Is there a proof about angular momentum conservation?
5 replies · 2K views
LCSphysicist
Angular momentum and it conservation.
L = rp
Angular momentum can be exchanged between objects in a closed system, but total angular momentum before and after an exchange remains constant (is conserved).
There is a proof about this conservation?
Consider two points in the system interacting, i.e. exerting a force on each other. If we accept the rule that action and reaction are equal and opposite then these forces are equal and opposite, ##\vec F## and ##-\vec F##, and lie in the same line.
If the forces exist for time dt then the points impart equal and opposite momenta, ##\vec Fdt## and ##-\vec Fdt##.
If we consider all this in respect of some axis O, and a vector from there to the line of action of the forces is ##\vec r##, then the angular momenta they impart on each other are ##\vec r\times\vec Fdt## and ##-\vec r\times\vec Fdt##.
Hence the sum of the imparted angular momenta is zero.
ORF said:
Hi,
A more abstract (and fancy) proof is given by Noether's theorem: if your system is invariant under rotation, angular momentum is conserved
https://en.wikipedia.org/wiki/Noether's_theorem#Applications
Regards,
ORF
Wow, this was scarry, i was just reading this in French Newtonian mechanics right now about this, like ten minutes ago kkkk unfortunately I don't understand much about these concepts of symmetry. but i will save it thx
You are using a theorem of classical Newtonian mechanics here, namely that the sum of torques ##\sum \vec{T_i}=\frac{d\vec{L}}{dt}## equals the rate of change of angular momentum L. It is a theorem in the sense that it can be proved from Newton's laws.
Start from Newton's second law ##\vec F = m \vec a ##.
By definition, the angular momentum is ##\vec L = \vec r \times\vec p= m \vec r \times\vec v##. (1)
(x means cross product)
## \vec r ## is the position vector, ## \vec v ## is the velocity ## \vec v = \dot {\vec r}##
##\vec a ## is the acceleration,##\dot{\vec v}= \vec a##.
The force is ##\vec F =m\vec a## .
The torque is ##\vec\tau=\vec r \times \vec F##
Take the time derivative of eq. (1)
##\dot{\vec L }= m \left (\dot{\vec r}\times \vec v + \vec r \times \dot{\vec v}\right)##
##\dot{\vec r}\times \vec v ==0##
so
##\dot{\vec L }= m \vec r \times \dot{\vec v}= m \vec r \times \vec a = \vec r \times\vec F= \vec \tau##
