Is the Young's Modulus Equation Homogeneous?
7 replies · 6K views · last reply
Frozenblaze1
I'm doing an experiment to determine the young's modulus involving the following equation:
Printed text giving the formula m/y = 8 pi r^2 Y y^2 / (g L^3) + 4 T0 / (L g), followed by definitions of m, y, L, r, Y, g and T0.
Finding the base units of the young's modulus with the equation resulted in the young's modulus being dimensionless, which of course is not true.
Handwritten dimensional analysis on lined paper: m/y = 8πr²Yy²/(gL³) + 4T₀/(Lg), rearranged to kg/m - kgms⁻²/(m²s⁻²) = 8πr²Yy²/(gL³), then kgm⁻¹ - kgm⁻¹ = Yr²y²/(gL³), ending with 0 = Y(r²y²/(gL³)) and therefore Y = 0??
Further attempts to check if the equation is homogeneous resulted in the equation not being homogeneous. Can someone double check whether or not this is the case?
The difference between two values with units kg/m is a value with units kg/m.
If it happens to be exactly zero, then some quantity is zero, but that is not part of the dimensional analysis.
You're right, that's a mistake.
I've worked out the base units again and this is what i got.
[tex]\frac{m}{y} = \frac{8.π.r^2.ϒ.y^2}{g.L^3} + \frac{4.T}{L.g}[/tex]
[tex]\frac{kg}{m} = \frac{kg.m^5.s^-2}{m^4.s^-2} + \frac{kg}{m}[/tex]
[tex]\frac{kg}{m} = kg.m + \frac{kg}{m}[/tex]
This means the equation is not homogeneous right? Or is there a mistake somewhere?
Yeah, I was taking the value of the Young's from google which seems to be incorrect. It should be kg.m^-1.s^-2
Google search results for "youngs modulus base units" showing a snippet that gives the SI unit as the pascal (Pa or N/m2) and, in red-circled text, kg. m. s-2 next to it.
