I've Got a Problem with Windows XP On My Notebook Here
  • Thread starter Thread starter eNtRopY
    Windows
The discussion centers on a malfunctioning scroll bar on a built-in touchpad mouse of a notebook running Windows XP. The user initially resolved the issue by reinstalling the mouse driver, but the problem recurred after a few days. Suggestions include checking the mouse software configuration, ensuring the correct settings for the touchpad scroll area, and considering the possibility of a buggy driver or corrupted Windows installation. Users recommend using an external mouse as a temporary solution while troubleshooting the issue.
  • Understanding of Windows XP operating system
  • Familiarity with touchpad mouse configurations
  • Knowledge of driver installation and troubleshooting
  • Basic skills in navigating Windows settings
  • Research how to configure touchpad settings in Windows XP
  • Learn about updating and reinstalling device drivers in Windows XP
  • Investigate common issues with touchpad hardware and software
  • Explore methods for troubleshooting corrupted Windows installations
This discussion is beneficial for notebook users experiencing touchpad issues, IT support personnel troubleshooting hardware problems, and anyone seeking to optimize their Windows XP experience.
eNtRopY
Computerphiles:
Okay, there is something a bit fvcked up happening with my notebook computer. The scroll-bar on the built-in mouse doesn't work. This happened a few days after I got the notebook; so, I reloaded the mouse driver, and it worked again. Eventually, however, it went back to not working.
I am running this machine on Windows XP on this machine.
Thanks.
eNtRopY
Computer science news on Phys.org
Creak open the old wallet whip out 30 bucks and spring for an external wheeled mouse.
Scroll bar on built in mouse...what kinda laptop is it? Touchpad design?
Is it a scroll button or a slider-type-thingie? Or is it one of those touchpads where you can designate a portion of the pad as a scrollslider?
Ext. mouse will help you out, but it's odd that it works for a while then quits. Did you install/remove anything between the new driver install and the point when it stopped working?
Yes, it is one of those touch pad mouses with a touch pad scroll bar on the side. The only thing I installed since reinstalling the driver was MikTeX.
eNtRopY
Have you checked within the mouse software to make sure it is still configured correctly? I think I know the software you would be using, and normally you can set the amount/size of the scroll section of the touchpad, as well as the sensitivity. Sometimes fooling around with these options will help. Just go poking around, chaging one or two options at a time so you can always go back and undo em if needed.
If not that, the only thing I can think of is a buggy driver or a corrupted windows install. If it is a big pain to skip using the scroll, or to use an external mouse, track down the most up to date drivers (although I think you mentioned you did) or reinstall windows.
Good luck!
Try this, (I'm working with Win2000, so the procedure to get there may be different) right click on the desktop and select "Properties" from the menu. then press the "Advanced" button at the bottom of the screen. Select the "Troublshooting" tab. You should see the "Hardware Acceleration" slider; if you don't, go to your help screen and look up "Hardware Acceleration." Each notch has a particular thing that it does. One of the notches gives control of the mouse to windows and removes it from the graphics card. If this helps, then your graphics card or driver is probably the problem.
9K
  • · Replies 39 ·
  • · Replies 123 ·
19K
