Is the theory of fractional-ordered calculus flawed?
The discussion revolves around the theory of fractional-ordered calculus, specifically examining the behavior of fractional derivatives and integrals applied to polynomial functions. Participants explore the implications of applying fractional derivatives and integrals, questioning whether the theory is flawed based on the results obtained from these operations.
  • One participant presents a mathematical exploration of fractional derivatives and integrals, questioning why an additional constant appears when applying the half-ordered integral operator twice to a polynomial function.
  • Another participant argues that fractional calculus is based on definite integrals, suggesting that the presence of an additional constant is not a flaw.
  • A different viewpoint emphasizes that the process of anti-differentiation in ordinary calculus produces a family of functions, implying that fractional calculus should also accommodate this characteristic.
  • Some participants discuss the definition of anti-differentiation as an operator that can yield unique results when a reference point is established, contrasting this with the traditional view of producing a family of functions.
  • There is a suggestion that fractional calculus often uses operators defined with respect to specific reference points, which may explain the absence of multiple constants in some definitions.
Participants express differing views on whether the introduction of an additional constant in fractional calculus indicates a flaw in the theory. Some assert that fractional calculus should produce a family of functions similar to ordinary calculus, while others maintain that it is correctly defined as producing unique results based on reference points. The discussion remains unresolved with multiple competing views.
The discussion highlights limitations in the assumptions regarding the behavior of fractional derivatives and integrals, particularly in relation to the definitions used in fractional calculus. There is an emphasis on the dependence of results on the chosen reference points and the implications of defining integration as a process that yields unique functions.
Kumar8434
Let's talk about the function ##f(x)=x^n##.
It's derivative of ##k^{th}## order can be expressed by the formula:
$$\frac{d^k}{dx^k}=\frac{n!}{(n-k)!}x^{n-k}$$
Similarly, the ##k^{th}## integral (integral operator applied ##k## times) can be expressed as:
$$\frac{n!}{(n+k)!}x^{n+k}$$
According the the Wikipedia article https://en.wikipedia.org/wiki/Fractional_calculus, we can replace the factorial with the Gamma function to get derivatives of fractional order.
So, applying the derivative of half order twice to ##\frac{x^{n+1}}{n+1}+C##, should get us to ##x^n##.
Applying the half-ordered derivative once gives:
$$\frac{d^{1/2}}{{dx^{1/2}}}\left(\frac{x^{n+1}}{n+1}+Cx^0\right)=\frac{1}{n+1}\frac{\Pi(n+1)}{\Pi(n+1/2)}x^{n+1/2}+C\frac{1}{\Pi(-1/2)}x^{-1/2}$$
where ##\Pi(x)## is the generalization of the factorial function, and ##\Pi(x)=\Gamma(1+x)##.
Again, applying the half-ordered derivative gives:
$$\frac{1}{n+1}\frac{\Pi(n+1)}{\Pi(n)}x^n+\frac{C}{\Pi(-1)}x^{-1}=x^n$$
which works fine because ##\frac{C}{\Pi(-1)}\rightarrow 0##. So, the derivative works good but that's not the case with fractional-ordered integration.
Applying the half-ordered integral operator twice to ##x^n## should give us ##\frac{x^{n+1}}{n+1}+C##. Applying the half-ordered integral once means finding a function whose half-ordered derivative is ##x^n##. So, applying it once gives:
$$\frac{\Pi(n)}{\Pi{(n+1/2)}}x^{n+1/2}+C\frac{1}{\Pi(-1/2)}x^{-1/2}$$
Again, applying the half ordered derivative to this function should give a function whose half-ordered derivative is this function. So, again applying the half-integral operator gives:
$$\frac{x^{n+1}}{n+1}+C+C'\frac{1}{\Pi(-1/2)}x^{-1/2}\neq \frac{x^{n+1}}{n+1}+C$$
where ##C'## is another constant. So, why this additional term containing ##C'## gets introduced? Is the theory of fractional derivatives flawed? Is there any way to get a single constant ##C## in the end by applying the half-integral operator two times?
I mistakenly posted it on General math. How to transfer it to the calculus forum?
You can use the "report" feature to report your own original post. In the reasons for reporting, say "Posted in wrong section. Please move the thread to the Calculus section". (The report feature isn't exclusively for reports about posts that are inflammatory or scandalous etc.)
No it shouldn't. There should be no +C because fractional calculus is a theory of definite integrals.
That isn't one of the assumptions used in fractional calculus.
Do you consider it a flaw of ordinary calculus that applying anti-differentiation twice to ##x^1## fails to produce ##x^3/6## and instead produces ##x^3/(6) + C + C'x##?
The definition of "anti-differentiation" in ordinary calculus is often stated as process that does not produce a unique function. Instead it produces a family of functions. The process-oriented definition of "anti-differentiate ##f(x)##" is to state a family (i.e. a set) of functions ##\mathbb{F}## such that that each member ##\mathbb{F}## of the family has a derivative equal to ##f(x)##. For example the statement ##\int x \ dx= x^2/2 + C## amounts to defining ##\int x\ dx## as a family of functions whose distinct members are defined by picking different values of ##C##.
To define anti-differentiation as a specific "operator", we must define it so it produces a unique answer. (An operator is a function whose domain is a set of functions and whose co-domain is a set of functions. A function must map each element in the domain to a unique element in the co-domain). The usual way to define a unique anti-differentiation operator is to take a specific "reference point" (also called a "fiducial point" by some authors). For example, taking the value ##a ## as the reference point, we can define the anti-derivative operator ##D_a^{-1} f(x)## as ##D_a^{-1} f(x) = \int_a^x f(x) dx##. That definition leaves no "undetermined constant" in the result because ##F(x) = D_a^{-1} f(x) ## implies ##F(a) = 0## so we have a "boundary value" that determines any constant that temporarily appears using the usual rules for the process of anti-differentiation. (i.e. ##D_a^{-1} f(x) = F(x) - F(a)## so the specific constant is ##-F(a)## and ##F(x)## is a specific function, not a family of functions. )
For example ##D_6^{-1} x = \int_6^x x\ dx = x^2/2 - 36/2 ##.
The usual approach in the fractional calculus is to use anti-derivative operators that are defined with respect to a specific reference point.
See page 5 of http://www.reed.edu/physics/faculty...ractional Calculus/A. Fractional Calculus.pdf for an elaboration of those ideas.
See page 5 of http://www.reed.edu/physics/faculty/wheeler/documents/Miscellaneous Math/Fractional Calculus/A. Fractional Calculus.pdf for an elaboration of those ideas.
Thanks. That solved my issue. But, why in fractional calculus the integration isn't defined to give a family of functions if getting multiple constants in the end isn't much problem?
If you look at various versions of the fractional calculus, you see that both fractional differentiation and fractional integration are defined as operators involving some reference point. (Sometimes the reference point is in implicitly taken as ##a = 0## or ##a = -\infty##). So if you try to define the process of integration of ##f(x)## as "state all possible functions whose derivative is ##f(x)##", you are involved in considering reference points since differentiation involves a reference point.
So the first question we should ask is "Why is fractional differentiation defined in terms of a reference point?"
The definition of the derivative of ##f(x)## in ordinary calculus is only referenced to the value "##x##". By contrast the various definitions of fractional derivative of ##f(x)## involve (implicitly or explicitly) an additional value besides ##x##. I suppose the only way to see why that is so would be to try to create a definition of fractional derivative that did not involve a reference point - and see what kind of trouble we get into making such a definition useful.
  • · Replies 0 ·
  • · Replies 36 ·
