Is the statement 0! = 1 actually wrong or just ill-defined?
  • Context: High School
  • Thread starter Thread starter johncena
    Proof
The statement 0! = 1 is established as true by definition, specifically through the recursive definition of factorials where 0! is defined as 1. This definition aligns with the Peano Axioms, which assert that 0 is a non-negative integer and not the successor of any number. The discussion also highlights the importance of definitions in mathematics, noting that while a definition may be deemed useless, it cannot be incorrect. The combinatorial interpretation of 0! as the number of ways to choose 0 elements from a set further supports this definition.
  • Understanding of factorials and their recursive definitions
  • Familiarity with the Peano Axioms
  • Basic knowledge of combinatorics, specifically binomial coefficients
  • Concept of parity in integers
  • Study the properties of the Gamma function and its relation to factorials
  • Explore the implications of the Peano Axioms in number theory
  • Research combinatorial interpretations of factorials and their applications
  • Investigate the concept of consistency in mathematical definitions and axioms
Mathematicians, educators, students in mathematics, and anyone interested in the foundations of mathematical definitions and their implications.
johncena
what is the proof for the statement 0! = 1??
Mathematics news on Phys.org
a number neither odd nor even cannot be equal to an odd number.
But zero is an even number since it has a parity of 0.
Assuming you mean the factorial of 0, then factorial is usually defined recursively by,
0! = 1
n! = (n-1)! * n for n > 0
So it's true by the definition of the factorial. If you mean why 0 doesn't equal 1 then you have to state explicitly some formal properties of the integers. For instance a popular way to describe the non-negative integers is the Peano Axioms which among other things state that 0 is a non-negative integer, there is no natural number whose successor is 0 and 1 is defined as the successor to 0. Hence if 0 = 1 then 0 would be the successor to 0 which contradicts the axiom that 0 isn't the successor of any non-negative number.
Alternatively if you are allowed to use properties like parity, and the fact that 0 and 1 have different parity, then they can't be equal because parity is uniquely determined. Note: 0 has even parity while 1 has odd parity; 0 is NOT neither odd nor even.
you said n! = (n-1)! * n for n > 0
so taking n = 1,
1! = (1-1)! * 1 = 1
0! * 1 = 1
thus, 0! = 1/1 = 1
is this proof correct?
There is no proof, it's by definition. It gives a basis for a recursive definition of n! as n! = n*(n-1)! and 0! = 1.
Like others said, this is by definition. You might be interested in the http://en.wikipedia.org/wiki/Gamma_function" .
I'll also note a definition can never be wrong. It may be useless, but it's never wrong.
A motivation(maybe) behind defining 0!=1, might be if we look at the combinations of class k taken from a set of n elements.
C_{k}^{n}
THen, since this is nothing else but the set of all subsets of k elements taken from a set of n elements, if we have:
C_0^n=\frac{n!}{(n-0)!0!} then since there is only one set that contains 0 elements taken from any set of n elements (the empty set), it follows that
C_0^n should equal 1, for this to happen 0! should be 1.
... unless a useless definition is defined to be something that is incorrect or wrong. :-p
But that would be a useless definition!
A definition cannot be incorrect or wrong. What a group of definitions can be is inconsistent, which is subtly different :) Determining if a set of axioms is consistent is a difficult problem (and consistency is the cornerstone for godel's theorem as with an inconsistent set of axioms you can prove stupid things like 0=1, 1=2, etc)
I was kinda playing. But what I think is more subtle is the use of the words "wrong" and "incorrect." If one were trying to make a definition of something containing the essence of an idea, such as curvature, then I could see how some definitions can be considered wrong or incorrect. Something being ill-defined often carries connotations of incorrectness or inconsistency, as its name implies. However, stating that the truth/validity in the defining of definition X is false is something I find somewhat meaningless.
  • · Replies 66 ·
  • · Replies 55 ·
  • · Replies 19 ·
  • · Replies 26 ·
