Is Zero Curvature Space Equivalent to Flat Space in General Relativity?
The discussion establishes that zero curvature space is not equivalent to flat space in General Relativity, although a flat space is always a zero curvature space. The metric tensor in flat space can be represented as ##g_{\mu\nu}(x) = \eta_{\mu\nu}## in certain coordinate systems, but this representation is not universally valid across all coordinate systems. The Riemann curvature tensor must be zero for a space to be classified as flat, and this property is invariant under coordinate transformations. The conversation emphasizes that while the metric may change, the underlying geometry remains unchanged.
  • Understanding of Riemann curvature tensor and its implications in General Relativity
  • Familiarity with metric tensors and their representations in various coordinate systems
  • Knowledge of coordinate transformations and their effects on geometric properties
  • Basic grasp of parallel transport and its significance in curved spaces
  • Study the properties of the Riemann curvature tensor in various geometries
  • Learn about different coordinate systems used in General Relativity, such as Schwarzschild and Eddington-Finkelstein coordinates
  • Explore the concept of parallel transport and its role in defining curvature
  • Investigate the implications of coordinate transformations on metric tensors and curvature invariants
Physicists, mathematicians, and students of General Relativity seeking to deepen their understanding of the relationship between curvature and flatness in spacetime, as well as those interested in the mathematical foundations of metric tensors and their transformations.
  • #31
Jianbing_Shao said:
Perhaps I can not express my opnion clearly, what I stressed is just that: to a vector field ##v(x)##, and we can express ##v(x)## using basis ##e^\mu(x)##.then
$$v(x)=v_\mu(x)e^\mu(x)$$
also we can express ##v(x)## using basis ##e'^\mu(x)##, and
$$v(x)=v_\mu(x)e^\mu(x)=v'_\mu(x)e'^\mu(x)$$
then because all the basis ##e^\mu(x)## are coordinate basis, so sometimes when we express ##v(x)## from one basis to another, then the changes of components can not be equivalantly described as change under coordinate transformation
I am sorry, it is impossible to deduce what you are trying to say here. If anything, this post made your argument murkier, not clearer.
  • #32
vanhees71 said:
In 2D just extend @Orodruin 's example of the 1D circle to a 2D cylinder surface :wink:
Actually, as I hinted to in a later post (#17), the cylinder is not as easy to get as the circle as the cylinder does admit a global coordinate system (being homeomorphic to ##\mathbb R^2 \setminus \{0\}##). The problem becomes showing that there is no way to arrange such a global coordinate system such that the metric becomes diagonal with the diagonal entries equal to one.
Edit: Just to be a little more specific. The global coordinate system on the cylinder ##x^2+y^2=r^2_0## as a submanifold of ##\mathbb R^3## using coordinates ##\xi## and ##\eta## on ##\mathbb R^2 \setminus \{0\}## can be constructed as
x = \frac{r_0 \xi}{\sqrt{\xi^2 + \eta^2}}, \quad
y = \frac{r_0 \eta}{\sqrt{\xi^2 + \eta^2}}, \quad
z = \frac{r_0}{2} \ln\left(\frac{\xi^2 + \eta^2}{r_0^2}\right).
Of course, in these coordinates, the induced metric from the embedding in ##\mathbb R^3## does not take the ##\delta## form, but it shows that a global coordinate system exists, making the argument a bit muddier than for the circle.
  • #33
Ibix said:
What do you mean by "it can change" as it goes around the loop? To what are you comparing it?
I know where I was wrong, thanks ! everyone
  • #34
Please tell us. We would like to make sure that you have gotten it right. (It happens more than you would think that people tell us they have gotten it, only to return with similar misconceptions a few days later.)
  • #35
Perhaps it can be stated that not all metric ##g_{\mu\nu}(x)## can globally transform to ##\eta_{\mu\nu}## under coordinate transformation.
  • #36
Another way to start classifying random metrics, and if they're flat, is to look into Petrov classifications if you have not OP.
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 50 ·
  • · Replies 38 ·
