stevendaryl said:
I don't understand what issue you are talking about. What are you claiming is not well-defined in this approach?
The comparison with perturbation theory is not appropriate, because perturbation theory is about approximating a solution by using a power series. The Bohmian approach isn't an approximation, or at least, it isn't assumed to be
The only thing I claim is I don't know what the math that backs up this funride is. The stuff you posted I've already read about - the point is not
what the theory is, but
why it is interpreted the way it is; you see, in my small-minded world view there are two things that describe the universe:
classical trajectories (CTs) and
quantum probability (densities) (QPDs); but as Demystifier puts it:
Demystifier said:
Trajectories are calculated from the velocity equal to the gradient of the phase of the wave function. The point of this is not to calculate a correction to classical trajectories. The fundamental thing are quantum trajectories, which sometimes are not even close to the classical ones.
If one uses this theory simply to define what one means by a quantum trajectory (QT), rather than trying to establish some kind of connection to the classical ones, then what's the point? Physics is either about CTs or QPDs, there's no middle ground (unless, of course, one bothers to ellaborate); defining some kind of hybrid with no parallel to those physical objects seems rather pointless - I dare say, from the depths of my ignorance, vacuous. I ask the mathematician within: where does a QT live? I know where CTs do - phase space - , as well as vector states - Hilbert space - , but what of the QTs ? In all material I read, never once this topic was discussed (of course, maybe it exists and I simply missed it), and, though the connection between QM and CM is far from established, we have many pointers of what it is about, including (semi-)classical limiting processes.
Also, I believe the analogy with perturbation theory is appropriate because of this view I've been defending here: a sensible interpretation ought to be based on (what I believe) is common ground to all physicists, CTs and QPDs, and the scheme I sketched, in the spirit of that idea, tries to define a limiting process QT → CT so that one recuperates familiar objects from a unconventional reasoning/thinking/interpretation/structure, at the least. But bear in mind, I make no claim for the correctness of it either - far from it; haven't touched upon questions of convergence, or even well-definiteness. I've only used it as a meta-counterexample, to query about the mathematical state of this interpretation. In this sense, the comparison with perturbation methods is only in the broadest sense, as the successive "corrections" aren't guaranteed to be well-behaved in any respect, or bear any strict formal similarity with Born series or the like.
But I think I demonize myself, by doing what I did not set out to do (debate phylosophy in this forum); as to not drag you into this mire any further, perhaps I should close up shop, just asking for any info you might have on alternate views of Bohmian mechanics (same eqs., different interpretations) and/or (specially) a rigorous mathematical formalism (there should exist one at least as rigorous as standard QM). Which is what I set out do. TYVMFYT.
