Is this analytically solvable?
  • Thread starter Thread starter Poirot
2 replies · 2K views
Poirot
I am trying to solve integrals of the form:
## \int_{-\infty}^{\infty} \frac{k}{k-1} e^{itk^2}e^{ikx}e^{-(k-k_0)^2/\alpha^2} dk \\
\int_{-\infty}^{\infty} \frac{1}{k-1} e^{itk^2}e^{ikx}e^{-(k-k_0)^2/\alpha^2} dk ##
A bit of background:
I'm trying to create an animation in Mathematica to show a gaussian wave packet passing through a delta potential. The fractions at the start of the integrals come from the transmission and reflection coeffecients such that
##\phi_k(x) = \left\{
\begin{array}{ll}
e^{ikx} + R_k e^{-ikx} & \quad x < 0 \\
T_k e^{ikx} & \quad x > 0
\end{array}
\right.##
so Rk and Tk are the fractions at the start then we multiply the phi(x) by a time dependent part and then the gaussian part and integrate for the linear superposition.
The overall integral is
##\int_{-\infty}^{\infty} \phi_k(x) e^{-(k-k_0)^2/\alpha^2} e^{-i\hbar k^2 t/2m} dk \\
R_k =\frac{1}{\frac{\hbar^2ik}{sm} -1} \\
T_k =\frac{1}{1-\frac{sm}{\hbar^2ik}} ##
where s is the strength of the delta potential such that:
V(x) = s\delta(x) ##
and I've set virtually every constant to 1 (except k0 and alpha which I plan to toggle once I get something).
3. The Attempt at a Solution
I'm told these integrals should be possible analytically but I can't see how. I've also tried using mathematica to compute it but it's having trouble with the function not converging on the interval. I've tried using NIntegrate too but I think the fact there's factors of x and t in the integrand is causing issues when trying to get a numerical approximation.
It might be worth mentioning that I've managed to solve the integral for the the e^(ikx) part for x<0 using completing the square but I can't see how to do it with the fraction.
Any help or guidance would be greatly appreciated thank you!
It seems that Mathematica can calculate
FourierTransform[ Exp[I t k^2] Exp[-(k - k0)^2/\[Alpha]^2] , k, x]
and
FourierTransform[k/(k - 1) , k, x]
but it chokes on the whole thing.
Maybe you can do something with the convolution theorem to combine them?
Let ##f(k) = \exp(i t k^2 + i x k - (k-k_0)^2/ \alpha^2)##. If you can get ##\int_{\mathbb{R}} f(k) \, dk## and ##\int_{\mathbb{R}} k f /(k-1) \, dk##, then you an get ##\int_{\mathbb{R}} f/(k-1) \, dk## because ##1/(k-1) = (1-k + k)/(k-1) = k/(k-1) - 1.##
