Kinematics equations with collision fo 2 balls
1 reply · 5K views
mjolnir80
a ball is shot straight up from the ground with speed Vo. simultaneously, a second rubber ball at height h directly above the first ball is dropped from rest
at what height above the ground do the balls collide?asnwer should be a symbolic expression in terms of Vo and g.
kinematics equations
we can use (delta)x = volt + 1/2 a t2 and since we know that the final positions are equal we can write this equation for the 2 balls and make them equal to each other
but the equation of the second ball would have a x(initial) for the ball in the equation (assuming the base line is the ground)...
can someone help me out please. Thanks in advanced
You mostly have it.
Construct the upward equation first:
X=Vo*t - 1/2*g*t2
Then construct the equation from rest:
X= h - 1/2*g*t2
If you solve for t then you just substitute into one of the x equations for the height.
