What are the angles of an isosceles triangle with a specific ratio?
  • Context: MHB
  • Thread starter Thread starter anemone
    Challenge Triangle
The discussion focuses on determining the angles of an isosceles triangle ABC where the sides AB and AC are equal, and the ratio of AB to BC is defined as 1 + 2cos(2π/7). The specific mathematical approach involves using trigonometric identities and properties of isosceles triangles to derive the angles. The conclusion emphasizes the relationship between the side lengths and angles, showcasing the unique properties of triangles with such ratios.
  • Understanding of isosceles triangle properties
  • Familiarity with trigonometric functions and identities
  • Knowledge of angle measurement in radians
  • Basic algebra for manipulating equations
  • Study the derivation of angles in isosceles triangles using the Law of Cosines
  • Explore trigonometric identities related to cosine functions
  • Investigate the implications of angle ratios in polygon geometry
  • Learn about the properties of triangles with specific side ratios
Mathematicians, geometry enthusiasts, and students studying trigonometry or triangle properties will benefit from this discussion.
anemone
MHB
POTW Director
Let $ABC$ be an isosceles triangle such that $AB=AC$. Find the angles of $\triangle ABC$ if $\dfrac{AB}{BC}=1+2\cos\dfrac{2\pi}{7}$.
Mathematics news on Phys.org
Write $\alpha$ for the two equal angles in the isosceles triangle, so that the angle at the apex is $\pi - 2\alpha$. By the sine rule, $$\frac{AB}{AC} = \frac{\sin\alpha}{\sin(\pi - 2\alpha)} = \frac{\sin\alpha}{\sin( 2\alpha)} = \frac{\sin\alpha}{2\sin\alpha\cos\alpha} = \frac1{2\cos\alpha}.$$ Now for a bit of trigonometry: $$\begin{aligned} \sin(3\theta) = \sin(2\theta+\theta) &= \sin(2\theta)\cos\theta + \cos(2\theta)\sin\theta \\ &= 2\sin\theta\cos^2\theta + \cos(2\theta)\sin\theta = \sin\theta(2\cos^2\theta + \cos(2\theta)) = \sin\theta(1 + 2\cos(2\theta)) \end{aligned}$$ (because $2\cos^2\theta = \cos(2\theta) + 1$). Therefore $1+ 2\cos(2\theta) = \dfrac{\sin(3\theta)}{\sin\theta}.$ In particular, with $\theta = \frac\pi7$, $$1 + 2\cos\tfrac{2\pi}7 = \frac{\sin\frac{3\pi}7}{\sin\frac{\pi}7} = \frac{\sin\frac{3\pi}7}{\sin\frac{6\pi}7} = \frac{\sin\frac{3\pi}7}{2\sin\frac{3\pi}7\cos\frac{3\pi}7} = \frac1{2\cos\frac{3\pi}7}.$$ It follows that if $$\frac{AB}{AC} = 1 + 2\cos\tfrac{2\pi}7$$ then $$ \frac1{2\cos\alpha} = \frac1{2\cos\frac{3\pi}7}$$, so that $\alpha = \frac{3\pi}7$. Thus the angles of the triangle are $\frac{3\pi}7$, $\frac{3\pi}7$ and $\frac\pi7$.
Bravo, Opalg!(Cool)
