Kinetic energy and momentum (Conceptual Question)
The discussion revolves around a conceptual question involving two toy cars with different masses racing over a distance of 1.0 meter, focusing on their kinetic energy and momentum. Participants explore the implications of mass, force, and acceleration in the context of physics principles.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss which car crosses the finish line first, the kinetic energy at the finish line, and the momentum of each car. There are attempts to reason through the relationships between mass, force, acceleration, and the resulting energy and momentum.
Some participants provide insights into the principles of work and impulse, noting that both cars experience the same force over the same distance, leading to equal kinetic energy. Others question the assumptions made about speed and distance, indicating a lack of consensus on certain points while exploring the implications of different masses on acceleration and momentum.
Participants express confusion regarding the time intervals mentioned in the questions, particularly the implications of the time frame on the cars' performance and the definitions of work and impulse in this context.
ScienceGeek24
The two toy cars shown in the figure, with masses as given in the figure, are ready to race. Both cars begin from rest. For each question, state whether the correct answer is car A, car B, or whether the two cars have equal values for the parameter in question.
For the next three parts assume that the cars’ motors supply the same force to each car over the course of a 1.0-meter race.
Car A mass= 1000g
Car B mass= 800g
I know that A) Which car crosses the finish line 1.0 away first?
=> Car B wins because it has less mass and more acceleration therefore more force.
B) Which car has the larger kinetic energy when it crosses the finish line 1.0 away?
=> Both cars have the same kinetic energy I know that both cars have the same kinetic energy because is a scalar , it does not depend in any other variable than energy. So they both have the same amount of kinetic energy.
C) Which car has a larger momentum when it crosses the finish line 1.0 away?
=> Car A because car A has a greater mass than car B they both have the same speeds therefore car A it will have more momentum.
D) Which car has traveled farther after 10^8 ?
=> Car B (I really don't get this one) (or why)
E) After 10^8 which car has a larger kinetic energy?
=> Car B (I really didn't understand this one nether)
F) After 10 which car has a larger momentum?
=> Both cars have the same momentum. (I don't know why both have the same momentum when they both have different masses and same velocity.)
Help? Can someone explain this to me?? please??
Car A mass= 1000g
Car B mass= 800g
Your answer was going so well, and then you added "therefore more force" and spoiled it.B) Which car has the larger kinetic energy when it crosses the finish line 1.0 away?
Again, great opening 7 words but the reasoning is way off. Kinetic energy is gained when you do work on the cars. Work is force by distance. They were each subject to the same force. That force acted over a distance of 1 m.
Started out wrong this time, since you some how arrived at the idea that they have the same speed - which is wrong.
travelled father after 108 what?
If that is really 10-8 seconds these questions can start to make sense!
Again, if it is really 10-8 this has meaning
Comments above , and generally.
Work = Force x distance
Impulse = Force x time
Work leads to a change in KE on a flat surface
Impulse leads to a change in momentum.
Both these cars are subject to the same force, so variations in Work - KE and Impluse - momentum come about due to differeing distances and/or differing times.
The different masses mean B accelerates at a higher rate - will thus gain a higher speed, and cover a greater distance - in a given time.
If the "race" lasts only 1 metre, Car B, which has accelerated more quickly will win, because it is traveling faster.
Force x distance is the same for both cars; so Ke is the same
Force x time is greater for Car A, since it takes a greater amount of time to get there.
If the acceleration is carried out for a set amount of time, then the impulse applied to each is the same; so they have the same momentum.
In that time, B will have covered a greater distance, so the work done on B is greater than the work done on A; so B will have the greater KE. [remember; work = force x distance]
Thanks! I can see now the meaning. Is just that i did not quite understood the concept of Work and impulse. Work is the change in KE on a flat surface and impulse is the change in momentum. It all seems clear now. Thanks man!
I mentioned the flat surface as sometimes these things happen on slopes, and part of the work goes to a change in Potential energy as well.
  • · Replies 17 ·
18K
