Javascript multiplication tables
9 replies · 5K views · last reply
adjacent
I am learning Javascript and have made a multiplication table generating program.
But it's about 1000x slower than C#. Is there any problem with this code?
I used the same code as C#, just the syntax is different.
Here is the code:
Code:
<html>
<head lang="en">
    <meta charset="UTF-8">
    <title>Gui</title>
    <style>
        p{
            padding-left:15px;
        .dc {
            height:500px;
            overflow:scroll;
            border:1px solid black;
        td >table{border:1px solid #DFE0E4; border-radius:5px;}
    </style>
    <script>
        var mf = function(){
            document.getElementById("gui").innerHTML="";
            var Of= document.getElementById("of").value;
            var From= document.getElementById("from").value;
            var To= document.getElementById("to").value;
            for(var i=From;i<=To;i++)
                var ans = Of*i;
                document.getElementById("gui").innerHTML += Of +" x "+ i+" = "+ans +"<br>";
    </script>
</head>
<body style="background-color: #E9EAED;">
<table style="width:100%; height:100%;">
    <tr>
        <td valign="middle">
            <table align="center" style="width:100px;padding:5px;  background-color: #fff;">
                <tr><td>Of:</td><td><input type="number" id="of"></td></tr>
                <tr><td>From:</td><td><input type="number" id="from"></td></tr>
                <tr><td>To:</td><td><input type="number" id="to"></td></tr>
                <tr><td><button type="submit" onclick="mf()">Calculate</button></td></tr>
                <tr>
                    <td colspan="2">
                        <div class="dc"><p id="gui"></p> </div>
                    </td>
                </tr>
            </table>
        </td>
    </tr>
</table>
</body>
</html>
Maybe you could use a temporary variable instead of using innerHtml and then once everything concatted to it assign it to innerHtml.
Every time, you change innerHtml other threads of the browser will try to update the document display because the innerHtml was changed.
Oh, that solved the problem. I can even get the table up to 1million in about 15 secs. :smile:
Faster than C# with list.
Thank you so much!
Another question. How will I prevent this? I want a newline only after the <br> tag. I have already set overflow to scroll. But it's not working. I tried overflow-x too.
Web form with fields Of: 20000000000, From: 1, To: 10, a Calculate button, and an output box listing 20000000000 x 1 = 20000000000 and 20000000000 x 2 = 40000000000.
  • Web form with fields Of: 20000000000, From: 1, To: 10, and a Calculate button, above a text box listing 20000000000 x 1 = 20000000000 and 20000000000 x 2 = 40000000000 on separate lines.
so your code is generating
Code:
999 * 999 = 999<br>999 * 999 = 999<br>...999 * 999 = 999<br>
try adding the <br> to the line before you add the expression to the line and only if the line isn't the empty string to produce:
Code:
999 * 999 = 999<br>999 * 999 = 999<br>999 * 999 = 999
Would that work?
There are two thinks you can do.
First, limit the width so that if you overrun it would just make it wider.
So:
Code:
        .dc {
            height:500px;
            width:300px;
            overflow:scroll;
Then, replace the four spaces with "&nsbp;".
So:
Code:
                document.getElementById("gui").innerHTML += Of +"&nbsp;x&nbsp;"+ i+" &nbsp;=&nbsp;"+ans +"<br>";
Actually, forget about those "&nbsp;"s. Instead include "white-space: nowrap;" in your style.
Also, I am guessing that the start of your last style rule "td >table" is supposed to be "td, table".
Would that work?
It didn't work. :devil:
So:
Code:
        .dc {
            height:500px;
            width:300px;
            overflow:scroll;
Include "white-space: nowrap;" in your style.
Oh, it worked. But how do I set it to the width it had before setting any width property to it?
I have two tables , one for layout and other for the actual thing. the actual thing is inside <td> of the first table :wink:
Actually w3schools does not recommend using tables for layout. However, I don't find any other easy way to do it without using tables. Is there any performance issue with using tables?
The content of a multiplication table is (doh!) a table, and that's what HTML tables were intended for.
If you want to use tables to create something more complicated than a rectangular grid of cells, the code can quickly get very messy.
A better way to create more general layouts is to use the <div> tags to define "tiles" that fit together to make the complete page.
But It's a <p> element here. I made new lines for rows :confused:
