What is the acceleration of the blue car once the brakes are applied?
  • Thread starter Thread starter maiad
    Cars Kinematics
The blue car accelerates uniformly at 4.2 m/s² for 3.2 seconds, covering a distance of 198 meters before applying brakes. It then decelerates uniformly to rest over a distance of 22 meters. The acceleration during braking was calculated using the formula Vf² = Vi² + 2ax, resulting in an acceleration of approximately -3.8 m/s². Attention to significant figures is crucial in online grading systems, as minor discrepancies can affect the final answer.
  • Understanding of kinematic equations, specifically Vf² = Vi² + 2ax
  • Knowledge of uniform acceleration and deceleration concepts
  • Familiarity with significant figures in mathematical calculations
  • Basic grasp of motion graphs and distance-time relationships
  • Study the implications of significant figures in physics calculations
  • Learn more about kinematic equations and their applications in real-world scenarios
  • Explore uniform acceleration and deceleration in various contexts
  • Investigate the effects of friction and other forces on vehicle motion
Students in physics courses, educators teaching kinematics, and anyone interested in understanding vehicle motion dynamics.
maiad
Two cars start from rest at a red stop light. When the light turns green, both cars accelerate forward. The blue car accelerates uniformly at a rate of 4.2 m/s2 for 3.2 seconds. It then continues at a constant speed for 13.2 seconds, before applying the brakes such that the car’s speed decreases uniformly coming to rest 220.0 meters from where it started. The yellow car accelerates uniformly for the entire distance, finally catching the blue car just as the blue car comes to a stop.
I found the distance traveled before the brakes were applied which was 198 m. I also found the speed at which it was constant which came out to be 13.44 m/s. These two values i have been confirmed is correct. I found the distance traveled after the brakes are applied which came out to be 22m (220.0-198).
So then i simply plugged the values into Vf^2=Vi^2+2ax → 0=(13.44)^2+2a(22)and solved for "a" but i got the wrong answer?
Look ok to me.
By the way, what is the yellow car doing in this problem.
I also agree that your work looks fine. However, I got 199 m instead of 198 m for the distance to where the blue car applies the brakes. Won't make much difference in the answer for the acceleration, but if you're plugging answers into on online grading system, then it might make a difference if they don't allow much tolerance.
Also, did you include the correct sign for the acceleration in your answer?
yes... very picky online grading system indeed. Thanks for your time guys :)
TRY this
0=(13)^2+2a(22)
answer is -3.8 or -3.84
the trick with the online grading is usually sig figs and that's why 13 is used not 13.44
  • · Replies 29 ·
12K
10K
