Kinetic E & Potential E Question
  • Thread starter Thread starter physics(L)10
    Kinetic Potential
The discussion focuses on calculating kinetic and potential energy for a 55kg mass projected vertically at an initial speed of 30 m/s. The original kinetic energy is calculated using the formula W = mv²/2, yielding 24,750 Joules. The kinetic energy after 4.5 seconds requires reevaluation of the velocity due to negative acceleration, leading to the use of conservation of energy principles to find the change in gravitational potential energy. The final approach emphasizes that height does not need to be calculated directly, as energy conservation provides the necessary relationship between kinetic and potential energy.
  • Understanding of kinetic energy calculations using W = mv²/2
  • Familiarity with gravitational potential energy, W = mgh
  • Knowledge of conservation of energy principles
  • Basic kinematics, particularly equations of motion under constant acceleration
  • Review the principles of conservation of energy in mechanical systems
  • Learn how to apply kinematic equations to solve for velocity and height
  • Explore advanced topics in energy transformations and their applications
  • Practice problems involving kinetic and potential energy calculations in various scenarios
Students studying physics, educators teaching mechanics, and anyone interested in understanding energy transformations in motion.
physics(L)10
A 55kg mass is projected vertically with and initial speed of 30m/sec
a) what is original kinetic energy
b) What is kinetic E after 4.5 seconds
c) What is chg in gravitational potential E in these 4.5seconds?
W=mv2/2
W=(m/2)(gt)2
W=mgh
a) Original =(55)(30)2/2
b) W=(m/2)(gt)2
=(55/2)[(9.8)(4.5)]2
c) W=mgh
=(55)(9.8)h
This is correct.
b) W=(m/2)(gt)2
This is not correct. Rethink how to calculate the speed; it's not equal to gt. (It's slowing down, for one thing. The acceleration is negative.)
ok I think I know,
v2=v1 -at
0=55-(9.8)(4.5)
Is this correct?
And how about c? you didn't comment on that
physics(L)10 said:
ok I think I know,
v2=v1 -at
0=55-(9.8)(4.5)
Good. (I assume you mean v2 = ..., not 0 = ...)
You need the answer to b to get c. (You aren't given the height.)
Yes my bad. and for c, does it look something like this?:
mgh=mv2/2
The m's cancel and you get:
gh=v2/2
Solving for h,
h=v2/2g
And then you could work out W=mgh?
mgh=mv2/2
Not exactly. Use conservation of energy like this:
KE1 + PE1 = KE2 + PE2
Then solve for the change in PE.
(Your equation assumes that the final KE is zero, which is not the case here.)
Note that there's no need to solve for h, just use energy conservation.
So let's say, initial speed = 55 and final = 25. These would be the only differences in KE1,KE2?
Those would be the speeds, from which you'd calculate KE1 and KE2 and then the difference.
How would you find out the height difference to find the potential energy difference?
You do not need the height difference. They ask for the change in PE, which can be found using conservation of energy.
If you wanted to find the height difference, use kinematics. But that's not necessary.
Would this work? I find change in KE which then can be used in the equation -KE=PE?
I think you mean -ΔKE = ΔPE. Sure that will work--that's equivalent to the equation I gave in post #6.
ΔKE = KE2 - KE1
ΔPE = PE2 - PE1
Okay I think I got it. Thank you :D :D
9K
  • · Replies 21 ·
