Is Tritium-Tritium Fusion the Key to Sustainable Energy?
  • Thread starter Thread starter BrianConlee
    Fusion
Tritium-Tritium (T-T) fusion is rarely discussed compared to Deuterium-Tritium (D-T) fusion due to its lower productivity and higher energy requirements. While T-T reactions can occur in a D-T plasma, their cross-section is significantly smaller, resulting in minimal contribution to overall energy production. The limited availability of tritium also poses a challenge for T-T fusion to be considered a viable alternative. Some participants speculate that if tritium resources were abundant, T-T fusion could be more favorable, but current scientific consensus favors D-T fusion for its efficiency. Overall, T-T fusion remains a less practical option in the pursuit of sustainable energy.
BrianConlee
I've been looking for information on this but can't seem to find any...
So I come to this wonderful place to find answers :)
Everything I read about fusion power talks about D-T fusion being the ideal.
I have two questions:
1. Why isn't a T-T reaction ever discussed? (does it happen anyway in a 50-50 D-T plasma?)
2. Tritium is a very limited resource at the moment, so if this limitation was over come, would it be a more ideal reaction then D-T?
Thanks
IIRC the D-T reaction requires a lower energy to start. Other reactions need higher energy.
Not sure but the T-T reaction might not be very productive one compared to D-T or D-D so that may be why its not being looked at.
Because it can't be done (yet).
Even D-T are too hard to get to start, imagine T-T. That's why.
But Curl, following the logic of D-t being a lot easier that D-D, (that much easier than proton proton) due to the larger cross section: A T-T would have an even larger cross section than a D-T with the same amount of positive charge repulsion?
When I "imagine T-T," I'm imagining T-T being easier than D-T.does anyone know where I might find specific info on this type of reaction?
D-T fuses into Helium5 which almost instantly goes to Helium 4 and a neutron.
So, let's take that a step further with T-T fusion...
Would it go to Helium 6? If this happened, the Helium 6 atom would beta decay to a Lithium 6... which itself could produce a Tritium atom if it encountered another Neutron...
To me, that sounds like the reaction is coming full circle in a way, give or take a couple neutrons.
Of course, in a 50/50 D/T plasma, the T-T reaction does occur, giving T+T -> alpha + 2 n +11.3 MeV. However, the cross section for this reaction is many orders of magnitude smaller than the D+T reaction, so it doesn't contribute much to the overall energy production, which is why you don't see it talked about much.
Here's a reference:
www.oup.co.uk/pdf/0-19-856264-0.pdf[/URL]
phyzguy,
thank you so much, this resource is wonderful!
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
