Is there any approximation to the two particle density matrix
The discussion revolves around the two-particle density matrix in quantum field theory, specifically the expression involving field operators. Participants explore the nature of this expression, whether it can be considered a density matrix, and the implications of its interpretation.
  • Some participants assert that the expression < \phi^{\dagger} (x) \phi^{\dagger} (y) \phi(y) \phi (x) > is indeed a density matrix, while others argue it is simply a number.
  • One participant references a specific paper (Phys Rev B, Vol 71, 165104) to support their claim about the two-particle density matrix.
  • There is a contention regarding the terminology used, with some insisting that the expression does not satisfy the properties of a density matrix, such as being hermitian and non-negative.
  • Participants discuss the implications of using operator-valued distributions and how they relate to the concept of a density matrix.
  • Some participants suggest that perturbation theory might provide an analytic approximation for the two-particle density matrix.
There is no consensus on whether the expression can be classified as a density matrix. Participants present competing views on its interpretation and properties, leading to an unresolved discussion.
Participants highlight limitations in terminology and the need for clarity regarding the mathematical properties of the discussed expressions. The discussion reflects varying interpretations of density matrices in quantum field theory.
chuckschuldiner
Let phi(x) and phi_dagger(x) be field operators which satisfy the appropriate commutation relations.
Then is there any analytic approximation for the two particle density matrix given by
<phi_dagger(x)phi_dagger(x')phi(x')phi(x)>
Thanks!
\langle \phi^{\dagger} (x) \phi^{\dagger} (y) \phi(y) \phi (x) \rangle
I'm not thinking this morning - this is a density matrix?
Hi
The author calls it the two particle density matrix. The reference is Phys Rev B, Vol 71, 165104 (2005)
The page number is 165104-3
It most certainly is the field operator version of the density matrix. By the way, this fact has to do with why I called the state |0><0| the "vacuum" in the discussion on the "superposition and kets":
https://www.physicsforums.com/showthread.php?t=124904
The best reference I've seen for explaining why this is the case is Julian Schwinger's "Quantum Kinematics and Dynamics", which is a small classic paperback book that is available cheaply at most good physics bookstores and also on Amazon.
Carl
NO, It is a number, a single number. It is neither a density nor a matrix.
the phi's are operator-valued distributions, putting them inside < |...| > gives you a number.
regards
sam
Note from Hurkyl: I fixed the formatting tags so that this will display properly[/color]
Depending on the theory, perturbation theory...? And yeah, it's an amplitude not a density matrix.
samalkhaiat said:
NO, It is a number, a single number. It is neither a density nor a matrix. The phi's are operator-valued distributions, putting them inside < |...| > gives you a number.
See, for example, equation (5) of:
http://arxiv.org/abs/nucl-th/9508008
No reason to argue over terminology. And \rho(x,x&#039;) is a lot more complicated than just a number.
Carl
Carl, I know one or two things about the density matrix, so you don't need to point a "reference" to me :smile:
A physically acceptable (unique, hermitian & non-negative) density matrix must satisfy;
1) &lt;\hat{A}&gt; = Tr(\rho\hat{A})
2) the quantum Liouville equation;
i\partial_{t} \rho (x,x&#039;;t) = [H,\rho (x,x&#039;;t)]
So, Carl, be kind and show us how YOU prove that the talked about expession satisfies (1) & (2) ?
I am aware that some people who work on many-particle systems, non-relativistic field theory, DO , occasionally, call;
&lt;\psi^{\dagger}(\vec{x},t)\psi(\vec{x&#039;},t)&gt;_{0}
(in Heisenberg picture)
or,
&lt;\psi^{\dagger}(\vec{x})\psi(\vec{x&#039;})&gt;_{t}
(in Schrödinger picture)
a one-body density matrix!
Well, they are wrong, because these expressions are C-numbers. As such they do not satisfy (1) & (2).
Indeed, from (1) we see that these expressions are equal to;
Tr(\rho_{0}\psi^{\dagger}(x,t)\psi(x&#039;,t))=Tr(\rho_{t}\psi^{\dagger}(x)\psi(x&#039;))
where the density matrix;
\rho(t) = exp(-iHt) \rho(0) exp(iHt)
does satisfy the quantum Liouville equation (2).
Don't ask me why, but even the number-density operator
n(\vec{x})=\psi^{\dagger}(\vec{x})\psi(\vec{x})
sometimes is called (by similar people) a density matrix!
I believe, it is a simple case of misuse of language, because these people do a fine work and make use of
&lt;n(\vec{x})&gt; = Tr \Left(\rho\psi^{\dagger}\psi\Right)
in their work!
regards
sam
  • · Replies 21 ·
