Why Does Benzoic Acid Have a Higher Ka but Lower Solubility than Acetic Acid?
  • Thread starter Thread starter #neutrino
    Solubility Water
Benzoic acid exhibits a higher acid dissociation constant (Ka) than acetic acid in aqueous solutions, yet its solubility in water is lower. This phenomenon arises because Ka values indicate the extent of ionization and reactivity of acids, while solubility is influenced by solute-solvent compatibility. The relationship between Ka and solubility is complex and not directly proportional, as solubility is more accurately described by solubility product equilibrium principles rather than simple acid-base comparisons.
  • Understanding of acid dissociation constants (Ka)
  • Knowledge of solubility principles in chemistry
  • Familiarity with solute-solvent interactions
  • Basic concepts of equilibrium constants
  • Research the concept of Solubility Product Equilibrium
  • Study the factors affecting solute-solvent compatibility
  • Explore the differences between strong and weak acids in aqueous solutions
  • Learn about the implications of Ka values on chemical reactivity
Chemistry students, researchers in chemical sciences, and professionals involved in acid-base chemistry and solubility studies will benefit from this discussion.
#neutrino
why is Ka of benzoic acid greater than acetic acid in aqueous medium yet water solubility of benzoic acid is less than acetic acid . (water solubility of acetic acid is infinite) ?
Chemistry news on Phys.org
What relation do you think should exist between Ka and solubility?
Very good question and extremely difficult to answer in simple terms. The most condensed explanation I can think of is Equilibrium Constants are numerical devices that define 'extent of reaction'. That is, it is a relative indicator of how much product is produced under specified conditions as a function of chemical reactivity. Its use to define solubility of a substance; i.e., acids in water can be misleading in that solubility is a function of solute-solvent compatibility factors whereas Ka values define the reactive ionization of a substance and not its solubility. Yes, K-values can be related to solubility, but you’ll see this more in discussions on Solubility Product Equilibrium as it relates to salt solubility (or, amount of salt that undergoes ionization in aqueous media) than in discussions comparing weak acid or weak base solubility.
  • · Replies 20 ·
  • · Replies 19 ·
13K
11K
10K
