K (thermal conductivity) value question.
The thermal conductivity (k value) of materials is generally temperature dependent, with most materials exhibiting this characteristic. While the k value is often referenced at room temperature (25 degrees C), exceptions exist, such as certain stainless steels that may have multiple temperature values listed. For practical applications, especially in building heating and cooling calculations, a constant k value is typically sufficient unless high precision is required, in which case the temperature range of 55 to 110 degrees F should be considered. Resources like www.matweb.com and www.elitesoft.com can provide additional material properties and simulation tools.
  • Understanding of thermal conductivity and its significance in material science.
  • Familiarity with temperature-dependent material properties.
  • Basic knowledge of heat transfer principles.
  • Experience with simulation software for thermal analysis.
  • Research the temperature-dependent properties of specific materials on www.matweb.com.
  • Learn about the ASHRAE guidelines for HVAC thermal conductivity values.
  • Explore the use of finite element analysis (FEA) in thermal conductivity simulations.
  • Investigate effective heating strategies for concrete in building applications.
Engineers, architects, and building designers focused on thermal performance, as well as researchers and students studying material properties and heat transfer in construction applications.
lawtonfogle
Does the k value have any relationship with the temperature of the wall (use of the word wall because that is what the k value is mostly used with).
Science news on Phys.org
Almost all materials' thermal conductivity coefficients are temperature dependent (I say almost to avoid absolutes, although I don't think I have heard of any materials that aren't). The thermal conductivity you can look up on www.matweb.com is usually at room temperature (25 degrees C), but there are exceptions (Some stainless steels, for example, may have a few tempertuare values listed). Heat transfer textbooks will tend to have temperature dependent properties of solids listed in their appendices.
Usually, a simple problem will approximate the conductivity coefficient as constant, but several highly complex problems I have solved in FEA must take this into account, especially with thermal conductivity, and electrical resistivity. Is there any particular material you are inquiring about?
As a point of fact, almost all material properties are to some extent temperature dependent.
Concrete, and how does it change when heated. I need the information for a simulation program, but all I have is the normal k value.
If you are just interested in calculating building heating/ac loads, you can consider it constant.
What kind of accuracy do you need to specify k to (allowed % error) and what temperature range do you expect the wall to experience?
Yes, in general there is a dependence, but it may be small enough that you don't have to worry about it (but not if you are doing a very precise calculation and your tolerances are 0.01% or somesuch).
The wall will be experencing a temperature range (in F) from no less than 55 to no more than 110. Mainly, I need to calculate is the difference enough to try to heat the concrete as an effective way to keep warmth in a house, and so I am looking for the equation to see if there is.
Those are pretty small temperature changes in engineering terms. You should be able to use just one value for the conductivity.
AFAIK, ASHRAE doesn't even list multiple k/r/u values for HVAC purposes, and the software I use doesn't calculate it. You may want to try it... www.elitesoft.com
  • · Replies 16 ·
14K
  • · Replies 27 ·
15K
