Kinematics: Analyzing circular motion of a particle
The discussion revolves around analyzing the circular motion of a particle using kinematic equations, particularly focusing on the SUVAT equations. Participants are exploring the relationships between initial velocity, acceleration, and displacement in a two-dimensional context.
  • Participants discuss the application of SUVAT equations, questioning which specific equations are relevant to the problem. There is an exploration of the use of trigonometry in determining angles and slopes, particularly in relation to vector components.
The discussion is active, with participants providing tips and suggestions for visualizing the problem through plotting. Some participants express uncertainty about their understanding of vector components and trigonometric relationships, while others clarify concepts related to angles and slopes.
There are indications of varying familiarity with the subject matter among participants, as well as references to regional differences in measurement units. Some participants express confusion regarding the notation used for position and velocity vectors.
Edward Hillsby
A particle moves with constant acceleration and its velocity at time t :
v= (5-0.1t)i +(3+0.2t)j
1. find a, u
2. find the time t when particle is travelling in direction NE and find its speed.
3. find the distance and bearing of the particle from the starting point at that time.
SUVAT, TRIG, Bearing
Help please
Hello @Edward Hillsby, :welcome: !
Apparently you know about SUVAT. Which ones in particular can be used here ?
Edward Hillsby said:
Help please
Sure! However, there are some requirements to get help at PF. Read here:smile: what is u anyway ? [edit] ah ! ##v_0## !
Tip: Make a plot !
u/initial velocity =v0, u is popular and very common in UK
SUVAT: v=u+at, r= r0+u0t+1/2 a t^2
UK is using inches and still has some catching up to do :-p
So: you know ##v = u + at## and you know ##v.\ \ ## What can be easier ?
BvU said:
Tip: Make a plot !
I am not sure how to use trig for the NE direction. It is 45 degree or pi/4, slope= 1
Tip: Make a plot ! All will be revealed !
is it vy sin 45=uy+ayt?, it does not work. What plot?
No. ##v_y = u_y + a_y t\ \ ## and ##\ v_x = u_x + a_x t ##
I am beginnning to fear you overlook the vector character of ##\vec r, \ \vec v,\ \vec a ## ?
What plot?
v= (5-0.1t)i +(3+0.2t)j ##\ \ ## You know what the ##\ \hat\imath\ ## and ## \ \hat\jmath\ ## stand for ?
Plot ##v_y(t)## as a function of ##v_x(t)## for ##t=0, 1, ...15## sMay I also advise you to use super- and subscripts ?
It is working. Thanks, guys from yahoo and overflow struggle to answer. I did not overlook vectors, but was to obsessed with trigs. 1 smart mathematician got similar result, using trigs: tangent, arcus tangent and got assumption pi/4=r_y/r_x...ry=(pi_*r_x)/4...is it right? I do not know what is different between ry and r_y. Thanks
It is working.
Without the plot ? :cry:
For what ?
I don'know if it's right. But intellegible it sure isn't :biggrin:
so, can angle in certain condition, here slope =1, be expressed by opposite/adjacent in right angle triangle? It mean angle = tangent??
The slope is the tangent of the angle. An angle π/4 gives a slope of 1. tan(π/4)=1.
I assume you are using rx, ry for coordinates of position.
ry=(π/4)rx would mean the position is a bit E of NE from the origin (ry<rx), so it is wrong on two counts:
1. For exactly NE you would want the coordinates equal. I.e. (ry/rx)=1=tan(π/4).
2. The condition you should be applying is that the velocity is NE.
thanks
  • · Replies 30 ·
