Iterative Minimization lemma proof
The discussion revolves around the iterative minimization of a real-valued function f(x) without explicit conditions on continuity. Participants are examining the lemma that states when the next point x^k is constructed using an optimal step size, the gradient at that point in the direction of descent should equal zero. The context involves differentiating the function along a descent direction to find optimal values.
  • Participants discuss differentiating the function f(x^{k-1} + \alpha d^k) with respect to α, expressing confusion about differentiating an undefined function. Some suggest visualizing the arguments of f and applying the chain rule. Others question the assumptions regarding the differentiability of f and its implications for the lemma.
The discussion is active, with participants exploring various interpretations of the problem and sharing insights on differentiation techniques. Some guidance has been offered regarding the application of the chain rule and the nature of the function being minimized, but no consensus has been reached on the proof of the lemma.
There is a mention of the function being quadratic in form, which may clarify some assumptions about differentiability that were initially questioned. Participants are also considering the implications of the function's behavior for different values of α.
rayge
[itex]f(x)[/itex] is the function we want to minimize. Beyond being real-valued, there are no other conditions on it. (I'm surprised it's not at least continuous, but the book doesn't say that's a condition.) We choose the next [itex]x^k[/itex] through the relation [itex]x^k = x^{k-1} + \alpha_{k}d^k[/itex]. We assume [itex]d^k[/itex] is a descent direction. That is, for small positive [itex]\alpha[/itex], [itex]f(x^{k-1} + \alpha d^k)[/itex] is decreasing.
Here's the lemma we want to prove:
When [itex]x^k[/itex] is constructed using the optimal [itex]\alpha[/itex], we have [itex]\nabla f(x^k) \cdot d^k = 0[/itex]
It's suggested in the book that we should differentiate the function [itex]f(x^{k-1} + \alpha d^k)[/itex] with respect to [itex]\alpha[/itex]. My problem is that I don't know how to differentiate a function that isn't defined. My first guess went something like this, but I don't see how I'm any closer to a solution.
[tex]\frac{\partial}{\partial \alpha} f(x^{k-1} + \alpha d^k) = \frac{\partial}{\partial \alpha} f(x^k)[/tex]
[tex]f'(x^{k-1} + \alpha d^k)d^k = f'(x^k)(0)[/tex]
[tex]f'(x^{k-1} + \alpha d^k)d^k = 0[/tex]
I'm really not looking for an answer, but if someone could point me to where I could learn about taking differentials of undefined functions that would be helpful. I'm guessing that somehow I can extract a gradient out of this, and a dot product, but I'm feeling pretty confused.
If you're expected to differentiate [itex]f[/itex] it would have to be differentiable, hence continuous.
You didn't say what [itex]x^k[/itex] is. I assume it is a vector. For example, [itex]x^k = ( {x^k}_1, {x^k}_2 )[/itex]
Visualize all the arguments of [itex]f[/itex] . For example [itex]f( {x^{k-1}}_1 + \alpha {d^k}_1, {x^{k-1}}_2 + \alpha {d^k}_2)[/itex]
Things might look more familiar In different notation. If we have a real valued function [itex]f(x,y)[/itex] of two real variables [itex]x,y[/itex] and [itex]X(\alpha), \ Y(\alpha)[/itex] are real valued functions of [itex]\alpha[/itex] then
[itex]\frac{df}{d\alpha} = \frac{\partial df}{dx}\frac{dX}{d\alpha} + \frac{\partial df}{dy} \frac{dY}{d\alpha}[/itex]
[itex]= \nabla f \cdot (\frac{dX}{d\alpha},\frac{dY}{d\alpha})[/itex]
Taking derivatives does not make sense unless ##f## is differentiable, so automatically continuous---in fact, even smoother than continuous. Maybe the book does not say that, but it is part of the reader's assumed background. Furthermore (just to be picky), expressions like ##\nabla f(x^k) \cdot d^k## depend on even more smoothness: ##f## must be continuously differentiable (not just plain differentiable). If the book does not make this clear, that is a flaw; it should definitely cover these points somewhere.
BTW: the stated result is false if ##f## is not continuously differentiable; there are some easy counterexamples.
Actually it is made clear in the beginning on the chapter that we're dealing with quadratic functions of the form [itex]f(x) = \frac{1}{2}\|Ax - b\|^2_2[/itex]. My fault for not reading closely enough.
OK, but the result is actually true for any continuously-differentiable ##f##.
Good to know, thanks. I applied the chain rule as suggested, and got:
[tex]\frac{d f(x^{k-1} + \alpha d^k)}{d\alpha} = \nabla f \cdot d^k[/tex]
From here, it seems reasonable that [itex]\frac{d f(x^{k-1} + \alpha d^k)}{d\alpha} = 0[/itex] is our optimal value but I don't know how to prove that from our assumptions. For small [itex]\alpha[/itex], [itex]f(x^{k-1} + \alpha d^k)[/itex] is decreasing. For large enough [itex]\alpha[/itex], I think [itex]f(x^{k-1} + \alpha d^k)[/itex] is increasing (i.e. we pass by the optimal point). I just don't have a solid grasp on how the function works, and assuming it's increasing for large [itex]\alpha[/itex], why that is the case.
Thanks again.
Thanks again.
You are searching for a minimum along a line, so you are trying to minimize a univariate function ##\phi(\alpha)##, which just happens to be of the form
[tex]\phi(\alpha) = f(x^{k-1} + \alpha d^k)[/tex]
for some vector constants ##x^{k-1}, d^k##. How do you minimize functions of one variable?
Thanks again.
I see that my previous response did not deal with all of your question. I cannot supply too many details without violating PF helping policies, but I can give a hint. In your specific case you have ##f(\vec{x}) = || A \vec{x} - \vec{b}||^2##. So letting ##\vec{y} = A \vec{x}^k - \vec{b}## and ##\vec{p} = A \vec{d}^k##, we have that ##\phi(\alpha) = f(\vec{x}^k + \vec{d}^k \alpha)## has the form ##\phi(\alpha) = ||\vec{y} + \alpha \vec{p}||^2 = a + b \alpha + c \alpha^2##. How do you find ##a, b, c##? Given that ##\vec{d}^k## is a descent direction, what does this say about the values or signs of ##a,b,c##? What do these signs say about the behavior of ##\phi(\alpha)##?
