Is the Quantum/Classical Boundary the most important question in Physics?
135 replies · 13K views
Elias1960 said:
Sorry, but this makes no sense. Kets are pure states. Point. For a mathematician, the only reasonable reaction to an attempt to name them mixed states is a facepalm.
Nobody is naming kets as mixed states. Mixed states can be represented as vector states, such as via the GNS construction. That's a mathematical fact.
You basically don't accept the whole area of quantum probability or its nomenclature, so you're simply never going to accept any of this. All I can say is that most experts do. The work of Huzhiro Araki and others in defining a representation independent notion of pure and mixed states and entropy might be a "face palm" for you and the definition of pure and mixed state in rigorous QM and quantum information might be dumb to you. However there is little I can say on that point.
Ok, nobody has written this (emphasis mine):
DarMM said:
An example being the case of superselection sectors where indeed a state such as:
$$|\psi\rangle = \frac{1}{\sqrt{2}}\left(|a\rangle + |b\rangle\right)$$
with ##|a\rangle## and ##|b\rangle## being elements of different superselection sectors. This is actually a mixed state, ...
Already better, but also sloppy language. The GNS construction is a larger space, the mixed states are projections into a smaller space. Ok, I'm not a native speaker, but "represented as" sounds problematic and misleading to me, "represented using a" or "represented by" would be ok. Because the "represented as" suggests some map object ##\to## representation, while "represented using a" suggests representation ##\to## object.
Again, just to clarify, I do not object against the mathematics, I have objections here against the misleading language used.
Yes that state is a mixed state. However that's not the same as saying vector states and mixed states are the same thing. Just in this case a mixed state is being represented as a vector state.
I don't see how. In the GNS construction a mixed state is represented as a vector state.
I don't get this "as/using a/by" thing. "Represented as" is a fairly common phrase.
An old colleague who was reading this thread has kindly pointed out to me that the literature has seven (!) different definitions of a superselection rule, with some equivalent, others stronger/weaker. I'll do a bit of reading and report back hopefully if I emerge from the morass! :smile:
I have to give up. There seems to be no chance. Possibly a culture thing: Mathematicians are taught to care even about minor differences, and assuming such a cultural background among physicists seems wrong.
Plenty of mathematicians write "represented as". I can give you some examples. I just don't think the difference between the English phrases "represented as" or "represented using a" are what you are claiming since nobody else seems to comment on or adhere to your distinction.
I don't really think this is a physicist vs mathematician cultural distinction, just that English isn't as fine grained as you are imagining here.
I'm not sure I see the controversy. I don't normally work with these kinds of equations but:
We have the ket ##|\psi\rangle = \frac{1}{\sqrt{2}}|a\rangle+\frac{1}{\sqrt{2}}|b\rangle## mentioned previously. Thus, we have a quantum state ##\omega_\psi## such that
$$\omega_\psi(A) = \frac{1}{2}\omega_a(A)+\frac{1}{2}\omega_b(A)+ \frac{1}{2}\langle a,Ab\rangle+\frac{1}{2}\langle b,Aa\rangle$$
for all observables ##A##. If ##|a\rangle## and ##|b\rangle## are subject to superselection rules such that ##\langle a,Ab\rangle = \langle b,Aa\rangle = 0## for all observables ##A##, then the above reduces to the mixed state
$$\omega_\psi(A) = \frac{1}{2}\omega_a(A)+\frac{1}{2}\omega_b(A)$$
But ##\omega_\psi## is still a vector state, since ##\psi\in\mathcal{H},||\psi||=1##.
Are you perhaps discriminiating ##|\psi\rangle## from ##\omega_\psi##?
[edit] - made notation more consistent
Yes. This is my point, they are different but indistinguishable because we can distinguish them only if we have operators which we don't have because of the superselection rule. The superselection rule reduces our ability to construct resp. identify by measurement particular states. But such restriction of human abilities to distinguish different objects does not make them identical.
Well the typical terminology in the most general applications of quantum theory, such as in algebraic field theory and quantum information, is that ##|\psi\rangle## is a vector state which represents ##\omega_{\psi}##. However it is to ##\omega_{\psi}## that the mixed/pure distinction refers, since regardless of the representation ##\omega## has finite entropy and all the other characteristics of a mixed state. Thus it is a mixed state represented by a vector state in this particular representation.
DarMM said:
A mixed state may be a vector state in the GNS Hilbert space, but not a pure state.
Secondly a sum of kets is not a pure state precisely in the case where both belong to different superselection sectors. Unless you are have a certain precise definition of Hilbert space in mind.
A. Neumaier said:
A vector state in the GNS Hilbert space is a pure state in the Hilbert space sense, but not in the ##C^*## algebra sense.
It is a pure state in the Hilbert space defined by the direct sum of the superselection sectors. What I don't understand is in which sense it can be a mixed state.
DarMM said:
Pure and Mixed refer to a state's entropy though. Thus a state is pure if it has vanishing entropy.
In many (most) cases of course we represent pure states with vector states. Thus the two are often, but not always, the same.
It's a vector state, not a pure state as its entropy does not vanish.
vanhees71 said:
It thought in a model with superselection rules the above superposition is simply not describing a physical preparable state. If it were preparable mathematically it'd by definition represent a pure state (or rather in the usual sense of ##\hat{\rho}=|\psi \rangle \langle \psi|## representing this pure state to be pedantic).
Morbert said:
We have the ket ##|\psi\rangle = \frac{1}{\sqrt{2}}|a\rangle+\frac{1}{\sqrt{2}}|b\rangle## mentioned previously. Thus, we have a quantum state ##\omega_\psi## such that $$\omega_\psi(A) = \frac{1}{2}\omega_a(A)+\frac{1}{2}\omega_b(A)+ \frac{1}{2}\langle a,Ab\rangle+\frac{1}{2}\langle b,Aa\rangle$$ for all observables ##A##. If ##|a\rangle## and ##|b\rangle## are subject to superselection rules such that ##\langle a,Ab\rangle = \langle b,Aa\rangle = 0## for all observables ##A##, then the above reduces to the mixed state $$\omega_\psi(A) = \frac{1}{2}\omega_a(A)+\frac{1}{2}\omega_b(A)$$ But ##\omega_\psi## is still a vector state, since ##\psi\in\mathcal{H},||\psi||=1##.
The misunderstandings in this thread related to the above are due to the fact that the notion of a state and the distinction between pure and mixed states are both ambiguous because both depend on the algebra on which they are considered. That's why we have been talking past each other.
A good open source general discussion is in Section 6.3 of the paper
The essence is here:
In standard quantum physics (i.e., that not using the ##C^*## algebra terminology), a state is a density operator (i.e., a Hermitian positive semidefinite trace 1 operator) ##\rho## on a Hilbert space ##H##, and it is pure when it has rank one and mixed otherwise. In the pure case (only) it can be represented by a state vector ##\psi## as ##\rho=\psi\psi^*##, uniquely up to a phase. Hence state vectors always represent pure states.
On the other hand, algebraic quantum physics uses the ##C^*## algebra terminology. There a state is a positive linear functional ##\omega## on a ##C^*## algebra ##A## (called the observable algebra) satisfying ##\omega(1)=1##, and the state is pure iff it is not decomposable into a convex combination of two different states. This is a generalization of the notion from standard quantum physics, which is the special case where the observable algebra is the algebra ##B(H)## of bounded linear operators on a Hilbert space ##H## and the density operator ##\rho## is identified with the positive linear functional ##\omega## defined by $$\omega(A):=Tr~ \rho A.~~~~~~~~(1)$$ This defines a 1-1 correspondence, making the identification possible. With this identification the notion of pure and mixed states agree.
One says that there are superselection rules when the observable algebra has a center consisting not only of the multiples of the identity. When working in a fixed Hilbert space this implies that ##A## is a proper *-subalgebra of ##B(H)##. In this case, (1) no longer defines a 1-1 correspondence between density operators and positive linear functionals, and the notions both of state and of the pure/mixed distinction differ algebraically.
This is easiest to see if one takes the Hilbert space as ##C^n## and the observable algebra to be the algebra of diagonal matrices. Then ##\omega(A)=\omega(Diag(A))##, where ##Diag(A)## is the matrix obtained from ##A## by setting the off-diagonal elements to zero. The pure states are now only those whose density matrix have a single 1 and otherwise zeros on the diagonal. In particular, most pure states become mixed.
The nonuniqueness also implies that the Schrödinger equation becomes meaningless; only the von Neumann equation for the dynamics of the density operator remains meaningful, and only for Hamiltonians belonging to the observable algebra. In particular, this dynamics does not lead outside of a superselection sector; if the initial state is pure (and hence belongs to a single superselection sector, as it is often assumed), the state remains pure and lies for all times in the same superselection sector.
DarMM said:
Well a very dumb example, but it could be fleshed out with a more realistic one, but imagine a "trap" of some kind that can only hold a single particle. Either spin-1/2 or spin-1. It's in contact with a reservoir of spin-1/2 and spin-1 particles with which it can exchange particles. The trap starts off with a single spin-1/2 particle. Its state after a finite time would be described by such a state.
This can work only in a setting where the initial state of the system of trap plus particle is already mixed. The reduced dynamics of the particle alone is no longer Hamiltonian. Thus it is no surprise that the initially pure state becomes mixed.
atyy said:
Quantum theory has a classical-quantum cut. Hence the use of quantum theory itself means the assumption of a classical "something".
No, it just means the appearance of something classical. A Heisenberg cut is subjective to the Observer. As I've shown earlier, observation can strengthen or weaken interference.
Apart from "observing," or detecting, the electrons, the detector had no effect on the current. Yet the scientists found that the very presence of the detector-"observer" near one of the openings caused changes in the interference pattern of the electron waves passing through the openings of the barrier. In fact, this effect was dependent on the "amount" of the observation: when the "observer's" capacity to detect electrons increased, in other words, when the level of the observation went up, the interference weakened; in contrast, when its capacity to detect electrons was reduced, in other words, when the observation slackened, the interference increased.
https://www.sciencedaily.com/releases/1998/02/980227055013.htm
So based on things like this, I see wave function collapse as the reduction of interference. This doesn't mean the probable states collapse. Without interference, these probable states appear as classical to the observer.
DarMM said:
Just to be clear, this is definition of superselection rules given by Wightman in "Superselection Rules: Old and New":
In the same paper Wightman also refers to "Superselection rules induced by the environment". So it seems to be considered valid by both Streater and Wightman that there can be superselection rules induced by the environment. Can you perhaps say where they are wrong with this?
It is only an informal notion, not a mathematical one. This is revealed by the fact that Section 6, which discusses this, has no significant formulas. Indeed, in the final paragraph of his paper Wightman writes:
Arthur Wightman said:
Even the definition of what one means by a superselection rule for a system induced by its environment has not been made sufficiently precise.
Maybe assuming a thermodynamic limit for the environment can make this mathematically precise, but of course the latter is an approximation only.
Note that there seem to be several definitions of a superselection in the literature, which may also be a source of talking past each other. Some authors permit superselections to simply correspond to a non-trivial commutant, allowing the center to be trivial. Even weaker, some authors, such as R.F. Streater permit it to correspond to the absence of an interference operator from the algebra of measurables. I use "measurable" here to specify a difference from the abstract C*-algebra of observables, where by we may be excluding observables for reasons beyond the quantum kinematical.
So if ##\mathcal{M}## is the Von-Neumann algebra of abstract observables constructed from the basic degrees of freedom, the different notions of superselection in the literature are in decreasing strength:
  1. ##\mathcal{Z}\left(\mathcal{M}\right)## non-trivial and ##\mathcal{Z}\left(\mathcal{M}\right) \subset \mathcal{M}##
  2. ##\mathcal{Z}\left(\mathcal{M}\right)## non-trivial
  3. Simply that ##\mathcal{M}^{'}## is non-trivial. Which may permit ##\mathcal{Z}\left(\mathcal{M}\right)## to be trivial. There are many different definitions of superselection in the literature that all reduce to this, or when made mathematically precise become this.
  4. The absence of the appropriate interference observable from the set of physically realizable observables.
Only the fourth, weakest notion, is the one commonly invoked for the Schrödinger cat paradox in order to view the uncertainty between macroscopic states as being due to ignorance. An example would be Streater in section 4.6 of his text "Lost Causes in and beyond Theoretical Physics" where he says on p.51:
This justifies the assumption that two states of a system differing in the value of a classical variable are separated by a superselection rule.
Thus he uses this weakest notion of superselection to argue for classical ignorance amongst macroscopic degrees of freedom. As you said this is not superselection in the quantum kinematical sense. Although note that some authors permit a weaker notion of superselection that is still kinematical (3 in the list above).
You've meant Definition 1 or perhaps also 2, where as I have meant the weakest: 4.
A. Neumaier said:
The misunderstandings in this thread...
Indeed, @vanhees71 essentially spotted this in #116. It's also the differences between the notions of entropy.
kith said:
Just a quick question: are there kets which correspond to partially mixed states?
DarMM said:
In the GNS construction you can form a vector state corresponding to any mixed state.
More in line with the case here you can just change the coefficients in front of the kets.
I have thought about it some more and your posts helped me to fix an error in my thinking.
In decoherence, we start with a superposition and evolve to a maximally mixed state. During this, the off-diagonal elements of the density matrix decay. In your example, we also end up in a maximally mixed state but we start with a basis state. What bothered me somehow was that the off-diagonal elements remain zero at all times but now I see that that's not a problem at all.
There's also been the related misunderstanding that when I asked about "partially mixed states", I had in mind a density matrix with fixed populations but didn't spell this out. Keeping this in mind, the answer to my question above is "no, these states are forbidden". Until now, I have viewed superselection rules from the viewpoint of the Hilbert space / state vectors / density matrices but if we start with the algebra of observables it seems very natural that certain density matrices simply don't occur as valid states.
Thanks for your help! I see that my knowledge has become a bit rusty in parts.
kith said:
Thanks for your help! I see that my knowledge has become a bit rusty.
No problem! It's very abstract stuff, I get mixed up myself sometimes! :smile:
