Kinematics - finding time given height and acceleration
5 replies · 28K views
indietro
The height of a helicopter above the ground is given by h = 2.50t^3 , where h is in meters and t is in seconds. After 2.45 s, the helicopter releases a small mailbag. How long after its release does the mailbag reach the ground?
d=v1t +1/2at^2
So i found the height of the helicopter at 2.45s which also = the distance the bag must fall:
=2.5(2.15)^3
= 36.8 m
then since the bag is in free fall it has an acceleration of 9.8m/s^2
and i just assume that the velocity is 0 because it is being drop from the helicopter.
so using kinematic equation: d=v1t +1/2at^2
rearrange for time and plugging in:
t^2= 36.8/4.9
t = 2.74s
can someone just check that my reasoning is correct? that would be great thanks :)
Well, since the helicopter is moving, the bag will have a (non-zero) initial velocity. So if you can figure out the helicopter's velocity at 2.45s, then you can use that for v1.
im not sure if I am finding velocity correctly...
so d = 36.76 m
a = 9.8 m/s^2
t = 2.45 s
plug into kinematic equation: d= vt + 1/2at^2 = 3 m/s
or do i not use gravity as acceleration because the helicopter could be accelerating...??
The helicopter is rising, not falling with gravity. Also, its acceleration is not constant; since a is not constant, those equations for constant acceleration do not work for the helicopter.
Have you had calculus? The derivative would be helpful in figuring out the helicopter's velocity here.
ok so the velocity of the helicopter h'= 7.5t^2 , plugging in 2.45s means the bag has in initial velocity of 45.0 m/s ...?
