Kinematics, work-energy, conservation, more, less?
The discussion revolves around a kinematics problem involving a rocket that runs out of fuel after a short distance, coasts to a maximum altitude, and then falls back. Participants are tasked with finding the velocity of the rocket when it runs out of fuel, given its mass, maximum altitude, and gravitational acceleration.
  • Participants explore energy methods, questioning how to apply conservation of energy principles given the lack of time and initial acceleration data. They discuss the relationship between kinetic and potential energy at different points in the rocket's trajectory and express uncertainty about how to incorporate work and momentum into their reasoning.
Some participants have suggested that knowing the maximum altitude provides significant information, while others are still grappling with how to determine the height at which the rocket runs out of fuel and the implications of the problem's constraints. There is an acknowledgment of the challenge in deriving additional expressions needed to solve for unknowns.
Participants note that the problem specifies a "short distance" and that assumptions about the rocket's proximity to the moon's surface may influence the calculations, although they recognize the limitations of the information provided.
barrylwires
Rocket launched runs out of fuel after accelerating "for a short distance," coasts to a maximum altitude, then falls back. Known: rocket mass, max. altitude, g. Find velocity when rocket runs out of fuel.
There doesn't seem to be enough information to use kinematic eqs: no time for anything, no initial acceleration; only maximum height. We know the rocket force must be at least mg, but it's clearly more, since it coasts upwards.
Seems to need energy methods, but I can't see the way. E=K+U, but E=U (at top) doesn't equal E at bottom, where K and U are both zero. And what can we know about K+U at yfuelanyway? Do I need work, force? Do I need Wnonconservative=∆K+∆U? Does momentum enter this? I know that force changes from rocket to gravity at yfuel, but I'm not sure what to do with that. I could use a shove in the right direction.
If I try K1+U1=K2+U2 at y1=no fuel and y2=max. altitude, I just wind up with v2=2g(y2-y1), the kinematic eq., and I have two unknowns. I need another expression with one of these variables in it. Momentum? Kinematics? Thanks.
Welcome to PF.
If you know the max altitude you know a lot don't you?
Vi2 = 2*g*x
since you know the max altitude is where vf = 0
The only thing off is the "very short distance".
Hello and thank you. Yes. y2 = ymax does tell me a lot, but I don't see what resources I have to determine either a) the distance y1 is above the ground = y0 or b) what time the rocket ran out of fuel. I do see that v2 and v0= 0 and that v12 = -2g(y2-y1). Are you saying there is a way to determine y1?
The problem statement says short distance.
If you have Δy << y, and v2 = 2*g*y
then I'd say (y/(y-Δy))1/2 ≈ 1
Great. Got it.
When the problem said "Assume it was not far from the surface [of the moon] at that time [when it ran out of fuel]," I thought the point might have been to use mgMOON, rather than GmRmM/r2, but I'm happy to know that there isn't a way to find an actual value from the information given.
Many thanks!
  • · Replies 18 ·
