Java Automobile class method requires String argument
  • Topic: Java
  • Thread starter redskins21
    Class Java
2 replies · 4K views · last reply
redskins21
Hello,
I am trying to figure out what I did wrong and I couldn't figure it out.
here is the error code:
setMake(java.lang.String) in Automobile cannot be applied to ().
Class file:
import java.util.Scanner;
public class Automobile
private int num; //number of automobiles to describe
private String make; //make of automobile
private String color; //color of automobile
public void setIteration()
Scanner stdIn = new Scanner(System.in);
System.out.print("How many cars do you want to consider: ");
this.num = stdIn.nextInt();
this.make = setMake("body");
this.color = setColor("paint");
}//end constructor
public void printColor()
System.out.println(this.color);
public void printMake()
System.out.println(this.make);
private String setMake(String makeType)
String make;
do
System.out.print("Select Buick, Chevrolet, or Pontiac (b,c,p): ");
make = stdIn.nextLine();
if (make.charAt(0) != 'b' || make.charAt(0) != 'g' || make.charAt(0) != 'p');
else
System.out.print("The only valid selections are 'b', 'c', or 'p'");
} while (!make.equals("b") && !make.equals("c") && !make.equals("p"));
switch (make.charAt(0))
case 'b':
make = "Buick";
break;
case 'c':
make = "Chevrolet";
break;
case 'p':
make = "Pontiac";
}//end switch
return make;
}//end setMake
private String setColor(String colorType)
String color;
do
System.out.print("Select Blue, Green, or Red(b,g,r): ");
color = stdIn.nextLine();
if (make.charAt(0) != 'b' || make.charAt(0) != 'g' || make.charAt(0) != 'r');
else
System.out.print("The only valid selections are 'b', 'c', or 'r'");
} while (!make.equals("b") && !make.equals("g") && !make.equals("r")) ;
case 'b':
make = "Blue";
break;
case 'g':
make = "Green";
break;
case 'r':
make = "Red";
}//end switch
return color;
}//end setColor
}//end class Automobile
Driver Class:
public class AutomobileDriver
public static void main(String[] args)
Automobile car = new Automobile();
car.setIteration();
car.setMake();
car.setColor();
car.printColor();
car.printMake();
}//end main
}//end driverClass
SAMPLE DISPLAY:
How many cars do you want to consider? 2
Select Buick, Chevrolet, or Pontiac (b,c,p): x
Select Buick, Chevrolet, or Pontiac (b,c,p): p
Select blue, green, or red (b,g,r): r
red Pontiac
Select Buick, Chevrolet, or Pontiac (b,c,p): c
Select blue, green, or red (b,g,r): g
green Chevrolet
THANKS!
The message means what it says. You declared
Code:
and then tried to call
Code:
setMake()
without a String argument.
You don't seem to use makeType for anything, so maybe it shouldn't be there.
You have a typo in your setMake definition.
Code:
   String make;
   do
      if (make.charAt(0) != 'b' || make.charAt(0) != 'g'[/color] || make.charAt(0) != 'p');
      else
Where I have marked the code with red you should be checking for the character 'c', not 'g'.
More serious is your logic error in the if statement above. See what you get if the user types 'b' and again if the user types one of the letters not listed. You don't want to be using the logical or operator - you should be using the logical and operator - &&.
Also note that if your compound condition in the if statement turns out to be true, nothing happens!
