Kinematic in Quadratic Form Equation (missing something simple)
12 replies · 3K views · last reply
Delta_Craig
I just ran this pretty quick at work. But this is the general outline. Sorry for the slop, it will get better with time. Thanks in advance and any additional info can be supplied.
The material is from the Khan free course.
A student is fed up with doing her kinematic formula homework, so she throws her pencil straight upward at 18.3 m/s.
How long does it take the pencil to first reach a point 12.2 m higher than where it was thrown?
Answers are suppose to be
t1= 0.869s
t2= 2.86s
My answers are negative time which is a neat concept. Doesn’t add up.
There are a lot of numbers there. Maybe a bit of algebra first would help?
Agreed, amongst other mathematics.
But, it does seem pretty straight forward.
I’ll keep plugging at it, I know it’s an order of op that’s got me on the wrong path.
Which direction are you taking as positive? Up or down?
Up for positive.
I have acceleration @ -9.81m/s
Delta_Craig said:
Up for positive.
It would be interesting to see your quadratic equation for ##t##.
Your first error is in line 2, where you have applied the same factor 1/2 to both g and s.
The next error is in multiplying those out you got a number near 1200 instead of near 120.
The result of that error was a negative number to square root, but instead of recognising something was wrong you just ignored the sign.
In your posted image, you then erroneously retained the square root sign having already substituted the root value.
Finally, you somehow got two positive results from -18.3±29.36.
It's so easy to go wrong with numbers I always find. ##g## is one symbol; whereas ##9.81m/s^2## is eight symbols.
Why would anyone prefer eight symbols when one would do?
t1= 0.869s
t2= 2.86s
Do they really teach you to do it that way? It seems extraordinary to me. I would never think of doing like that.
I just did, with up positive:
##s = v_0t - \frac 1 2 gt^2##
##\frac 1 2 gt^2 -v_0t + s = 0##
##t = \frac{v_0 \pm \sqrt{v_0^2 - 2gs}}{g}##
And I just plugged the numbers in a spreadsheet and out came the answer you quoted.
I’m sure you have a better grasp on this to make a statement like that, and I believe what your saying. I’m just going to run all the free courses (edit: knowing they are less than adequate, but a fair primer) I can before I start academically.
That’s the thing too, kinematic formulas are 100% new to me, so just learning these little gems is a lot of fun. I don’t have the perspective to know it’s not the most efficient way. I’m just hoping pencil on paper = progress
I’ll play with your formula tonight.
Or, try the calculator on your phone. Mine is a basic phone, but the calculator has an option to go into "scientific" mode. It's really easy to do formulas like that.
I’ll admit I rushed the formula at work, no excuse...
I’ll keep it cleaner from here on out, sorry for the waste of time on anyone’s part.
sat down and figured out the issue pretty quick.
On line 2, under the square root you are subtracting a velocity (m/s) from a squared velocity (m2/s2).
On line 3, the squared velocity is no longer squared. But you are about to take the square root of it.
On line 4, the square root of an un-squared velocity turns into an un-squared velocity.
If you are going to track units, track units.
