Is there a link between non-locality and non-linearity?
  • Context: Graduate
  • Thread starter Thread starter cryptist
    Non-linear
12 replies · 3K views
cryptist
Is there a strict connection between non-locality and non-linearity? Is it true that non-local systems must have non-linear equations? Are non-linear equations the consequence of non-locality?
Your question is very general.
The response of a material can be non-linear -this depends on the (external) field- while non-locality does not necessarily depend on the field. I don't know if this applies to all cases, this is simply my understanding.
You need to elaborate a bit here. What kind of "non-linear equations" do you have in mind ?
The constitutive relations of a chiral medium can be linear and non-local.
Yes, and I expect a general answer. There might be some exceptional systems as you mentioned. But, can we say that in general?
Nevertheless, let's think the motion of a particle as an example. Let's assume we exposed particle to an instantaneous effect (for example that effect can change his position superluminally). Then this system is non-local, and it must have non-linear equations, right?
Yes, quantum mechanics is linear, and I think that's why it cannot explain some phenomena like wave function collapse.
A non-local eqn will pop out if the particle's position does not depend only on the applied field, say F, but also on its derivatives, its curl for example. This does not necessarily* introduce nonlinearities in the eqns of motion.
* meaning that you don't always get quadratic or higher order terms of F
You are asking about a strict connection between non-linear and non-local. If quantum mechanics is linear and non-local, then your question has a negative answer, no?
There is no direct relation between nonlinearity and nonlocality.
Yet, if QM were nonlinear (not merely by a collapse postulate, but at a more physical level), then, depending on the interpretation, it could be even more nonlocal than it is in the standard linear form.
See e.g.
http://xxx.lanl.gov/abs/0707.2319
and Refs. [1,2,3] therein.
So such field should affect particle's acceleration also, to have non-linear equations?
Or quantum mechanics is wrong. Oops, I have to run :))
See e.g.
So as far as I understand, although no strict connection between both, nonlocality increases from linear to nonlinear.
No. Why do you say this ?
What do you mean by "nonlocality increases from linear to nonlinear" ?
martinbn said:
Isn't quantum mechanics linear ?
not settled yet.
Ok, I guess the relationship between these two is far more than I thought. So there is no substantial connection.
