Is X^M-N the Minimal Polynomial of Irrational Root \sqrt[M]{N} in \mathbb{Q}[X]?
The discussion revolves around the minimal polynomial of the irrational root \(\sqrt[M]{N}\) in the context of polynomials over the rational numbers \(\mathbb{Q}[X]\). Participants explore conditions under which \(X^M - N\) serves as the minimal polynomial, examining various cases and counterexamples.
  • One participant asserts that \(X^M - N\) is the minimal polynomial of \(\sqrt[M]{N}\) under the assumption that \(\sqrt[M]{N}\) is irrational, but struggles to prove this claim.
  • Another participant provides a specific example, \(\sqrt[4]{4}\), suggesting that \(X^2 - 2 = 0\) is relevant to the discussion.
  • Some participants propose that the minimal polynomial holds true when \(M\) is a prime number or when \(N\) has a square-free prime factorization, while questioning if there are simpler conditions.
  • It is noted that if \(M\) is not a power of 2, the polynomial must have a linear factor, implying a rational root, which leads to a contradiction.
  • Counterexamples are introduced, such as \(\sqrt[9]{9}\), which challenge the assertion that \(X^M - N\) is always the minimal polynomial, particularly when \(M\) is composite and \(N\) is an \(n\) power where \(n\) divides \(M\).
  • Participants discuss the implications of different values of \(M\) and \(N\) on the minimal polynomial, suggesting that \(X^M - N\) may not be minimal if there exist \(M' < M\) and \(N' < N\) such that \(\sqrt[M]{N} = \sqrt[M']{N'}\).
  • Several participants shift the discussion towards proving the independence of certain irrational combinations, exploring polynomial relationships and vector space dimensions over \(\mathbb{Q}\).
Participants express differing views on the conditions under which \(X^M - N\) is the minimal polynomial, with no consensus reached. The discussion includes multiple competing perspectives and examples that challenge the initial claim.
Participants highlight the complexity of the problem, noting that assumptions about the nature of \(M\) and \(N\) significantly affect the validity of the claims regarding minimal polynomials. The discussion also touches on the implications of polynomial factorization and the existence of rational roots.
jostpuur
Assume that \sqrt[M]{N} is irrational where N,M are positive integers. I'm under belief that
<br /> X^M-N<br />
is the minimal polynomial of \sqrt[M]{N} in \mathbb{Q}[X], but I cannot figure out the proof. Assume as an antithesis that p(X)\in\mathbb{Q}[X] is the minimal polynomial such that \partial p &lt; M.
We can divide X^M-N by p(X) and obtain
<br /> X^M-N = q(X)p(X) + r(X)<br />
where \partial r &lt; \partial p. According to the assumption, r=0 must hold.
So I'm somehow supposed to use the information X^M-N=q(X)p(X) and r=0 and find a contradiction.
Doesn't look very obvious to me.
\sqrt[4]{4}?
##X^2-2=0##
I had never really thought about this. All I know is that it will be true when M is a prime number, or if N is a number with a square-free prime factorization ( use eisenstein's ). I don't if there are easier conditions
edit: also, I think it will be true if M is not a power of 2. Over Q, you can factorize your polynomial into irreducibles that are either linear factors of x^2 + n terms, where n is a positive integer. If M is not a power of 2, then you must have a linear factor in such a decomposition. Then, the polynomial must have a rational root. But it is easy to see that it cannot, since this is a monic polynomial with coefficients in Z. Any rational root of these polynomials must themselves be in Z
No, being a power of 2 is not relevant. For example, the ninth root of 9, \sqrt[9]{9} is a zero of x^3- 3. This will be false whenever M is a composite number and N is an n power where n divides M.
some linear combinations of irrationals
Well at least I was careful enough to mention that I was "under belief"...
I'll hijack my own thread to a new topic. I have so many questions with similar themes, so I guess I might as well concentrate them here...
I want to prove that there does not exist coefficients a_1,a_2,a_3,a_4\in\mathbb{Q} such that
<br /> a_1 + a_2\sqrt{2} + a_3\sqrt{3} + a_4\sqrt{6} = 0<br />
without all coefficients being zero. How does that happen?
I have a feeling that the proof might have something to do with polynomials
<br /> p(X_1,X_2) = (X_1^2-2)^2 + (X_2^2-3)^2<br />
and
<br /> a(X_1,X_2) = a_1 + a_2X_1 + a_3X_2 + a_4X_1X_2<br />
which would both satisfy p(\sqrt{2},\sqrt{3})=0 and a(\sqrt{2},\sqrt{3})=0, but I'm not sure what's the final trick.
I think I would consider ##(b_1+b_2\sqrt{2}+b_3\sqrt{3})^2##. It gives all 4 different terms, and if the bracket cannot be rational the square of it cannot be rational either.
If I first fix arbitrary a_1,a_2,a_3,a_4\in\mathbb{Q}, you are not going to find b_1,b_2,b_3\in\mathbb{Q} such that they would map to the a_1,a_2,a_3,a_4 through that square.
My question is equivalent to asking that how do I prove that \mathbb{Q}(\sqrt{2})(\sqrt{3}) is two dimensional vector space with respect to the scalar field \mathbb{Q}(\sqrt{2}). Does this remark help those who know the theory?
<br /> \mathbb{Q}(\sqrt{2})(\sqrt{3}) = \big\{x_1+x_2\sqrt{3}\;\big|\;x_1,x_2\in\mathbb{Q}(\sqrt{2})\big\}<br />
It looks like two dimensional, but it's not obvious that non-zero x_1,x_2\in\mathbb{Q}(\sqrt{2}) wouldn't exist so that x_1+x_2\sqrt{3}=0.
a_1 does not have to match, as my expression is not supposed to be 0. You can write it on the RHS.
I invented one proof on my own now. I can assume that a_1,a_2,a_3,a_4\in\mathbb{Z}. Equations
<br /> (a_1 + a_2\sqrt{2})^2 = (a_3\sqrt{3} + a_4\sqrt{6})^2<br />
and
<br /> (a_1 + a_3\sqrt{3})^2 = (a_2\sqrt{2} + a_4\sqrt{6})^2<br />
eventually imply
<br /> 2a_2^2 = 3a_3^2<br />
which then implies a_2=\pm\infty and a_3=\pm\infty when you work out how 2^n divides these coeffients with arbitrarily large n.
No, no, mfb, you'r idea aint working.
<br /> (b_1 + b_2\sqrt{2} + b_3\sqrt{3})^2 = b_1^2 + 2b_2^2 + 3b_3^2 + 2b_1b_2\sqrt{2} + 2b_1b_3\sqrt{3} + 2b_2b_3\sqrt{6}<br />
So you were thinking, that once a_2,a_3,a_4\in\mathbb{Q} were fixed, you could find b_1,b_2,b_3\in\mathbb{Q} such that
<br /> a_2 = 2b_1b_2<br />
<br /> a_3 = 2b_1b_3<br />
<br /> a_4 = 2b_2b_3<br />
These equations actually fix b_1,b_2,b_3 uniquely, and they can be solved. The answer is
<br /> b_1=\sqrt{\frac{a_2a_3}{2a_4}}<br />
<br /> b_2=\sqrt{\frac{a_2a_4}{2a_3}}<br />
<br /> b_3=\sqrt{\frac{a_3a_4}{2a_2}}<br />
We see they can be irrational too.
Actually
<br /> (\sqrt[9]{9})^3 = 3^{\frac{2}{3}} \neq 3<br />
:wink:
\sqrt[9]{27} would be a zero of X^3-3.
Anyway, it's clear that \sqrt[M]{N}=\sqrt[M&#039;]{N&#039;} often holds while M\neq M&#039; and N\neq N&#039;. It still seems reasonable, that X^M-N will turn out to be the minimal polynomial of \sqrt[M]{N} if there does not exist M&#039;&lt;M and N&#039;&lt;N such that \sqrt[M]{N}=\sqrt[M&#039;]{N&#039;}.
Okay. I did not check it in detail, it was just an idea.
Your proof is nice.
  • · Replies 16 ·
  • · Replies 28 ·
