Is the Spin of Electrons Aligned Opposite to Net Magnetization in Ferromagnets?
  • Context: Graduate
  • Thread starter Thread starter eintagsfliege
    Ferromagnetic
The discussion revolves around the relationship between electron spin alignment and net magnetization in ferromagnetic materials. Participants explore the implications of spin band structure, the behavior of charge carriers in the presence of magnetization, and the effects of magnetic fields on energy levels.
  • One participant suggests that the difference in the number of up- and down-spin electrons contributes to net magnetization in ferromagnets.
  • Another participant argues that conduction in ferromagnets can occur for both spin channels, depending on the density of states at the Fermi level, and mentions the existence of half-metals that support conduction for only one spin type.
  • A question is raised about why electrons passing through a ferromagnet tend to align their spins with the magnetization, despite the minority band having a higher density of states at the Fermi level.
  • One participant explains that the presence of a magnetic field alters the Hamiltonian, leading to a splitting of energy levels for spin-up and spin-down electrons, favoring spins aligned with the field.
  • Another participant expresses confusion regarding the polarization of charge carriers by magnetization in the absence of an external magnetic field, questioning the relationship between spin channels and density of states.
Participants express differing views on the behavior of electron spins in relation to net magnetization and the effects of magnetic fields, indicating that multiple competing perspectives remain unresolved.
Participants highlight the importance of distinguishing between density of states at the Fermi level and integrated density of states, suggesting potential limitations in understanding the relationship between spin alignment and magnetization.
eintagsfliege
Hi everybody
The bands of up- and down-spins are split in the bandstructur of a ferromagnet. Does the part with the higher amount result in a net magnetization?
If yes, doesn't that mean, that electrons passing a ferromagnet, they align their spin in the opposite direction compared to the magnetization? Since the minority band is at the fermi-level, the spins should be in opposite direction to the net magnetization.
Thanks for any help...
[URL]http://www.sciencemag.org/cgi/content/full/282/5394/1660/F1[/URL]
Yes to your first question: you add up the total number of electrons for both spins and the difference gives you the net magnetization.
No to your second question: a ferromagnet usually has a Fermi surface for both spins, so it can support conduction for either. Conduction is proportionate to the density of states at the Fermi level, which can be larger of smaller in either spin channel. There are materials called half-metals which have a gap in one spin channel and not the other; these materials will only support conduction of one type of spin (usually in the majority channel I think).
hm...how comes then, that the electrons passing a uniform magnetization tend to align its spin to the magnetization?
The presence of a magnetic field will change the Hamiltonian and thus the energy levels. Roughly speaking, this will add a potential energy term mu*B to the Hamiltonian and split the energy levels for spin up and down electrons, so that spins aligned with the field become more populated.
But even when no magnetic field is applied, the magnetization polarizes the charger carriers passing by.
I don't understand it, since it seems that the minority band has a higher density of states at the fermi level.
Huh? I don't understand your question. You said "no magnetic field is applied, the magnetization polarizes the charger carriers passing by..." charge carries are passing by what?
The spin minority/majority has nothing to do with the density of states at the Fermi level, it's about the integrated density of states up to the Fermi level.
  • · Replies 19 ·
