem to have any relation to decoherence, as far as I know. That's why I queried you for more information.
The environment induced superselection rules are heavily state-dependent and strictly speaking do not deserve their name.
The "cut" doesn't even need to be brought up when talking about Copenhagen, because Copenhagen doesn't deal with it. Yes, it's mystical that apparently we could make the "cut" appear anywhere in the measurement process, and we get the same results. That's because no where in the formalism does it tell us where to break off, where does the measurement *actually* occur. Apparently, at some point, a break from this quantum system occurs, and a classical outcome becomes reality. So, Copenhagen isn't the interpretation to look at if you care about that. Or in the words of Robert Georch...
Robert Georch said:
But, in any case, no difficulty arises from the failure of the Copenhagen interpretation, in the first experiment, to specify whether the geiger counter was “classical” or “quantum”. The claim of the interpretation is just that:
if you specify to it with sufficient precision what you will do in making a measurement, it will tell you the probability distribution for the results of the measurement.
It does precisely this in every case. It does not have to deal with what “really happens”. It is, in some sense, “consistent”
Superselection rules are often defined by the statement that for two sets of states ##S_A## and ##S_B## say, then there is no element of the observable algebra ##\mathcal{A}## that connects these two sets. That's what is going on here. Why is this not a superselection rule then?
Because decoherence does not prove this for environment induced superselection rules. At least I haven't seen such a proof, did you?
It shows that the required self-adjoint operator involves systems of ##\mathcal{O}\left(10^{10^{18}}\right)## particles that would have to violate relativity. These don't exist clearly, so this self-adjoint operator isn't an element of the observable algebra.
DarMM said:
It shows that the required self-adjoint operator involves systems of ##\mathcal{O}\left(10^{10^{18}}\right)## particles. These don't exist clearly, so this self-adjoint operator isn't an element of the observable algebra.
These don't exist only in a particular state - namely the Heisenberg state specifying our universe. But the observable algebra allows many states in which these exist!
It does? The states also require a violation of relativity. How could the observable algebra allow them?
DarMM said:
It does?
Yes. A free QFT allows states with arbitrarily many particles.
This is a different statement, which I do not believe since decoherence is usually discussed in a strictly nonrelativistic framework.
Where precisely is this proved? Page numbers please.
atyy said:
But in every application there is a cut, so one could just as well say that everything requires a classical treatment. Basically, there is a classical-quantum cut, the topic of this thread.
Where in the description of the Stern-Gerlach experiment and its outcome is the necessity for a cut? You can describe it pretty easily completely by solving the Schrödinger equation for a particle in an inhomogeneous magnetic field of the appropriate kind.
The magnetic field and the detector are described in classical terms.
Just to be clear, this is definition of superselection rules given by Wightman in "Superselection Rules: Old and New":
We shall say that a superselection rule operates between subspaces if there are neither spontaneous transitions between their state vectors (i.e. if a selection rule operates between them) and if, in addition to this, there are no measurable quantities with finite matrix elements between their state sectors
In the same paper Wightman also refers to "Superselection rules induced by the environment". So it seems to be considered valid by both Streater and Wightman that there can be superselection rules induced by the environment. Can you perhaps say where they are wrong with this?
I don't understand how this is relevant.
Omnes discusses it on p.269 of his book. He doesn't give it in full detail, but it is easy enough to spell out.
An object of ##10^{10^{18}}## particles would need to be at least several quadrillion light years to not collapse in on itself. At this size it cannot operate fast enough (due to the speed of light) to have full reversible control of the first device, whose thermal fluctuations and so on operate on much smaller time scales.
But does this imply a classical treatment is required? Omnes states that empirical data are 'best expressed in classical terms' but he still associates them with a quantum mechanical description of the detector.
DarMM said:
However sometimes a state of the form:
$$|\psi\rangle = \frac{1}{\sqrt{2}}\left(|a\rangle + |b\rangle\right)$$​
simply represents classical "ignorance" based probability. Such as when |a⟩|a⟩ and |b⟩|b⟩ belong to different superselection sectors.
If [itex]|a \rangle[/itex] and [itex]|b \rangle[/itex] belong to different superselection sectors, doesn't your definition in post #82 imply that [itex]|\psi \rangle[/itex] can't be prepared in the first place?
kith said:
If [itex]|a \rangle[/itex] and [itex]|b \rangle[/itex] belong to different superselection sectors, doesn't your definition in post #84 imply that [itex]|\psi \rangle[/itex] can't be prepared in the first place?
Mixed states can be prepared. Post #84 isn't mine, obviously this is just a minor typo, which one of my posts are you referring to?
Yes but then why did you write down a ket?
I meant post #82 (Thanks, I edited my last post) where you gave the definition of superselection rules.
It's still a vector state, i.e. it is a sum in the Hilbert space of two pure states. It's just that sometimes kets are actually mixed states. That's the "interesting" part about superselection rules.
Usually a pure state is defined as being represented by a projector, i.e., obeying ##\hat{\rho}^2=\hat{\rho}##, i.e., there's a normalized vector, defined up to a phase factor, with ##\hat{\rho}=|\psi \rangle \langle \psi|##. There's a one-to-one mapping between Hilbert-space vectors modulo a phase (rays) and the pure states.
In which sense can kets represent mixed states and what has it to do with superselection rules? Don't superselection rules simply say that certain superpositions cannot describe perparable (pure) states? E.g., usually one argues that one cannot have the superposition of states with half-integer and integer spin, because rotations by angles ##2 \pi## should be a symmetry?
The cut is between what you as the user of quantum mechanics consider to be the quantum system and everything else (including the measurement apparatus and yourself).
In a simple description of the Stern-Gerlach experiment, you cut between the spin degree of freedom and everything else. So your quantum mechanical system is a simple two-level system.
In the more sophisticated version you refer to above, you move the cut behind the magnets. So your quantum mechanical system consists of a spin-1/2 particle and the magnet[itex]^1[/itex]. Note that the measurement result gets recorded only when part the quantum system interacts with the screen. This is why in this description, the screen alone constitutes the external measurement apparatus which isn't included in the quantum description.
Can the cut be shifted further? In principle, sure. If you start your experiment, isolate and leave the lab, you could take the spin-1/2 particle, the SG apparatus and the whole lab to be the quantum system which evolves unitarily until you break the isolation by opening the lab door.
Is there a limit how far you can shift the cut even in principle? Yes. If you are doing experiments, you can't include yourself in the description of these experiments.
______
[itex]^1[/itex] Actually, a semiclassical approximation is used, so the magnet isn't treated completely quantum mechanically.
