Java Coin Counter Program: Counting Change with Syntax Errors Help
  • Topic: Java
  • Thread starter Thread starter JaysFan31
    Java
7 replies · 3K views
JaysFan31
Hi. I'm completely new to Java, but I'm taking a course at a local university. I was wondering if someone could help me with this.
I need to create a program that counts change (pennies, nickels, dimes, quarters).
I've only been taking the class for about a week and am still very inexperienced when it comes to programming (and more importantly spotting errors). I modeled this program after a very similar one in my textbook. However, I cannot compile it using Dr. Java. Would someone mind helping me with some of the syntax errors I have made? Any help would be appreciated.
import java.util.Scanner;
public class CoinCounter {
public static void main(String[] args) {
// we define the variables that we need for our calculations
int quarters = 0, dimes = 0.0;
int nickels = 0; pennies = 0;
int total, num;
// we read in the values
Scanner scan = new Scanner(System.in);
System.out.println("How many quarters do you have:");
int quarters = scan.nextInt();
System.out.println("How many dimes do you have:");
dimes = scan.nextInt();
System.out.println("How many nickels do you have:");
nickels = scan.nextInt();
System.out.println("How many pennies do you have:");
pennies = scan.nextDouble();
// we perform the calculations
quarters + dimes + nickels + pennies = num;
total = 25 * quarters;
total = total + 10 * dimes;
total = nickels * 5 + total;
total = total + pennies;
// print the result
System.out.println("The number of coins you have is "
+ num);
System.out.println("And they are worth in cents: " total);
dimes should be initialized to 0, not 0.0, right?
It would help if you posted the errors. We could compile it ourselves and see what our compilers say and point out your mistakes, but that doesn't help us help you learn how to read compiler output messages!
There is a ; instead of a , on the following line:
OK. I made 4 changes.
I changed the dimes to just 0
I changed the ; after nickels = 0 to ,
I changed the scan.nextDouble for pennies to scan.nextInt
I changed quarters + dimes + nickels + pennies = num; to num = quarters + dimes + nickels + pennies;
I still get the following compiler error however:
Line 35 "System.out.println("And they are worth in cents: " total);
Error: ')' expected
Could someone explain?
int quarters = 0, dimes = 0;
int nickels = 0, pennies = 0;
int total, num;
pennies = scan.nextInt();
// print the result
+ num);
JaysFan31 said:
Code:
Error: ')' expected
You need to concatenate the string with the variable total.
Error: ')' expected
[snip]
One likely elaboration is that somewhere in this line, there is a syntax error, and the error occurs someplace where it wouldn't be too unreasonable to expect a close parenthesis.
