Java - calculate nth Fibonacci number
  • Topic: Comp Sci
  • Thread starter Thread starter Hercuflea
    Java
3 replies · 7K views
Hercuflea
Hello everyone, I am trying to write a java program that asks the user to input a number n, and the computer calculates the nth Fibonacci number. I am supposed to use a loop to calculate the problem.
My question is, how do I set up the loop to calculate the nth Fibonacci number? I know how to do all of the program except the loop.
I want to use the "for" loop.
import java.util.Scanner;
public class Assignment2 {
public static void main(String [] args) {
Scanner input = new Scanner(System.in);
System.out.print("Enter a number n in order to calculate the nth Fibonacci number: ");
int n = input.nextInt();
for(int i = 0; i;){}
System.out.println("The " + n + "th Fibonacci number is: ");
When you post code, put it inside [noparse]
Code:
[/noparse] tags. This makes your code easier to read, by preserving your indentation (if you used any).
You can't write a program to calculate Fibonacci numbers if you don't know how to calculate them yourself. What are the first few numbers in a Fibonacci sequence?
Code:
a1 = 0, a2 = 1, a3 = 1, a4 = 2, a5 = 3, a6 = 5, ...etc. adding the last two numbers to get the nth number.
Usually the indices start at zero, so that [itex]F_0=0[/itex], [itex]F_1=1[/itex], [itex]F_2=1[/itex], [itex]F_3=2[/itex],etc.
I would suggest that you store all calculated Fibonacci numbers in an array of Integers. To start with, you will need to initialize the array to include [itex]F_0[/itex] and [itex]F_1[/itex]. Then, to calculate the nth number, you first look in the array to see if it has already been calculated; if yes then simply output that entry in the array, if no, then start with the last 2 entries in the array an calculate and store (in the array) all the remaining numbers up until the nth number.
