Is this a reliable way to determine the alcohol %?
  • Context: Undergrad
  • Thread starter Thread starter LennoxLewis
    Alcohol
The discussion centers on using freezing point depression to estimate the alcohol percentage in a whiskey-water mixture. The experiment indicated that a 1:1 mixture of whiskey (40% alcohol) and water froze at approximately -22 to -17 degrees Celsius, suggesting a theoretical freezing point of -23 degrees Celsius for the mixture. However, the reasoning is challenged due to the non-linear behavior of binary mixtures during phase transitions, with phase separation potentially occurring. Alternative methods for determining alcohol content, such as measuring density, are also proposed.
  • Understanding of freezing point depression in solutions
  • Knowledge of phase transitions in binary mixtures
  • Familiarity with density measurements and their implications
  • Basic principles of alcohol and water mixtures
  • Research the principles of freezing point depression in solutions
  • Study the phase behavior of binary mixtures, particularly alcohol-water systems
  • Learn how to accurately measure density and its application in determining alcohol content
  • Explore alternative methods for measuring alcohol concentration, such as distillation or hydrometry
Individuals interested in home brewing, mixology, or anyone seeking to understand the physical properties of alcohol-water mixtures and their measurement techniques.
LennoxLewis
Alcohol (ethanol) has a freezing point of -114 degrees celsius. Can this be used to determine the alcohol percentage in a drink?
Last week i put a glass of whiskey mixed with some water (about 1:1) and the surface was just frozen after i left it a night in the freezer, which was somewhere between -22 and -17 degrees celsius (i didn't take an accurate reading because i just wanted it to be really cold).
So, given that whiskey has about 40% alcohol, the total theoretical percentage is about 20%, which means the freezing point of this "cocktail" is (0.2 * -114 + 0.8 * 0) = -23 degrees celsius. Although not very practical because you're bound to a certain temperature range and it's hard to decrease the temperatur step-by-step, is this reasoning correct? The small experiment indicates so..
By the way, I've placed this one in the physics and not chemistry forum because it only deals with freezing points and volume ratios. Admin, feel free to move it if necessary.
Science news on Phys.org
Sorry, but this seems to be wrong. Binary mixes behave very "non linear" when it comes to phase transitions see http://en.wikipedia.org/wiki/Eutectic What you have discovered seems to be more of a phase separation, where some water freezes out leaving the rest of the liquid with a higher alcohol concentration.
Water alcohol mixes might be some special case though, where the "hanging part" of the transition line is very flat, and your idea could work, but then I would expect no phase separation but the whole mix to freeze solid.
I see. Is there an other physical (not chemical) way to determine the alcohol level? Counting the number of glasses that gets me smashed doesn't count!
The first thing that came to my mind was weighing it and using the known densities. Ethanol is 0.789 g/mL. This would be a problem though if there were other things besides ethanol and water. But I suppose you could find the density of pure whiskey yourself first, then use that to figure out how much of the mixture is added water.
  • · Replies 17 ·
39K
13K
  • · Replies 67 ·
16K
  • · Replies 19 ·
9K
