The Importance of Voltage in Electrical Components
  • Thread starter Thread starter tkahn6
    Important Voltage
The voltage across electrical components, such as LEDs, is crucial for their proper operation. For instance, an LED rated at 2.1V and 20mA indicates the forward voltage and maximum current it can handle. Connecting an LED to a voltage higher than its rated forward voltage without a current-limiting resistor can significantly reduce its lifespan. Understanding voltage is essential for applications like determining how many LEDs can be connected in series with a given power supply.
  • Basic understanding of electrical components, specifically LEDs
  • Knowledge of Ohm's Law and its application in circuit design
  • Familiarity with current-limiting resistors and their importance
  • Understanding of voltage, current, and resistance relationships
  • Research LED forward voltage specifications and their implications
  • Learn about current-limiting resistor calculations for LED circuits
  • Explore the differences in voltage requirements for various colored LEDs
  • Investigate the use of constant current power circuits for LED applications
Electronics enthusiasts, hobbyists working with LED circuits, and engineers designing lighting solutions will benefit from this discussion.
tkahn6
I suspect this is a very stupid question but:
Why is voltage across a component (say, an LED) important? Isn't current the only important factor?
If it says on the package 2.1V, 20mA. What does this mean?
Does it not matter if I connect it to a voltage of 5V over 250Ω or 3V over 150Ω?
Thanks guys!
I believe the 2.1v would be the forward voltage, the voltage the LED will run at when it's limited at 20mA, like if you used a constant current power circuit. Check this site http://led.linear1.org/1led.wiz for a nice LED calculator.
20ma is the max current rating of the diode. If you do not limit diode current to less then 20ma the life of the diode will be seriously compromised.
The voltage across a LED when it is operating is very important.
It tells you how many LEDs you can put in series across a 12 volt supply to make Christmas lights, for example.
It tells you if you could power the LED from a single 1.2 volt NiCd battery.
You have to put limiting resistors into limit the current, of course, and if you have plenty of voltage to spare, you only have to worry about the current. But it is those times when you are trying to run something off a low voltage when it really matters how much voltage is across each LED.
Also, different coloured LEDs have different voltages across them, so a colour that will not work could be replaced by one that will.
First the voltage definition is the potential difference between two ends. the current is the flow of the electrons. let me tell you some simple example think about the over head tank - the voltage is the pressure difference between tank and the tap but current can be compared with flow of the water. without potential difference (voltage) the flow of electron (current) can not exist.
  • · Replies 25 ·
  • · Replies 47 ·
  • · Replies 16 ·
