Kinematics- police driver acceleration problem
The discussion focuses on calculating the acceleration of a vehicle involved in an accident, where the police measured skidmarks of 150 meters. The driver was traveling at a speed of 80 km/h (22 m/s) when the brakes were applied. Using the kinematic equation v_{fx}^2 = v_{ox}^2 + 2as, the final velocity (v_{fx}) is 0 m/s, leading to an acceleration (a) of -1.61 m/s². This negative acceleration indicates the vehicle is decelerating as it comes to a stop.
  • Understanding of kinematic equations
  • Knowledge of unit conversions (km/h to m/s)
  • Familiarity with basic physics concepts such as acceleration and velocity
  • Ability to perform dimensional analysis
  • Study the derivation and application of kinematic equations in physics
  • Learn about unit conversions, specifically between kilometers per hour and meters per second
  • Explore the concept of negative acceleration and its implications in real-world scenarios
  • Investigate the principles of dimensional analysis in physics calculations
Students studying physics, accident reconstruction professionals, and anyone interested in understanding vehicle dynamics and kinematics.
alicia113
In an accident investigation police measured the skidmarks left my vehicle. they measure the skidmarks to be 150 m from the point where the driver applied the brakes to where the car came to rest. In their investigation the police Sumat the driver was traveling at this bead limit of 80 km/h (22m/s) when the brakes were applied. Calculate the acceleration of the vehicle.
ok so i know acceleration is
d= delta v
delta t
= vf - vi
delta t
but because this question has no initial point. What do I use? Do I just started off as zero OR do I have to solve for something? can someone please help me. thank you
Consider the kinematic relation v_{fx}^2 = v_{ox}^2 + 2as, where v_{fx} = final velocity of car after skid, v_{ox} = velocity of car before skid and\, s = displacement.
Think about what this equation is saying: From the stage of the journey where the car was traveling at 80km/h to the stage of the journey where the car is at rest, it has covered a distance of 150m, and so we can determine it's acceleration using the above relation.
ok so my s is 150m and my initial veloticy is 80km but i need to put that into m/s.. how do i find the final velocity?
The final velocity is given to you in the question. The words 'at rest' mean the car has halted to zero velocity.
ok so its just 0... so i just sub everything into the equaiton?
Yes. Notice the negative sign for acceleration. What does this mean?
because it is slowing down that's why it is negative
Yes, but to be a little bit more precise, if the car is defined to be moving in positive x direction and slowing down, then the acceleration vector would point in the negative x direction. Thus we get a 'negative acceleration' ( which is more precise than the word 'deceleration' used in everyday life)
ok so 80km/h is 22m/s
so..
0=22^2+2a(150)
0= 484+a300
-484=a300
-484
------ = a
300
-1.61 = a is it still in m/s?
or should i have stuck with 80km... and i would of got -21.3 km/h (i think that's the units not ti sure)
It is always best to rearrange the equation for the given quantity required. (This does help in figuring out the units).
So the kinematic relation rearranged for a yields a = \frac {v_{fx}^2 - v_{ox}^2}{2s},
If we replace each physical quantity with its units we end up with a= \frac{m^2/s^2}{m} from which you see one m cancels top and bottom to give m/s2 as the units.
However, having said that, with these sorts of quantities that we use 'all the time' in physics, they become second nature after a while. So this 'dimensional analysis', as it is called, is not required all the time, only when dealing with unfamiliar expressions.
The definition of acceleration is the change in velocity per unit time. So this -1.61 m/s2 means the car slows down at a rate of 1.61 m/s every second.
11K
