Jointly WSS Processes: ϕxy(τ) & ϕxy(ω)
  • Thread starter Thread starter SeriousNoob
The discussion focuses on jointly wide-sense stationary (WSS) processes, specifically analyzing the autocorrelation and cross-correlation of inputs v[t] and w[t] through linear time-invariant (LTI) systems h1(t) and h2(t). The key findings include the derivation of the expressions for the cross-correlation sequence ϕxy(τ) and the cross power spectrum ϕxy(ω) in terms of the input statistics and system parameters. Additionally, it is established that the cross power spectrum ϕxy(ω) is non-negative for all ω, confirming the properties of jointly WSS processes.
  • Understanding of jointly wide-sense stationary (WSS) processes
  • Knowledge of linear time-invariant (LTI) systems
  • Familiarity with autocorrelation and cross-correlation functions
  • Proficiency in Fourier Transform techniques
  • Study the properties of jointly WSS processes in detail
  • Learn about the implications of LTI systems on signal processing
  • Explore the derivation of power spectral density from autocorrelation
  • Investigate the conditions under which cross power spectra are non-negative
Students and professionals in signal processing, electrical engineering, and applied mathematics, particularly those working with stochastic processes and system analysis.
SeriousNoob
ϕ(t) = R(t) = autocorrelation
ϕ(f) = S(f) = power spectral density
Inputs v[t] and w[t] are zero mean, jointly WSS processes with auto-correlation se-
quences ϕvv(τ ) and ϕww(τ ), cross-correlation sequence ϕvw(τ ), power spectrums ϕvv(ω)
and ϕww(ω), and cross power spectrum ϕvw(ω). Let x(t) be the output of a LTI system
h1(t) with input v(t), i.e. x(t) = h1(t)v(t), and let y(t) be the output of a LTI system
h2(t) with input w(t), i.e. y(t) = h2(t)  w(t). Assume all quantities to be complex.
(a) Show that x(t) and y(t) are jointly WSS. Determine an expression for ϕxy(τ ) and
ϕxy(ω) in terms of the input statistics and the system parameters.
(b) Is the cross power spectrum always non-negative, i.e. is ϕxy(ω) ≥ 0, for all ω? Justify
your answer.
(c) Specialize this formula to obtain an expression for ϕxx(ω).
ϕxy(τ) = E[x(t)y(t+τ)]
ϕx(f) = ϕv(f)|H|²
ϕx(f) = Fourier Transform( ϕx(t) )
I'm at a complete loss. For jointly WSS, I need to prove x(t) and y(t) are WSS which they are because of v(t) and w(t) going through an LTI system. But I also need to show ϕxy(τ) only depends on τ.
I feel that I'm missing a crucial point and don't know how to start.
I suppose that it is trivial to show X(t) and Y(t) are WSS :wink: So the problem is only to prove X(t) and Y(t) are jointly WSS.
To do this, expand [itex]R_{XY}(t,t+\tau)[/itex]:
[itex]X(t) = \int_{-\infty}^{+\infty}V(t-\alpha)h_1(\alpha)d\alpha[/itex]
[itex]Y(t+\tau) = \int_{-\infty}^{+\infty}W(t+\tau-\beta)h_2(\beta)d\beta[/itex]
Hence:
[itex]R_{XY}(t,t+\tau) = \int_{\alpha=-\infty}^{+\infty} \int_{\beta=-\infty}^{+\infty} E[V(t-\alpha)W(t+\tau-\beta)]h_1(\alpha)h_2(\beta)d\beta d\alpha[/itex]
It is easy now :)
