Killing vector in kruskal coordinates
The discussion focuses on the transformation of the Killing vector \(\xi = -U\partial_U + V\partial_V\) from Kruskal coordinates to exterior Schwarzschild coordinates. The participants derive the necessary partial derivatives using implicit differentiation, leading to the expression \(\xi = 4m\frac{\partial}{\partial t}\) after correcting initial errors in the calculations. The transformation process involves differentiating the relationships between Kruskal coordinates and Schwarzschild coordinates, specifically using the chain rule. The final result confirms that \(\partial_t\) is indeed a Killing vector in the Schwarzschild metric.
  • Understanding of Kruskal coordinates and their properties
  • Familiarity with Schwarzschild coordinates and metrics
  • Knowledge of Killing vectors in differential geometry
  • Proficiency in implicit differentiation and the chain rule
  • Study the derivation of Killing vectors in general relativity
  • Learn about transformations between different coordinate systems in curved spacetime
  • Explore the implications of Killing vectors on symmetries in spacetime
  • Investigate the role of Kruskal and Schwarzschild coordinates in black hole physics
Researchers and students in theoretical physics, particularly those focusing on general relativity, differential geometry, and black hole studies.
cristo
Staff Emeritus
Let (U,V,\theta, \phi) be Kruskal coordinates on the Kruskal manifold, where -UV=\left(\frac{r}{2m}-1\right)e^{r/2m},\hspace{1cm} t=2m\ln\left(\frac{-V}{U}\right) and \theta and \phi are the usual polar angles. The metric is ds^2=\frac{-32m^3}{r}e^{\frac{-r}{2m}}dUdV+r^2d\Omega^2. The vector \xi=-U\partial_U+V\partial_V is a Killing vector.
I need to express \xi in exterior Schwarzschild coordinates, however I'm not sure how to go about doing this. I guess I need to transform the basis vectors \partial_U and \partial_V into basis vectors in the Schwarzschild coordinates, but can't see how to, as U and V are defined implicitly.
Any help would be much appreciated!
Does it work out if you use the chain rule, for example,
\frac{\partial}{\partial U} = \frac{\partial r}{\partial U} \frac{\partial}{\partial r} + \frac{\partial t}{\partial U} \frac{\partial}{\partial t},
and implicit differentiation?
Well, I've tried that; here's my attempt: -UV=\left(\frac{r}{2m}-1\right)e^{r/2m},\hspace{1cm} t=2m\ln\left(\frac{-V}{U}\right). Differentiating the first wrt U gives -V=\frac{\partial}{\partial U}\left[\frac{r}{2m}-1\right]e^{r/2m}=\frac{r}{4m^2}e^{r/2m}\frac{\partial r}{\partial U} \boxed{\Rightarrow \frac{\partial r}{\partial U}=\frac{-4m^2V}{r}e^{-r/2m}}. Differentiating the second wrt U gives \boxed{\frac{\partial t}{\partial U}=\frac{2m}{UV}}. Doing a similar thing for V gives \boxed{\frac{\partial r}{\partial V}=\frac{-4m^2U}{r}e^{-r/2m}} and \boxed{\frac{\partial t}{\partial V} =\frac{-2mU}{V}}. And so, -U\partial_U+V\partial_V=-U\left[\frac{-4m^2V}{r}e^{-2m/r}\frac{\partial}{\partial r}+\frac{2m}{UV}\frac{\partial}{\partial t}\right]+V\left[\frac{-4m^2U}{r}e^{-r/2m}\frac{\partial}{\partial r}-\frac{2mU}{V}\frac{\partial}{\partial t}\right] and this simplifies to give \xi =\frac{4m^2}{r}e^{-r/2m}(V-U)\frac{\partial}{\partial r}-2m\left(\frac{1-UV}{V}\right)\frac{\partial}{\partial t}
However, now I can't get rid of the U's and V's in the answer, since I don't have explicit definitions for them (well, obviously, the UV in the last term could be eliminated, but this won't help the fact that there are other U's and V's in the first term, and in the denominator of the second). Have I made a mistake somewhere? Thanks for helping, by the way!
Your derivatives of t with respect to U and V don't look right.
Ok, I've recalculated the derivatives of time, and get \frac{\partial t}{\partial U}=-\frac{2m}{U} and \frac{\partial t}{\partial V}=-\frac{2m}{V}. I also noted a mistake when calculating the last line; namely that I didn't multiply U and V (respectively) into the brackets. Doing so, causes the term in r to disappear, so we end up with \xi=4m\frac{\partial}{\partial t}. I think this makes sense, since \partial_t is a Killing vector in the Schwarzschild metric.
Thanks a lot for your help, George!
  • · Replies 43 ·
  • · Replies 31 ·
