Is there a way to prove that a set is bounded using calculus techniques?
  • Thread starter Thread starter Anne5632
    Bounded Set
The discussion revolves around proving that a set, specifically a subset of real numbers defined by the expression S=(n^2-1)/(n^3-1) for natural numbers n, is bounded. Participants explore the definitions of boundedness, including both upper and lower bounds, and consider the implications of specific values of n.
  • Participants discuss the lower bound of the set, noting that it appears to be 0 for n > 1. They question how to establish an upper bound and whether rewriting expressions could aid in proving boundedness. Some suggest using direct proof or proof by contradiction methods.
The conversation is ongoing, with participants sharing insights on proving boundedness and discussing related mathematical concepts. Some guidance has been offered regarding proof techniques, but there is no explicit consensus on the approach to take.
Participants express uncertainty about the requirements for formal proofs and the specific techniques they should be familiar with. There are indications of missing background knowledge in proofs and theorems relevant to the discussion.
Anne5632
Prove that S which is a subset of R is bounded
S=(n^2-1)/(n^3-1)
S is an element of natural numbers
I know that for a set to be bounded it is bounded above and below, for the bound below is it 0 and n cannot equal 1 and u paper bound is inf but how do I prove that it is bounded?
Anne5632 said:
Homework Statement:: Prove that S which is a subset of R is bounded
Relevant Equations:: S=(n^2-1)/(n^3-1)
Did you try writing down the first few elements in the set to get an idea? I assume we are taking about ##n > 1## here?
the inf of the set is 0 so does that count in the interval?
Yes, it should be clear that for all ##n > 1## we have ##s_n > 0##. ##S## is, therefore, bounded below by ##0##. What about an upper bound?
Anne5632 said:
How do you prove that is the question?
Have you done many proofs?
No I haven't done proofs
I simplified the fraction in the equation given and factorised out (x-1) then got a polynomial to degree one in top and a polynomial to degree 2 on the bottom.
If i want to show it's smaller than 1 should I rewrite 1 into a polynomial with degree 2÷polynomial to degree 2
You can either do a direct proof, which is to show directly that ##\frac{n^2 -1}{n^3 - 1} \le 1##. Or, you can do a proof by contradiction by assuming that for some ##n## we have ##\frac{n^2 -1}{n^3 - 1} > 1## and reaching a contradiction.
Cancelling the common factor of ##n - 1## is an option.
Got the bounds I think , thanks.
Part 4 of that q asked:
Let B be a bounded subset of R. Prove -B + S is bounded from below.
How would I know the bounds of B? Does it have no lower bound?
Let B be a bounded subset of R. Prove -B + A is bounded from below.
What's A?
PeroK said:
What's A?
Sorry meant to write S,
A is the set S described in the question above
First, if ##X## is a bounded subset of ##\mathbb R##, then the set ##-X \equiv \{-x: x \in X\}## is also a bounded subset of ##\mathbb R##.
And, more generally ##X## is bounded above iff ##-X## is bounded below.
Also, if ##X## and ##Y## are bounded above, then the set ##X + Y \equiv \{x+y: x \in X, y \in Y\}## is bounded above. Similarly, if ##X## and ##Y## are bounded below, then so is ##X + Y##.
These are things that I assume you will be shown in your course or asked to prove as an exercise. You need to learn some of the techniques that are used to prove things like this. The proofs are straighforward, but not always easy to see for someone new to formal proofs.
Have you seen anything like this on your course? It seems to me that you are working in the dark here.
No I haven't, and none of the other exercises are similar.
But I'll looks through the theorems in that topic
If we take the first one.
A simple proof of that would be;
Let ##U## be an upper bound for ##X##.
Let ##y \in -X##. Then ##y = -x## for some ##x \in X##. Now ##x \le U \ \Rightarrow \ -x \ge -U##. Hence ##y \ge -U##.
As ##y## was any member of ##-X## we see that ##-U## is a lower bound for ##-X## and so ##-X## is bounded below.
Then you would do something similar for a lower bound ##L##.
That's the style of proof that I assume is required for these problems.
Would the formula
Inf(N)=-sup(-N)
be useful?
Anne5632 said:
Would the formula
Inf(N)=-sup(-N)
be useful?
That result is similar and has the same sort of proof as the one I gave. But, ultimately, pure mathematics isn't about plugging numbers into formulas; it's about being able to construct logically valid proofs.
True,
To find the lower bound of -B I thought I could use that theorem
Anne5632 said:
True,
Well, let's see you attempt to prove it. You haven't actually posted anything yet that gives me any indication of what you can do!
@Anne5632 :
If you've done a bit of Calculus or advanced pre-Calculus, you can consider ##f(x)=\frac {x^2-1}{x^3-1} ## and use standard optimization techniques: Take derivative f'(x), set to 0, etc.
  • · Replies 43 ·
