Is the Universe a Quantum Computer Algorithm?
65 replies · 12K views
Tom Mattson said:
What's that supposed to prove?
http://www-groups.dcs.st-and.ac.uk/~history/Mathematicians/Witten.html
Basically Witten is a mathematical physicist and he has a wealth of important publications which are properly in physics. However, as Atiyah writes in [3]:-
Although he is definitely a physicist (as his list of publications clearly shows) his command of mathematics is rivalled by few mathematicians, and his ability to interpret physical ideas in mathematical form is quite unique. Time and again he has surprised the mathematical community by his brilliant application of physical insight leading to new and deep mathematical theorems.
Tom Mattson said:
Maybe it's time for you to consider that you really don't understand mathematics all that well. The objects of mathematics, and the rules of inference, are all based on definitions. Get those wrong, and you've got math wrong.
Yes, there is much to learn about mathematics.
I promise to harass you whilst you are spouting inaccurate garbage, Russell, don't worry. Why on Earth you chose to cite Ed Witten is a mystery, but then you seem to be beyond the pale of reasonable logical thought and into the realms of the crackpot, so frankly who cares?
Tom Mattson said:
Again, what is that supposed to prove?
You wrote this:
Tom Mattson said:
Physics has no bearing on set theory, Venn diagrams, or circles.
Sets "contain" elements, members, etc. Venn diagrams can be represented as conic sections.
A______B
____P____
C______D
A, B, C, and P are "co-moving" i.e. they are at rest with respect to each other. The radius[hypotenuse] from P to the other points{A, B, C, D} is the same length. An expanding circle of light[from point P] reaches A, B, C, and D, "simultaneously". The invariance of "c".
Tom Mattson said:
Experimental physics is not mathematical, but it's still physics. Of course, doing physics would be very difficult without math, but it certainly could exist without it.
:zzz: :zzz: :zzz:
There is no experiment unless "numbers" can be attached to the quantity being observed.
Your statement that "experimental physics is not mathematical" is total hog-wash.
Any measurement uses numbers.
Light cones are cutting edge stuff :
http://www.mpi-hd.mpg.de/ilcac/98SPeter_prop/node4.html
It has been known for some time that light-cone field theory is uniquely suited for to address problems in string theory. In addition recently new developments in formal field theory associated with string theory, matrix models and M-theory have appeared which also seem particularly well suited to the light-cone approach
Yes, I suppose it is psychologically healthfull [for you at least] to get in touch withn your inner troll
Russell E. Rierson said:
You wrote this:
Yes, I know what I wrote.
LOL, thanks for the lesson. :rolleyes:
A______B
____P____
C______D
This has nothing whatsoever to do with the question I asked. In fact. your entire post looks as though it were written by a random word generator.
False. You can do an experiment without attaching any numbers to the results, and it would still be called "physics".
That's not what an experimental physicist would say. :rolleyes:
No kidding. That doesn't mean that physics wouldn't exist without mathematics.
And what does this have to do with anything being discussed here?
An experiment is something that can be repeated over and over again. The repetition leads to "equations".
I flip a coin for a large number of repetitions, I notice[observe] certain regularities.
Yes it does. Numbers are part of "mathematics".
You also appear to act like an ignorant troll.
An experiment is something that can be repeated over and over again. The repitition leads to "equations".
Observation is not the same as doing mathematics.
Again, simply attaching numbers to measurements is not the same thing as doing mathematics.
Guess what? So do you. :rolleyes:
Seriously, so what if I appear that way to you? You said the same thing to Matt Grime. He is a PhD student in mathematics, and I am a PhD student in physics. Given that you seem to be struggling to understand both of those two disciplines, it hardly seems unsettling that you should say that.
edited after second thoughts:
Thank you for your perspective Tom Mattson
A measurement is "numerical": e.g. distance, length, time, force, counting repititions, counting quantities, weight, mass, colour-wavelength, symmetric/asymmetric/anti-symmetric patterns, volume, area, etc.
Distinctions or differentiating between quantities is inherently LOGICAL/MATHEMATICAL.
My[Phd student] interlocutors only response has been "that aint true".
What can I say...
College aint what it used to be?
What can I say...
that isn't what you've been saying before, and our replies do not reflect what you claim we have said.
In fact I believe we are pointing out that you do not konw what a venn diagram is, nor that you understand the usage and meaning (if they are different) of 'necessary' and that you stated all simple closed curves were circles, which is obviously wrong.
I don't recall ever using or seeing the word 'distinction' before in this thread and I certainly can't imagine I needed to use 'measurement' at any point other than in this post.
You are distinguishing between things, and you are inherently unmathematical. At least you are consistent in your inconsistency.
Nope. I never said simple closed curves were "only" circles.
But your continual berating is very distracting. Hopefully you can put that education to good use and say something constructive.
No one denies that numbers are attached to measurements, but as I said, measuring and doing mathematics are two different things. Also, one could do experimentation qualitatively, without numbers. Did you know that there is not a single equation in any of Michael Faraday's lab notebooks? And yet who would say that he did not do physics?
Well, that's not really fair. We have explained ourselves.
Didn't Michael Faraday discover somethiong like "field" lines of force? If his notebooks contained diagrams, then he was thinking in terms of vectors.
Vectors are mathematical.
You keep stating the obvious, as if it proves what your are saying, but it doesn't. No one denies that physical forces can be described by vectors, and quite well at that. But it is not the case that physical forces are vectors. One is the map, and the other is the territory: they aren't the same thing.
Faraday was an experimentalist who thought in "mathematical" terms, even though he was not formally trained in physics or mathematics.
You concede then?
OK...
That's just it: He thought in physical terms. It is you who is imposing the mathematical viewpoint onto this.
An experimentalist with no training or interest in mathematics looks at Faraday's apparatus and sees coils, batteries, wires, magnets, capacitors, inductors, etc. He hooks them up and he sees wires being attracted and repelled, ammeter needles deflecting, etc.
You look at those things, and you see vectors, whose line integrals you can compute and whose divergence you can calculate. There's nothing wrong with that (indeed, I see the same thing), but there's also no reason to think that everyone is going to see it that way. Further, there's further no reason to think that such people aren't "doing physics".
The statement "Physics would not exist without mathematics" is simply false. In fact I think a better case could be made for the converse.
You concede then?
OK...
Why should I? :confused:
Faraday visualized field lines of force; directed line segments. Vectors in simple form.
In certain respects, physical existence is mathematical. If not, then why does mathematics explain the world so well?
http://www.dartmouth.edu/~matc/MathDrama/reading/Wigner.html
http://en.wikipedia.org/wiki/The_Unreasonable_Effectiveness_of_Mathematics_in_the_Natural_Sciences
"The miracle of the appropriateness of the language of mathematics for the formulation of the laws of physics is a wonderful gift which we neither understand nor deserve. We should be grateful for it and hope that it will remain valid in future research and that it will extend, for better or for worse, to our pleasure, even though perhaps also to our bafflement, to wide branches of learning."
An arbitrary n-dimensional surface, a curve, can be defined by a parametric equation:
[itex]x^a[/itex] = [itex]x^a(u)[/itex] , [itex](a = 1,2,...,n)[/itex] where [itex]u[/itex] is the parameter with [itex]x^1(u),x^2(u),...,x^n(u)[/itex] denoting [itex]n[/itex] functions of [itex]u[/itex]. A subspace/surface of [itex]m[/itex] dimensions has [itex](m < n)[/itex] degrees of freedom, depending on [itex]m[/itex] parameters according to the parametric equations:
[itex]x^a[/itex] = [itex]x^a(u^1 , u^2 ,..., u^m)[/itex] , [itex](a = 1, 2,...,n)[/itex]
When [itex]m = n-1[/itex] the subspace is called the hypersurface:
[itex]x^a[/itex] = [itex]x^a(u^1 , u^2 ,..., u^n^-^1)[/itex], [itex](a=1, 2,..., n)[/itex]
If the manifold with [itex]n[/itex] degrees of freedom is restricted to a hypersurface of an [itex]n-1[/itex] subspace, its coordinates must satisfy the constraint:
[itex]f(x^1 , x^2,..., x^n) = 0[/itex]
Intersecting "level surfaces" or simple closed curves, of n-1 dimensions with radius R and 1/R, respectively, form in-phase standing waves. A geometric "universal set".
nxn matrices and nxn matrices of nonzero determinant are manifolds, one has one fewer degree of freedom than the other, yet they have the same dimension (that of the dimension of its tangent space at any point).
We'll leave the rest as specious nonsense at this stage
I can see that my comment went in one ear and out the other.
Once again: it is you who is imputing the mathematical interpretation onto this.
First, a question is not a valid argument. Second, mathematics isn't used "explain" the world at all. It is used to describe the world. And third, your position as to the nature of existence is neither a scientific viewpoint nor a mathematical one. It is a philosophical viewpoint, and a rather bad one at that, as it is a form of idealism that mistakes the ideal forms used to describe the physical reality, for the physical reality itself.
Anyway, the point that led up to this line of discussion was my response to your comment that energy arguments could somehow be invoked in set theory. They can't. Physical arguments are of no use whatsoever in proving mathematical results, because math is not physics, and vice versa.
I have read the Wigner article more than once. Do you know why he calls the effectiveness of mathematics "unreasonable"? It's because no one can explain it. That is precisely why the article is not of any use in proving your assertions.
Incorrect. First, "standing waves" are physical phenomena. And second, even if you mean that they are "standing wave solutions to the wave equation" (which are bona fide mathematical objects), your analysis here by no means proves such a thing. You haven't even specified the parametric equations, nor a dynamical equation that they are supposed to satisfy.
What is so "universal" about this set?
I'm afraid Matt is right: What you have written here is specious nonsense, and has nothing to do with either math or physics.
Tom Mattson said:
... mathematics isn't used "explain" the world at all. It is used to describe the world.
Sorry for the intrusion. That was once one of my misconceptions (about relativity, but same thing). Best way to make it clear is to think that math was invented to get answers in the physical world. That is, to describe it, not to explain it. Because, things don't happen in physical world because of math says so, it's the other way around. Math is abstract anyway. So when you simplfy or rearrange equations, it may not have a physical meaning, maybe two forces are canceling each other out, but they sill exist, the answer you get is still correct.
It is one interpretation of the "Wheeler-Feynman Absorber" theory. I will not give the equations on a silver platter. :eek: :eek: :eek:
:rolleyes:
First of all, you have not presented anything that could be called an interpretation of any physical theory. And second, the Wheeler-Feynman Absorber theory is not a secret.
You keep throwing technical terms around, but you don't seem to have the foggiest idea of what any of them mean.
Has it occurred to you to go into the Math and Physics Forums and ask people for help? This place is loaded with people who can do just that.
Here is a quote of Oliver Heaviside, talking about Michael Faraday:
"And it is a noteworthy fact that ignorant men have long been
in advance of the learned about vectors. Ignorant people, like
Faraday, naturally think in vectors. They may know nothing of their
formal manipulation, but if they think about vectors, they think of
them *as* vectors, that is, directed magnitudes. No ignorant man
could or would think about the three components of a vector
separately, and disconnected from one another. That is a device of
learned mathematicians, to enable them to evade vectors. The device
is often useful, especially for calculating purposes, but for general
purposes of reasoning the manipulation of the scalar components
instead of the vector itself is entirely wrong."
Mathematics is a meta-language. Yes, mathematics "describes" the physical universe and it also "explains" :
http://www.m-w.com/cgi-bin/dictionary?book=Dictionary&va=explain&x=15&y=16
EXPLAIN
1 a : to make known b : to make plain or understandable <footnotes that explain the terms>
2 : to give the reason for or cause of
3 : to show the logical development or relationships of
:eek:
Here is an interesting paper by Max Tegmark that you have probably read before?
http://www.hep.upenn.edu/~max/toe.pdf
Here is a quote about the equivalence of mathematical existence with physical existence:
Our proposed TOE can be summarized as follows:
Physical existence is equivalent to mathematical existence.
What precisely is meant by mathematical existence, or
ME for brevity?
A generally accepted interpretation of
ME is that of David Hilbert:
Mathematical existence is merely freedom from contradiction.
In other words, if the set of axioms that defne a mathematical
structure cannot be used to prove both a statement
and its negation, then the mathematical structure
is said to have ME.
"Mathematical existence is merely freedom from contradiction" The universe must make sense.
Faraday recognized that action at a distance was absurd, and he solved the problem with the "field" concept.
You are saying that fields are not mathematical structures? I disagree. You are saying that Faraday didn't think mathematically? I disagree.
The laws of physics could be described as laws of geometry. The constants of physics could be described as constants of geometry. That is what Einstein was trying to do, yes?
Then Wigner's paper is also useless for Max Tegmark's writings and I wasn't trying to prove assertions with it.
I agree with Michael Faraday and Albert Einstein. Action at a distance is totally absurd. Geometry solves that problem.
Again, I will repeat the first axiom:
If the physical universe includes all that is real and excludes all that is not real, then the physical universe is the universal set.
References for the first axiom:
Chris Langan
www.ctmu.org
Lee Smolin
"Three Roads to Quantum Gravity"
Refute the first axiom. You are a mentor.
That is your opinion? Refute it mathematically.
Yes, I will ask for help. One question at a time.
Thank you.
So what? Even if I leave alone the fact that Heaviside and Faraday were not contemporaries[/color], the fact remains that this does not one thing to prove your ridiculous assertion that physics would not exist without mathematics, and neither does it do anything for your equally ridiculous assertions that physical arguments can be used in mathematical proofs. Why won't you just concede that fact, instead of bringing up these silly arguments?
Oh does it? Let's look at what you cite as evidence.
EXPLAIN
Mathematical models don't do that. That's what observation does.
Nope, mathematical models don't do that either.
OK, mathematical models do that, to a certain extent. But they most definitely don't do that in the most fundamental degrees of freedom, whch is what would be required for an "explanation".
Yes, I've read it. Do you really think that a student in theoretical physics hasn't read the articles by Tegmark and Wigner?
Here's a novel idea: How about you stop trying to prove your ponits with quotes, and start trying to prove them with arguments. :surprise:
1. I am saying that physical fields, and the mathematical fields used to describe them, are not the same thing.
2. I am not saying that Faraday didn't think mathematically. I am saying that there is no reason to think that your assertion, "Physics would not exist without mathematics", is correct.
That's what he did with GR, and he tried to do it with his attempt at a unified field theory in the 1950's. Still, none of that information lends any credence to the math-o-phille position that mathematical forms acutally exist in nature. That is an unfounded belief.
Then why did you quote it in response to my challenge of your assertion?
I agree that action at a distance is absurd. But I would say that geometry describes the problem. I would also be so forward as to say that Faraday and Einstein would agree with that.
Chris Langan
www.ctmu.org
Lee Smolin
What are you talking about? Axioms don't need references or proofs. They just need logical arguments to flow from them. What you quote here proves nothing.
I don't even care about refuting "the first axiom", if nothing can be derived from it.
Tom: I'm afraid Matt is right: What you have written here is specious nonsense, and has nothing to do with either math or physics.
Russell: That is your opinion? Refute it mathematically.
It's not my opinion, it is a fact. You want me to prove mathematically that the gibberish you have posted is wrong? Why should I? Instead why don't you stop screwing around and post something with some actual reasoning behind it?
:rolleyes:
Nice try.
From the quote of Tegmark and Hilbert: Hilbert defines mathematical existence as "freedom from contradiction"
If mathematical existence equals physical existence:
Physical theories must be free of contradiction.
Physical theories would not exist without mathematics.
Physics must be free of contradiction
Are you saying that "observation" is not a mathematical process in itself?
eye<-------[photons]------->observed phenomena
I am not proving[or trying to prove] points with quotes. This thread started out as a question and was moved to TD. Now I am trying to "develop" the theory. Or more correctly, I am trying to develop a hypothesis
Earlier, you said this about Faraday:
Now you agree that he thought in mathematical terms also :devil:
Thanks.
It is not a "belief". It is a hypothesis. Perhaps I should have stated that expilcitly.
Thanks for the help.
:rolleyes:
Nice try.
I have no idea of what you mean by that.
Was this supposed to be an answer to what I was saying? If so, then I don't see how. All you are doing is starting from your peculiar brand of idealist philosophy, and drawing conclusions from it. I wasn't wondering about the consequences, I was wondering what made you think the statement,
"Mathematical existence equals physical existence,"
was true in the first place.
Yes, observation is not a mathematical process.
Then why do you respond to comments with quotes and links that have no relevance to the discussion? Why not just post an argument? If you are here to devlop a theory, you don't seem to be trying very hard.
Thanks.
He probably did. So what? It still doesn't mean that physics would not exist without mathematics.
A belief is nothing other than a hypothesis that is held to be true, without any evidence.
I feel compelled to echo Matt's earlier thought: When you have figured out what it is you want to prove, let us know.
Mathematics is THE LANGUAGE that express human thoughts in the most logical way. Physics is the study of what exists. You can consider an observation made in an experiment to be part of the mathematical terminology, but in our mathematical system they aren't always included.
Also if you meant to say that "existence" is due to mathematics it isn't true since language isn't by definition the root of existence.
Since mathematical existence is defined by David Hilbert as "freedom from contradiction" It holds that, if, mathematical existence is equal to physical existence, then physical existence is also freedom from contradiction. That is to say, physical phenomena[events] are constrained by an intrinsic, logical self-consistency.
Observation[in the sense of empiricism/scientific method] is NOT self contradictory, if, physical existence is "freedom from contradiction".
Ergo, it follows that your statement: "observation is not a mathematical process" is false.
This appears to be your personal, biased opinion? Elitism? Feigned ignorance? The quotes and links ARE relevant to the discussion.
[1.] Physics would not exist without an ability to describe phenomena.
[2.] The description of phenomena must be logically consistent[free of contradiction].
[3.] Mathematical existence is defined as freedom from contradiction.
[4.] Mathematics describes phenomena.
Therefore
Physics would not exist without mathematics.
If the hypothesis cannot be tested, then what good is it?
:zzz: :zzz: :zzz:
If the universe includes all that is real and excludes that which is not real, then the universe is the "universal set".
Background Independence:
The description of any entity inside the real universe can only be
with reference to other things in the universe. Space is then
relational, and the universe, self referential. For example, if an
object has a momentum, that momentum can only be explained with
respect to another object within the universe. Space then becomes an
aspect of the relationships between things in reality.
Physicist Lee Smolin says that space becomes analogous to a sentence, and it is absurd to say that a sentence has no words in it. So the grammatical structure of each sentence[space] is defined by the relationships that hold between the words in it.
For example, relationships like object-subject or adjective-noun. So
there are many different grammatical structures composed of different
arrangements of words, and the varied relationships between them.
If the universe is closed, the "information" or entangled quantum
states cannot leak out of the closed system. So the density of
entangled quantum states, continually increases, as the entropy must
always increase. While to us, it is interpreted as entropy or lost
information, it is actually recombined information, to the universe.
Shannon entropy.
Since entropy can also be defined as the number of states within a
region of space, and the entropy of the universe must always
increase, the next logical step is to realize that the spacetime
density, i.e. the information encoded within a circumscribed region
of space, must be increasing in the thermodynamic direction of time.
The entropy of thermodynamics and entropy of Shannon, are equivalent
concepts, because the number of arrangements that are counted by
Boltzmann entropy reflects the amount of Shannon information needed
to implement any particular combination, or arrangement. The two
entropies also appear to have superficial differences.
Thermodynamic entropy is interpreted in units of energy divided by
temperature, while, the Shannon entropy is interpreted in terms of
dimensionless bits. This seems to point towards a computational/language structure for reality.
The Heisenberg uncertainty principle follows directly from the Cauchy-Schwartz inequality for scalar products. By quantizing spacetime geometry, it seems that the wavefunctions/waveforms aren't based on a background space. The wavefunction space, can be thought of as the space of square-
integrable wavefunctions over classical configuration space. Geometric quantization can be constructed, via fiber bundles.
OK, fine.
No, it doesn't follow. You are in dire need of a lesson in elementary logic. It is a simple, obvious fact that denying the statement "physical existence = mathematical existence" and affirming the statement "physical observations must be noncontradictory" are compatible.
Tom: Then why do you respond to comments with quotes and links that have no relevance to the discussion? Why not just post an argument? If you are here to devlop a theory, you don't seem to be trying very hard.
Russell: This appears to be your personal, biased opinion? Elitism? Feigned ignorance? The quotes and links ARE relevant to the discussion.
No, they aren't relevant. You consistently respond to comments with links that have the correct buzzwords, but do not connect to those comments in the slightest. Anyone who knows anything about mathematics or physics can see this.
Therefore
Russell, do yourself a huge favor and take a course in logic. This argument is so asinine, I am astounded that a would-be mathematical theorist would even post it.
Exaclty my point: Your belief that physical existence is equivalent to mathematical existence cannot be tested. Ergo, it is no good.
Shannon entropy.
Be sure to let me know when you want to present a logical argument for your ideas on geometric set theory. :rolleyes:
