Is the series covergent or divergent?
  • Context: Undergrad
  • Thread starter Thread starter shaiqbashir
    Divergent Series
The series \sum \frac{2}{\sqrt{n}+1} is divergent, as confirmed by applying the Limit Comparison Test with the harmonic series \sum \frac{1}{n}. The Divergence Test initially yielded a result of zero, leading to confusion regarding convergence. The correct approach involves comparing the series to \sum \frac{1}{\sqrt{n}} and \sum \frac{1}{n^{1.5}}, both of which also indicate divergence. The discussion highlights the importance of selecting appropriate comparison series for determining convergence or divergence.
  • Understanding of series convergence and divergence
  • Familiarity with the Limit Comparison Test
  • Knowledge of the Divergence Test
  • Basic Comparison Test principles
  • Study the Limit Comparison Test in detail
  • Explore the Divergence Test and its applications
  • Learn about the Basic Comparison Test and its effectiveness
  • Investigate series behavior as n approaches infinity
Mathematics students, educators, and anyone studying series convergence and divergence, particularly in calculus or analysis courses.
shaiqbashir
is the series covergent or divergent?
I want to know that is the following series convergent or divergent??
when i apply divergent test to it, it comes equal to 0 , it means that divergent test gets failed. then how to solve it?
which test i should apply?
the correct answer in my copy is written as COnvergent, but I am not getting a convergent answer.
please help me as soon as possible!
Thanks in advance!
Compare it to \sum 1/n.
Are you sure about that? Perhaps you should specify the limits, or may we assume from 0 (or 1?) to infinity?
Thanks for ur Help StatusX!
I applied Limit comparison test and it works with series 1/n as Bn.
thanks a lot once again!
But you know that the harmonic series (1/n) diverges, right?
okz okz! I am sorry for some mistakes.
the correct answer of the above series is this that the series is DIVERGENT not convergent. it was my mistake!
So that means that Status X was correct, we can compare it with 1/n and we can also compare it with 1/(n^1/2)
both will give divergence as result by using Basic Comparison test.
Now I am having another problem which looks like to me of the same sort. I don't know its correct answer. here is the problem :
\sum \frac{1}{\sqrt{n}+\sqrt{n+1}}
we have to find that is the following series converging or diverging??
here is what i have done:
The Divergence Test seems to be failed here as it is giving me an answer equals to zero!
Now if i go for basic comparison test, what series should i consider in order to compare it with above series?
I have worked on the following series and they don't give me proper results:
\sum \frac{1}{\sqrt{n+1}}
\sum \frac{1}{n}
\sum \frac{1}{n^(1.5)}
Then what should i consider?
please answer this question as soon as possible!
thanks in advance!
What do the terms look like as n gets very large? That should give you an idea of what to compare it to.
  • · Replies 17 ·
